[Nek5000-users] Linearised Navier Stokes
Wed Aug 16 11:52:12 CDT 2017
Hi Adam,
         Thank you very much for the help.
         Does the ###.map, ###.box file  and from them the ###.rea file (in
the dfh_cav case: the ###.re2 files)  are created as done for the earlier
versions i.e., by using genbox and genmap. Please clarify.
Swarandeep
On Wed, Aug 16, 2017 at 5:35 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi,
> The simplest way would be to look into existing example under
> Nek5000/short_test/dfh_cav/
> It is a differentially heated cavity case and covers both direct and
> adjoint linear solver. It is compatible with the current git version and
> uses ###.par file instead of ###.rea.
> Regards
> Adam
> On 11/08/17 11:05, nek5000-users at lists.mcs.anl.gov wrote:
>> This information might be outdated (old version) but previously the base
>> flow was read in using the restart option in the rea file. The disturbance
>> you can read in yourself in userchk.
>> Philipp
>> On 2017-08-11 10:49, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Philipp,
>>>       That was very much helpful. I have a steady base flow and
>>> temperature state. Please let me know where to provide the base flow.
>>> Thank you
>>> Swarandeep
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170816/206985bd/attachment.html>
