[Nek5000-users] linear stability tool
Tue Mar 15 02:49:02 CDT 2016
Hi Neks,
I'm trying to use the linear stability tool of Nek5000.
To start with, I am trying to run the ext_cyl example. However, I have
found the following problem:
ERROR: arnoldi assumes constant base flow.
I have found on the README tutorial that the base flow has to be
specified on the .rea file. I have included a file in the
PRESOLVE/RESTART option, however I still have the same error.
What should I modify?
Finally, I have also used a subroutine defined in the .usr file that
reads the file containing the base flow. However, the error persist...
Could you help me, please?
Cheers
SL
