[Nek5000-users] constant average velocity at inlet with periodic boundary conditions
Tue Sep 6 09:19:38 CDT 2016
Hi Marco,
Does this have conjugate heat transfer ?
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Tuesday, September 06, 2016 8:39 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] constant average velocity at inlet with periodic       boundary conditions
Dear nek users,
I am simulating the flow in a 7 pin bundle mesh with periodic boundary conditions in Nek5000 and set the parameters p054 and p055 to -3 and 1, respectively. With these settings, the average velocity should be 1 in the geometry. This is however not what I am seeing; the maximum velocity is around 0.32.
I used the same set up for a 3-D pipe and the numerical solution behaves as expected.
Does anybody has details on how the fix mass flow rate/volumetric velocity are enforced in Nek5000?
Marco
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
