[Nek5000-users] Periodic B.C and Genmap Issue
Thu Mar 10 08:46:43 CST 2016
Hi Paul,
It is looks like that the n2to3 not generate the 3D  mesh with periodic
boundary conditions correctly by rotating.  First I tried to generate a 3D
mesh, then after applied genmap it appears the similar error.
Following the discussions some years ago, it seems I need to update the
genmap.f,  Have you update the new version, or Would you like to post the
genmap.f again?
thanks!
Wei
n2to3
 This is the code that establishes proper
 element connectivities, as of Oct., 2006.
 Input old (source) file name:
box
 Input new (output) file name:
boxss
 For ASCII output only: 0; For .rea/.re2: 1
0
 input number of levels: (1, 2, 3,...; < 0 for circular sweep.):
-20
 input z min:
0
 input z max:
90
 input gain (0=custom,1=uniform,other=geometric spacing):
1
 This is for CEM: yes or no:
no
 Enter Z(5) FLUID boundary condition (P,v,O,ect):
P
 this is FLUID cbz: P  P   <---
 F F           0           1  ifheat,ifmhd
         360 elements written to boxss.rea
genmap
Input (.rea) file name:
boxss
Input mesh tolerance (default 0.2):
NOTE: smaller is better, but generous is more forgiving for bad meshes.
0.1
 reading .rea file data ...
 start locglob_lexico:           8         360        2880
0.10000000000000001
 locglob:           1           1        2880
 locglob:           2          59        2880
 locglob:           3          84        2880
 locglob:           1         588        2880
 locglob:           2         588        2880
 locglob:           3         588        2880
 locglob:           1         588        2880
 locglob:           2         588        2880
 locglob:           3         588        2880
 done locglob_lexico:         588         588        2880           8
 start periodic vtx:         360         588
     1     4     4  Matrix:    x0
  1   x0    1.2084E-06  1.2084E-06  1.6729E-06  1.6729E-06
  2   x0   -1.2362E-03 -1.2362E-03  1.2363E-03  1.2363E-03
  3   x0   -0.0000E+00 -0.0000E+00 -0.0000E+00 -0.0000E+00
  4   x0   -2.6465E-03  2.6465E-03  2.6465E-03 -2.6465E-03
   343     4     4  Matrix:    x1
1   x1    1.2084E-06  1.6729E-06  1.6729E-06  1.2084E-06
  2   x1    5.4038E-11 -5.4038E-11 -5.4038E-11  5.4038E-11
  3   x1    1.2362E-03 -1.2363E-03 -1.2363E-03  1.2362E-03
  4   x1   -2.6465E-03 -2.6465E-03  2.6465E-03  2.6465E-03
     1     4     4  Matrix:    z0
  1   z0    1.2084E-06  1.2084E-06  1.6729E-06  1.6729E-06
  2   z0    1.4000E-02  1.4000E-02  1.6473E-02  1.6473E-02
  3   z0   -0.0000E+00 -0.0000E+00 -0.0000E+00 -0.0000E+00
  4   z0   -1.1000E-01 -1.0471E-01 -1.0471E-01 -1.1000E-01
   343     4     4  Matrix:    z1
  1   z1    1.2084E-06  1.6729E-06  1.6729E-06  1.2084E-06
  2   z1   -6.1196E-10 -7.2004E-10 -7.2004E-10 -6.1196E-10
  3   z1   -1.4000E-02 -1.6473E-02 -1.6473E-02 -1.4000E-02
  4   z1   -1.1000E-01 -1.1000E-01 -1.0471E-01 -1.0471E-01
           1 5  3  1.00000000E-03  1.10000000E-01 abort: FACE MATCH FAIL
         343 6  5  1.10000000E-04  3.49664311E-03 abort: FACE MATCH FAIL
           0  quit
Yes, got it now. I don't know why it wasn't working either. I use the
same thing to compress files, either way it's good now. Thanks Paul.
- Michael
----- Original Message -----
<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
To: nek5000-users at lists.mcs.anl.gov
Sent: Tuesday, June 22, 2010 10:40:57 AM GMT -06:00 Guadalajara /
Mexico City / Monterrey
Subject: Re: [Nek5000-users] Periodic BC & Genmap issue
Hi Michael,
not sure why gunzip didn't work - it worked here... but I've
put the unzipped version in:
www.mcs.anl.gov/~fischer/genmap.f
Let me know if that works for you.
Cheers,
Paul
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160310/06594a49/attachment-0001.html>
