[Nek5000-users] constant average velocity at inlet with periodic boundary conditions
Tue Sep 6 08:39:26 CDT 2016
Dear nek users,
I am simulating the flow in a 7 pin bundle mesh with periodic boundary conditions in Nek5000 and set the parameters p054 and p055 to -3 and 1, respectively. With these settings, the average velocity should be 1 in the geometry. This is however not what I am seeing; the maximum velocity is around 0.32.
I used the same set up for a 3-D pipe and the numerical solution behaves as expected.
Does anybody has details on how the fix mass flow rate/volumetric velocity are enforced in Nek5000?
Marco
