[Nek5000-users] VISIT and NEKTON
Tue Mar 1 22:09:50 CST 2016
Visit is working now, there was a problem because of the version of the
visit I was using, easy solution, well thanks for your advice.
On Mar 1, 2016 10:07 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> It is very likely your mesh has a double precision output, see parameter 63
> http://nek5000.github.io/NekDoc/Nek_usersch7.html#x9-690007.1
> Older versions of visit do not support field files in double precision, so
> you should have that parameter set to anything but 8.
> If this doesn't work please make sure your computation did not blow up
> prior to writing to file.
> Oana
> From: nek5000-users-bounces at lists.mcs.anl.gov [
> nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> Sent: Tuesday, March 01, 2016 4:57 PM
> To: nek5000-users at lists.mcs.anl.gov
> Subject: [Nek5000-users] VISIT and NEKTON
> Can anyone help me in visualizing the data on VISIT and or NEKTON, my
> problem is that I am not able to visualize the data using any of these. For
> instance in VISIT I am able to generate .nek5000 file and was able to load
> it in VISIT but whenever I try to plot something it crashes. Similarly in
> NEKTON (POSTX), I was able to see the mesh grid , however whenever I click
> on the plot it makes the whole grid go blue and time remains at "0", I
> tried to change the time to some other value but I failed.
> Please guide me what is causing this issue and what I am doing wrong. I am
> using linux mint to run the nek5000.
> Thanks,
> Abhinav
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160301/0d6daaf9/attachment.html>
