[Nek5000-users] Linearised Navier Stokes
Wed Aug 16 07:05:26 CDT 2017
The simplest way would be to look into existing example under
Nek5000/short_test/dfh_cav/
It is a differentially heated cavity case and covers both direct and
adjoint linear solver. It is compatible with the current git version and
uses ###.par file instead of ###.rea.
Regards
Adam
On 11/08/17 11:05, nek5000-users at lists.mcs.anl.gov wrote:
> This information might be outdated (old version) but previously the
> base flow was read in using the restart option in the rea file. The
> disturbance you can read in yourself in userchk.
> Philipp
> On 2017-08-11 10:49, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Philipp,
>>       That was very much helpful. I have a steady base flow and
>> temperature state. Please let me know where to provide the base flow.
>> Thank you
>> Swarandeep
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
