[Nek5000-users] Nek5000-users Digest, Vol 92, Issue 2
Thu Oct 6 04:41:35 CDT 2016
Hi all,
Sorry for the confusion in the first post. Any 3D Neknek simulation is
stuck endlessly in the following line
call mpi_send(jsend,len,mpi_byte,id,100+nid, intercomm,ierr)
within "intpts_locate" subroutine in multimesh.f.
Could anyone please share if you have experienced similar issues, and
how can this be resolved?
Thank you very much,
Best regards,
Sudhakar
Quoting nek5000-users-request at lists.mcs.anl.gov:
> Send Nek5000-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> 	https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	nek5000-users-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Nek5000-users digest..."
> Today's Topics:
>    1. Issue in 3D NEKNEK simulations (nek5000-users at lists.mcs.anl.gov)
> Message: 1
> Date: Wed, 5 Oct 2016 15:03:33 +0200
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Subject: [Nek5000-users] Issue in 3D NEKNEK simulations
> Message-ID:
> 	<mailman.4026.1475672736.3602.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset="utf-8"; Format="flowed"
> Hi,
> I am coupling the Navier-Stokes and Darcy equations using the NekNek
> framework. Everything is working fine in 2D. However, any 3D example in
> neknek is stuck endlessly in the following line
> callmpi_send
> <http://www.mcs.anl.gov/research/projects/nek5/docs/html/mpi__dummy_8f.html#af98c20c7332635506f852083f7ee504a>(jsend,len,mpi_byte,id
> <http://www.mcs.anl.gov/research/projects/nek5/docs/html/findpts__test_8c.html#a37e2ea357c25dfa93b154d03c233cd23>,100+nid,
> intercomm,ierr)
> within the "intpts_locate" subroutine in multimesh.f. When I modify the
> eddy_neknek test case given in the example folder, the behavior is the
> same, so the issue is not specific to my examples. I already checked
> that the problem is not the memory or the length of the data processed
> in MPI_send. Did anyone experience the same before?
> Best regards,
> Sudhakar
> The Royal institute of Technology (KTH)
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20161005/e1f98db4/attachment-0001.html>
> End of Nek5000-users Digest, Vol 92, Issue 2
