[Nek5000-users] Linearised Navier Stokes
Thu Aug 17 03:18:57 CDT 2017
Hi Swarandeep,
Yes. You generate ###.rea in the standard way. In the old version it was
txt and contained both mesh information and runtime parameter. One could
split mesh information (###.re2, binary file) and runtime parameters
(###.rea with negative number of elements or currently ###.par) using
reatore2 tool. The map file is generated with genmap (can be txt or
binary). So the procedure is more or less the same. If you have ###.rea
with mesh you split it and generate ###.re2. Next you generate ###.map
with genmap and finally ###.par by hand. Be careful to use tolls from
the same release, as they've been changed significantly (e.g. binary
###.map file).
Regards
Adam
On 16/08/17 18:52, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Adam,
>          Thank you very much for the help.
>          Does the ###.map, ###.box file  and from them the ###.rea
> file (in the dfh_cav case: the ###.re2 files)  are created as done for
> the earlier versions i.e., by using genbox and genmap. Please clarify.
> Swarandeep
> On Wed, Aug 16, 2017 at 5:35 PM, <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>     Hi,
>     The simplest way would be to look into existing example under
>     Nek5000/short_test/dfh_cav/
>     It is a differentially heated cavity case and covers both direct
>     and adjoint linear solver. It is compatible with the current git
>     version and uses ###.par file instead of ###.rea.
>     Regards
>     Adam
>     On 11/08/17 11:05, nek5000-users at lists.mcs.anl.gov
>     <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>         This information might be outdated (old version) but
>         previously the base flow was read in using the restart option
>         in the rea file. The disturbance you can read in yourself in
>         userchk.
>         Philipp
>         On 2017-08-11 10:49, nek5000-users at lists.mcs.anl.gov
>             Hi Philipp,
>                   That was very much helpful. I have a steady base
>             flow and
>             temperature state. Please let me know where to provide the
>             base flow.
>             Thank you
>             Swarandeep
>             _______________________________________________
>             Nek5000-users mailing list
>             Nek5000-users at lists.mcs.anl.gov
>             <mailto:Nek5000-users at lists.mcs.anl.gov>
>             https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>             <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170817/6273dd9f/attachment.html>
