[Nek5000-users] ERROR: Error reading restart header. Abort. ierr= 2 call exitt: dying ...
Fri Sep 2 14:40:04 CDT 2016
Thanks for the reply. Here is the full output file that contains the log.
Saikat.
*Saikat Mukherjee,*
*Graduate** Student,*
*Engineering Science and Mechanics,*
*BEAM,*
*Virginia Tech.*
On Fri, Sep 2, 2016 at 3:31 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Saikat,
> Can you show the complete log you get when trying  to run the case ?
> Thanks,
> Antoine
> *De: *nek5000-users at lists.mcs.anl.gov
> *À: *nek5000-users at lists.mcs.anl.gov
> *Envoyé: *Vendredi 2 Septembre 2016 19:29:47
> *Objet: *[Nek5000-users] ERROR: Error reading restart header. Abort.
> Hello all,
> I have been getting this error message for my RESTART calculations,
> however using the same kind of .rea file in a different calculation
> (different mesh) seems to work. Any help is appreciated. .rea file is
> attached. I had to zip it because it exceeds the file upload size
> limitation.
> Thanks,
> Saikat.
> *Saikat Mukherjee,*
> *BEAM,*
> *Virginia Tech.*
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160902/0db1dade/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160902/0db1dade/attachment.obj>
