[Nek5000-users] Linearised Navier Stokes
Fri Aug 18 05:02:02 CDT 2017
Hi Swarandeep,
The binary mesh is saved in the re2 file, you can use that file to
generate a map file with genmap.
You don't need to start from the box file, because for this specific
case the type of the boundary conditions is the same for the linear
and nonlinear simulations.
clio
Quoting nek5000-users at lists.mcs.anl.gov:
> Hi
>     I could no find the ###.ma2 file for the dfh_cav example. Hence I
> suppose I require the ###.box or the ###.map file to proceed for the base
> flow. Please correct me if I have misunderstood.
> Swarandeep
> On Fri, Aug 18, 2017 at 1:03 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Swarandeep,
>> For computing the base flow you can use the same mesh and map file. What
>> you need to change is 1) the boundary conditions such that they are valid
>> for the base flow and 2) the flags that you run a nonlinear instead of a
>> linear case.
>> As Clio was saying, in that particular case the base flow was computed
>> using a Newton method. For lower Rayleigh numbers, you should however be
>> able to just run (nonlinear) DNS to reach the steady state.
>> Best regards,
>> Philipp
>> On 2017-08-17 20:23, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Clio and Adam,
>>>         Thanks for the information.
>>>   I think in order to compute the base flow I need the ###.box file as
>>> well as a different ###.usr file as I think the boundary and initial
>>> conditions for the ###.usr file in the short_tests/dfh_cav directory is
>>> applicable for the perturbations only. Please send me the ###.box and the
>>> corresponding ###.usr file applicable for the base flow for dfh_cav case.
>>> Swarandeep
>>> On Thu, Aug 17, 2017 at 7:03 PM, <nek5000-users at lists.mcs.anl.gov
>>> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>>>     Hi Swarandeep,
>>>     The baseflow has been computed with a Newton solver (which is not
>>>     available in the nek examples). The additional code had been
>>>     implemented in the version 1040 of nek5000, and there is no .par
>>>     file for that. However, in general, if your case is laminar, to
>>>     compute a baseflow, you just need to evaluate the steady state of
>>>     your nonlinear case. For that, you can use the same .par file, and
>>>     just change to the nonlinear solver (perturbationmodes = 0,
>>>     perturbations = no, solveBaseflow = yes).
>>>     The non dimensionalization is based on Hellums and Churchill (1962).
>>>     The equations are:
>>>     Pr (du/dt + (U*nabla)u + (u*nabla)U) = 1/sqrt(Ra)laplacian(u) -grad
>>>     p + e_g theta
>>>     d theta/dt + (u*nabla)Theta + (U*nabla)theta =
>>>     1/sqrt(Ra)laplacian(theta)
>>>     div(u)=0
>>>     where u, theta are respectively the velocity and temperature of the
>>>     perturbation, U, Theta the velocity and temperature of the baseflow.
>>>     You can find more information in the paper "Saglietti, Clio, et al.
>>>     "Adjoint optimization of natural convection problems: differentially
>>>     heated cavity." Theoretical and Computational Fluid Dynamics (2016):
>>>     1-17." on which the example is based.
>>>     Regards,
>>>     clio
>>>     <mailto:nek5000-users at lists.mcs.anl.gov>:
>>>         Hi Adam,
>>>         Thanks for the clarification. Can you please send me a sample
>>>         .par file for
>>>         the baseflow for the case of "dfh_cav". Also is it possible to
>>>         get the
>>>         equations solved for this problem(dfh_cav). I would like to know
>>>         the way
>>>         that this has been made dimensionless.
>>>         For your kind information I briefly describe my case which I
>>>         have been used
>>>         to solve with the regular non-linear framework using older
>>>         versions (.rea
>>>         files). My setup is as follows:
>>>         Geometry is a 3D cylindrical annullus.
>>>         Temperature are fixed at inner and outer cylinders.
>>>         Gravity is acting in -z direction
>>>         There is a back ground rotation which is constant.
>>>         Please let me know if any other info is required. Thanks for the
>>>         help.
>>>         Swarandeep
>>>         On Thu, Aug 17, 2017 at 1:48 PM,
>>>             Hi Swarandeep,
>>>             Yes. You generate ###.rea in the standard way. In the old
>>>             version it was
>>>             txt and contained both mesh information and runtime
>>>             parameter. One could
>>>             split mesh information (###.re2, binary file) and runtime
>>>             parameters
>>>             (###.rea with negative number of elements or currently
>>>             ###.par) using
>>>             reatore2 tool. The map file is generated with genmap (can be
>>>             txt or
>>>             binary). So the procedure is more or less the same. If you
>>>             have ###.rea
>>>             with mesh you split it and generate ###.re2. Next you
>>>             generate ###.map with
>>>             genmap and finally ###.par by hand. Be careful to use tolls
>>>             from the same
>>>             release, as they've been changed significantly (e.g. binary
>>>             ###.map file).
>>>             Regards
>>>             Adam
>>>             On 16/08/17 18:52, nek5000-users at lists.mcs.anl.gov
>>>             <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>>>             Hi Adam,
>>>                       Thank you very much for the help.
>>>                       Does the ###.map, ###.box file  and from them the
>>>             ###.rea file
>>>             (in the dfh_cav case: the ###.re2 files)  are created as
>>>             done for the
>>>             earlier versions i.e., by using genbox and genmap. Please
>>>             clarify.
>>>             Swarandeep
>>>             On Wed, Aug 16, 2017 at 5:35 PM,
>>>                 Hi,
>>>                 The simplest way would be to look into existing example
>>>                 under
>>>                 Nek5000/short_test/dfh_cav/
>>>                 It is a differentially heated cavity case and covers
>>>                 both direct and
>>>                 adjoint linear solver. It is compatible with the current
>>>                 git version and
>>>                 uses ###.par file instead of ###.rea.
>>>                 Regards
>>>                 Adam
>>>                 On 11/08/17 11:05, nek5000-users at lists.mcs.anl.gov
>>>                     This information might be outdated (old version) but
>>>                     previously the base
>>>                     flow was read in using the restart option in the rea
>>>                     file. The disturbance
>>>                     you can read in yourself in userchk.
>>>                     Philipp
>>>                     On 2017-08-11 10:49, nek5000-users at lists.mcs.anl.gov
>>>                         Hi Philipp,
>>>                                That was very much helpful. I have a
>>>                         steady base flow and
>>>                         temperature state. Please let me know where to
>>>                         provide the base flow.
>>>                         Thank you
>>>                         Swarandeep
>>>                         _______________________________________________
>>>                         Nek5000-users mailing list
>>>                         Nek5000-users at lists.mcs.anl.gov
>>>                         <mailto:Nek5000-users at lists.mcs.anl.gov>
>>>                         https://lists.mcs.anl.gov/mail
>>> man/listinfo/nek5000-users
>>>                         <https://lists.mcs.anl.gov/mai
>>> lman/listinfo/nek5000-users>
>>>                 https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>                 <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>             Nek5000-users mailing listNek5000-users at lists.mcs.an
>>>             <mailto:listNek5000-users at lists.mcs.an>l.govhttps://lists.
>>>             <http://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>>             <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>>     Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mc
>>> s.anl.gov>
