[Nek5000-users] linear stability tool
Tue Mar 15 07:18:33 CDT 2016
Hi Adam,
thank you, it works now.
However I still have a question about this tool. My base flow is time
dependent, so I did in usrchk
call opcopy (u,v,w,vx,vy,vz)
u=u*function(time)
v=v*function(time)
w=w*function(time)
call gop(u,work,'+  ',n)
call gop(v,work,'+  ',n)
call gop(w,work,'+  ',n)
do e=1,nelv
    eg = lglel(e)
    call copy(vx(1,1,1,e),u(1,1,1,eg),nxyz)
    call copy(vy(1,1,1,e),v(1,1,1,eg),nxyz)
    call copy(vz(1,1,1,e),w(1,1,1,eg),nxyz)
enddo
However, I am not sure how to specify this velocity filed as the base
flow each time step...
Thank you in advance.
SL
El 15-03-2016 19:06, nek5000-users at lists.mcs.anl.gov escribió:
> Hi
> To force base flow to be constant you have to set negative param(31)
> in your ###.rea file. Something like
>    -1.00000     p031 NPERT: #perturbation modes
> Of course you need the base flow as well. It could be analytical one
> set in useric, or just a field read during initialisation.
> Regards
> Adam
> On 2016-03-15 08:49, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Neks,
>> I'm trying to use the linear stability tool of Nek5000.
>> To start with, I am trying to run the ext_cyl example. However, I have
>> found the following problem:
>> ERROR: arnoldi assumes constant base flow.
>> I have found on the README tutorial that the base flow has to be
>> specified on the .rea file. I have included a file in the
>> PRESOLVE/RESTART option, however I still have the same error.
>> What should I modify?
>> Finally, I have also used a subroutine defined in the .usr file that
>> reads the file containing the base flow. However, the error persist...
>> Could you help me, please?
>> Cheers
>> SL
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
