[Nek5000-users] VISIT and NEKTON
Tue Mar 1 22:07:08 CST 2016
It is very likely your mesh has a double precision output, see parameter 63
http://nek5000.github.io/NekDoc/Nek_usersch7.html#x9-690007.1
Older versions of visit do not support field files in double precision, so you should have that parameter set to anything but 8.
If this doesn't work please make sure your computation did not blow up prior to writing to file.
Oana
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Tuesday, March 01, 2016 4:57 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] VISIT and NEKTON
Can anyone help me in visualizing the data on VISIT and or NEKTON, my problem is that I am not able to visualize the data using any of these. For instance in VISIT I am able to generate .nek5000 file and was able to load it in VISIT but whenever I try to plot something it crashes. Similarly in NEKTON (POSTX), I was able to see the mesh grid , however whenever I click on the plot it makes the whole grid go blue and time remains at "0", I tried to change the time to some other value but I failed.
Please guide me what is causing this issue and what I am doing wrong. I am using linux mint to run the nek5000.
Abhinav
