[Nek5000-users] Nek5000-users Digest, Vol 87, Issue 1
Thu May 12 13:08:39 CDT 2016
Thanks a lot Paul and Max the answers were very helpful since I am new to Linux and coding.
From: nek5000-users-bounces at lists.mcs.anl.gov <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users-request at lists.mcs.anl.gov <nek5000-users-request at lists.mcs.anl.gov>
Sent: Wednesday, May 11, 2016 1:00 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Nek5000-users Digest, Vol 87, Issue 1
Send Nek5000-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
        https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        nek5000-users-owner at lists.mcs.anl.gov
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Nek5000-users digest..."
Today's Topics:
   1. problem in running a case (nek5000-users at lists.mcs.anl.gov)
   2. Re: problem in running a case (nek5000-users at lists.mcs.anl.gov)
   3. Re: problem in running a case (nek5000-users at lists.mcs.anl.gov)
Message: 1
Date: Tue, 10 May 2016 19:57:12 +0000
To: "nek5000-users at lists.mcs.anl.gov"
        <nek5000-users at lists.mcs.anl.gov>
Subject: [Nek5000-users] problem in running a case
Message-ID:
        <mailman.21233.1462912411.24727.nek5000-users at lists.mcs.anl.gov>
Content-Type: text/plain; charset="iso-8859-1"
Hello,
I am mansi patel and I am downloading nek5000 I was able to compile makenek eddy_uv
but after that I am not able to run a case nekb eddy_uv    Do I need to stay in eddy directory? even if I change directory I am getting same error command not found .
what should I do?
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160510/46eeaca5/attachment-0001.html>
Message: 2
Date: Tue, 10 May 2016 21:56:51 +0000
Subject: Re: [Nek5000-users] problem in running a case
Message-ID:
        <mailman.21279.1462974976.24727.nek5000-users at lists.mcs.anl.gov>
You should copy ~/nek5_svn/trunk/tools/scripts/*  ~/bin
This will put nekb in your path, assuming ~/bin is in your path.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Tuesday, May 10, 2016 2:57 PM
Hello,
what should I do?
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160510/9883e029/attachment-0001.html>
Message: 3
Date: Wed, 11 May 2016 01:54:41 +0000
Message-ID:
        <mailman.21280.1462974976.24727.nek5000-users at lists.mcs.anl.gov>
Content-Type: text/plain; charset="utf-8"
Hi Mansi,
Is nekb in your path?  Try:
$ which nekb
If it is not, copy it from tools/scripts/nekb to your ~/bin .  You should
run the test from within the eddy directory.
Hope this helps,
Max
On Tue, May 10, 2016 at 3:33 PM <nek5000-users at lists.mcs.anl.gov> wrote:
> Hello,
> I am mansi patel and I am downloading nek5000 I was able to compile *makenek
> eddy_uv*
> but after that I am not able to run a case *nekb eddy_uv*    Do I need to
> stay in eddy directory? even if I change directory I am getting *same
> error command not found *.
> what should I do?
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160511/39b20740/attachment-0001.html>
End of Nek5000-users Digest, Vol 87, Issue 1
