[Nek5000-users] Issue in 3D NEKNEK simulations
Wed Oct 5 12:03:36 CDT 2016
Hi Sudhakar,
Thank you for sharing your experiences with using NekNek. We have run many
3D examples with it, and it has been working fine. Maybe, you can send your
modification to an eddy_neknek case where you experience this problem
offline, and we can look at it?
Best regards,
Yulia Peet
Yulia T. Peet
Assistant Professor of Aerospace and Mechanical Engineering
Arizona State University
School for Engineering of Matter, Transport and Energy (SEMTE)
Office: ERC 379
Tel: 480-965-0735
E-mail: ypeet at asu.edu
Web: isim.asu.edu
On Wed, Oct 5, 2016 at 6:03 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi,
> I am coupling the Navier-Stokes and Darcy equations using the NekNek
> framework. Everything is working fine in 2D. However, any 3D example in
> neknek is stuck endlessly in the following line
> call mpi_send <http://www.mcs.anl.gov/research/projects/nek5/docs/html/mpi__dummy_8f.html#af98c20c7332635506f852083f7ee504a>(jsend,len,mpi_byte,id <http://www.mcs.anl.gov/research/projects/nek5/docs/html/findpts__test_8c.html#a37e2ea357c25dfa93b154d03c233cd23>,100+nid, intercomm,ierr)
> within the "intpts_locate" subroutine in multimesh.f. When I modify the
> eddy_neknek test case given in the example folder, the behavior is the
> same, so the issue is not specific to my examples. I already checked that
> the problem is not the memory or the length of the data processed in
> MPI_send. Did anyone experience the same before?
> Thank you very much,
> Best regards,
> Sudhakar
> The Royal institute of Technology (KTH)
> Nek5000-users mailing list
Yulia T. Peet
Office: ERC 379
Tel: 480-965-0735
Web: isim.asu.edu
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161005/74acbff2/attachment.html>
