[Nek5000-users] Linearised Navier Stokes
Fri Aug 18 09:38:41 CDT 2017
in particular, one can use the same mesh (and thus map file) for both
linear and nonlinear simulation.
Philipp
On 2017-08-18 12:02, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Swarandeep,
> The binary mesh is saved in the re2 file, you can use that file to
> generate a map file with genmap.
> You don't need to start from the box file, because for this specific
> case the type of the boundary conditions is the same for the linear and
> nonlinear simulations.
> Regards,
> clio
> Quoting nek5000-users at lists.mcs.anl.gov:
>> Hi
>>     I could no find the ###.ma2 file for the dfh_cav example. Hence I
>> suppose I require the ###.box or the ###.map file to proceed for the base
>> flow. Please correct me if I have misunderstood.
>> Swarandeep
>> On Fri, Aug 18, 2017 at 1:03 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi Swarandeep,
>>> For computing the base flow you can use the same mesh and map file. What
>>> you need to change is 1) the boundary conditions such that they are
>>> valid
>>> for the base flow and 2) the flags that you run a nonlinear instead of a
>>> linear case.
>>> As Clio was saying, in that particular case the base flow was computed
>>> using a Newton method. For lower Rayleigh numbers, you should however be
>>> able to just run (nonlinear) DNS to reach the steady state.
>>> Best regards,
>>> Philipp
>>> On 2017-08-17 20:23, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi Clio and Adam,
>>>>         Thanks for the information.
>>>>   I think in order to compute the base flow I need the ###.box file as
>>>> well as a different ###.usr file as I think the boundary and initial
>>>> conditions for the ###.usr file in the short_tests/dfh_cav directory is
>>>> applicable for the perturbations only. Please send me the ###.box
>>>> and the
>>>> corresponding ###.usr file applicable for the base flow for dfh_cav
>>>> case.
>>>> Swarandeep
>>>> On Thu, Aug 17, 2017 at 7:03 PM, <nek5000-users at lists.mcs.anl.gov
>>>> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>>>>     Hi Swarandeep,
>>>>     The baseflow has been computed with a Newton solver (which is not
>>>>     available in the nek examples). The additional code had been
>>>>     implemented in the version 1040 of nek5000, and there is no .par
>>>>     file for that. However, in general, if your case is laminar, to
>>>>     compute a baseflow, you just need to evaluate the steady state of
>>>>     your nonlinear case. For that, you can use the same .par file, and
>>>>     just change to the nonlinear solver (perturbationmodes = 0,
>>>>     perturbations = no, solveBaseflow = yes).
>>>>     The non dimensionalization is based on Hellums and Churchill
>>>> (1962).
>>>>     The equations are:
>>>>     Pr (du/dt + (U*nabla)u + (u*nabla)U) = 1/sqrt(Ra)laplacian(u) -grad
>>>>     p + e_g theta
>>>>     d theta/dt + (u*nabla)Theta + (U*nabla)theta =
>>>>     1/sqrt(Ra)laplacian(theta)
>>>>     div(u)=0
>>>>     where u, theta are respectively the velocity and temperature of the
>>>>     perturbation, U, Theta the velocity and temperature of the
>>>> baseflow.
>>>>     You can find more information in the paper "Saglietti, Clio, et al.
>>>>     "Adjoint optimization of natural convection problems:
>>>> differentially
>>>>     heated cavity." Theoretical and Computational Fluid Dynamics
>>>> (2016):
>>>>     1-17." on which the example is based.
>>>>     Regards,
>>>>     clio
>>>>     <mailto:nek5000-users at lists.mcs.anl.gov>:
>>>>         Hi Adam,
>>>>         Thanks for the clarification. Can you please send me a sample
>>>>         .par file for
>>>>         the baseflow for the case of "dfh_cav". Also is it possible to
>>>>         get the
>>>>         equations solved for this problem(dfh_cav). I would like to
>>>> know
>>>>         the way
>>>>         that this has been made dimensionless.
>>>>         For your kind information I briefly describe my case which I
>>>>         have been used
>>>>         to solve with the regular non-linear framework using older
>>>>         versions (.rea
>>>>         files). My setup is as follows:
>>>>         Geometry is a 3D cylindrical annullus.
>>>>         Temperature are fixed at inner and outer cylinders.
>>>>         Gravity is acting in -z direction
>>>>         There is a back ground rotation which is constant.
>>>>         Please let me know if any other info is required. Thanks for
>>>> the
>>>>         help.
>>>>         Swarandeep
>>>>         On Thu, Aug 17, 2017 at 1:48 PM,
>>>>             Hi Swarandeep,
>>>>             Yes. You generate ###.rea in the standard way. In the old
>>>>             version it was
>>>>             txt and contained both mesh information and runtime
>>>>             parameter. One could
>>>>             split mesh information (###.re2, binary file) and runtime
>>>>             parameters
>>>>             (###.rea with negative number of elements or currently
>>>>             ###.par) using
>>>>             reatore2 tool. The map file is generated with genmap
>>>> (can be
>>>>             txt or
>>>>             binary). So the procedure is more or less the same. If you
>>>>             have ###.rea
>>>>             with mesh you split it and generate ###.re2. Next you
>>>>             generate ###.map with
>>>>             genmap and finally ###.par by hand. Be careful to use tolls
>>>>             from the same
>>>>             release, as they've been changed significantly (e.g. binary
>>>>             ###.map file).
>>>>             Regards
>>>>             Adam
>>>>             On 16/08/17 18:52, nek5000-users at lists.mcs.anl.gov
>>>>             <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>>>>             Hi Adam,
>>>>                       Thank you very much for the help.
>>>>                       Does the ###.map, ###.box file  and from them the
>>>>             ###.rea file
>>>>             (in the dfh_cav case: the ###.re2 files)  are created as
>>>>             done for the
>>>>             earlier versions i.e., by using genbox and genmap. Please
>>>>             clarify.
>>>>             Swarandeep
>>>>             On Wed, Aug 16, 2017 at 5:35 PM,
>>>>                 Hi,
>>>>                 The simplest way would be to look into existing example
>>>>                 under
>>>>                 Nek5000/short_test/dfh_cav/
>>>>                 It is a differentially heated cavity case and covers
>>>>                 both direct and
>>>>                 adjoint linear solver. It is compatible with the
>>>> current
>>>>                 git version and
>>>>                 uses ###.par file instead of ###.rea.
>>>>                 Regards
>>>>                 Adam
>>>>                 On 11/08/17 11:05, nek5000-users at lists.mcs.anl.gov
>>>>                     This information might be outdated (old version)
>>>> but
>>>>                     previously the base
>>>>                     flow was read in using the restart option in the
>>>> rea
>>>>                     file. The disturbance
>>>>                     you can read in yourself in userchk.
>>>>                     Philipp
>>>>                     On 2017-08-11 10:49,
>>>>                         Hi Philipp,
>>>>                                That was very much helpful. I have a
>>>>                         steady base flow and
>>>>                         temperature state. Please let me know where to
>>>>                         provide the base flow.
>>>>                         Thank you
>>>>                         Swarandeep
>>>>                         _______________________________________________
>>>>                         Nek5000-users mailing list
>>>>                         Nek5000-users at lists.mcs.anl.gov
>>>>                         <mailto:Nek5000-users at lists.mcs.anl.gov>
>>>>                         https://lists.mcs.anl.gov/mail
>>>> man/listinfo/nek5000-users
>>>>                         <https://lists.mcs.anl.gov/mai
>>>> lman/listinfo/nek5000-users>
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>> <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>             Nek5000-users mailing listNek5000-users at lists.mcs.an
>>>>             <mailto:listNek5000-users at lists.mcs.an>l.govhttps://lists.
>>>>             <http://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>>>             <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>>>     Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mc
>>>> s.anl.gov>
