[Nek5000-users] problem in running a case
Tue May 10 20:54:41 CDT 2016
Hi Mansi,
Is nekb in your path?  Try:
$ which nekb
If it is not, copy it from tools/scripts/nekb to your ~/bin .  You should
run the test from within the eddy directory.
Hope this helps,
Max
On Tue, May 10, 2016 at 3:33 PM <nek5000-users at lists.mcs.anl.gov> wrote:
> Hello,
> I am mansi patel and I am downloading nek5000 I was able to compile *makenek
> eddy_uv*
> but after that I am not able to run a case *nekb eddy_uv*    Do I need to
> stay in eddy directory? even if I change directory I am getting *same
> error command not found *.
> what should I do?
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160511/39b20740/attachment.html>
