[Nek5000-users] Conjugate heat transfer with complex properties
Thu Aug 3 11:36:33 CDT 2017
Awesome, thank you Paul.
Adam
On 08/03/2017 11:19 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Yes - that should work.
> Set ifuservp = .true. and then, in uservp()
>       if (ifield.eq.1) then ! fluid properties
>             udiff = param(2)
>             utrans = param(1)
>       else                            ! thermal properties
>             udiff = your diffusivity
>             utrans = your rhoCp
>       endif
> *From:* Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on
> behalf of nek5000-users at lists.mcs.anl.gov
> <nek5000-users at lists.mcs.anl.gov>
> *Sent:* Thursday, August 3, 2017 10:13:03 AM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* Re: [Nek5000-users] Conjugate heat transfer with complex
> properties
> Hi Paul,
> Yep, there's some melting going on.  There's a porous structure that
> does not melt and wax trapped in the porous structure.  The wax melts
> and re-solidifies.  There really nothing complex happening with the
> geometry.  A static mesh should do the job.  The material properties
> are the challenge.  I think I could model the material behavior as
> having a non-linear specific heat capacity as a function of temperature.
> Adam
> On 08/03/2017 09:30 AM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Adam,
>> Can you be more specific?  Is it melting?
>> In principle, it should be possible as that was one of the original
>> applications for Nek5000.  In practice, however, I would rate that as
>> still a research area (at least from the Nek perspective).  I guess
>> that melting is much easier than freezing, however.
>> Paul
>> *Sent:* Thursday, August 3, 2017 8:29:09 AM
>> *Subject:* [Nek5000-users] Conjugate heat transfer with complex
>> properties
>> Hello,
>> I have a conjugate heat transfer problem where the solid material is a
>> composite that undergoes a phase transformation.  Is it possible to
>> model a material like this in Nek5000?
>> Thanks,
>> Adam Lange
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170803/6e516b39/attachment-0001.html>
