[Nek5000-users] linear stability tool
Tue Mar 15 03:06:51 CDT 2016
Hi
To force base flow to be constant you have to set negative param(31) in
your ###.rea file. Something like
    -1.00000     p031 NPERT: #perturbation modes
Of course you need the base flow as well. It could be analytical one set
in useric, or just a field read during initialisation.
Regards
Adam
On 2016-03-15 08:49, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Neks,
> I'm trying to use the linear stability tool of Nek5000.
> To start with, I am trying to run the ext_cyl example. However, I have
> found the following problem:
> ERROR: arnoldi assumes constant base flow.
> I have found on the README tutorial that the base flow has to be
> specified on the .rea file. I have included a file in the
> PRESOLVE/RESTART option, however I still have the same error.
> What should I modify?
> Finally, I have also used a subroutine defined in the .usr file that
> reads the file containing the base flow. However, the error persist...
> Could you help me, please?
> Cheers
> SL
> Nek5000-users mailing list
