[Nek5000-users] problem in running a case
Tue May 10 16:56:51 CDT 2016
You should copy ~/nek5_svn/trunk/tools/scripts/*  ~/bin
This will put nekb in your path, assuming ~/bin is in your path.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Tuesday, May 10, 2016 2:57 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] problem in running a case
Hello,
I am mansi patel and I am downloading nek5000 I was able to compile makenek eddy_uv
but after that I am not able to run a case nekb eddy_uv    Do I need to stay in eddy directory? even if I change directory I am getting same error command not found .
what should I do?
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160510/9883e029/attachment.html>
