[Nek5000-users] Restarting with PNPN using PNPN-2 results
Wed Jun 15 22:22:52 CDT 2016
Philipp,
I am investigating a switch for two reasons:
1) to see how it affects my results.  This is why I want to converge
pressure right away before performing more timesteps. I will be running
several more simulations that are similar to this one, and I am interested
in how PNPN will perform for the same flow.  I have already put in a
significant amount of compute time into my current case and so I don't want
to start it over to perform this simple investigation.
2) I have an additional interest in post processing and analyzing the
pressure fluctuation field. Using PNPN over PNPN-2 makes sense in this case
since the pressure field is better resolved and enforces C0 continuity
across element boundaries.
Phil
On Wed, Jun 15, 2016 at 11:00 AM, <nek5000-users-request at lists.mcs.anl.gov>
wrote:
> Send Nek5000-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         nek5000-users-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Nek5000-users digest..."
> Today's Topics:
>    1. Re: Restarting with PNPN using PNPN-2 results
>       (nek5000-users at lists.mcs.anl.gov)
> Message: 1
> Date: Wed, 15 Jun 2016 10:44:04 +0200
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Restarting with PNPN using PNPN-2 results
> Message-ID:
>         <mailman.23825.1465980259.24727.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset=windows-1252; format=flowed
> Hi,
> I guess the question is whether there is a similar type of Uzawa
> iteration also for Pnpn, this I don't know and I have not looked into
> the theory. I can only say that for PnPn-2, with the nested iterations
> you can get a perfect pressure (i.e. not proportional to Delta p) in one
> time step. I guess one needs a PnPn user to answer that question.
> Just as a side question; why do you want to go from PnPn-2 to PnPn? Out
> of curiosity...
> Best regards,
> PHilipp
> On 2016-06-15 00:44, nek5000-users at lists.mcs.anl.gov wrote:
> > Philipp and Aleks,
> > Thanks for the replies.  The Uzawa method sounds exactly like what I am
> > looking for.  I would like to pay a penalty upfront to converge to a
> > good pressure solution without taking too many (or really any) timesteps
> > and then move forward with a resolved pressure solution.  I am hoping
> > there is a way to do this since a pressure projection method is being
> used.
> > My solution is already well resolved temporally and I don't want to
> > perturbe it with a long time series of unresolved pressure
> > fields/slightly divergent velocity fields. Can anyone comment on the use
> > of Uzawa with PNPN?  Also, Philipp is there a specific routine you call
> > to perform just one of these iterations?  I haven't used this method
> before.
> > Kind regards,
> > Phil
> > On Tue, Jun 14, 2016 at 11:00 AM,
> >     <mailto:nek5000-users at lists.mcs.anl.gov>
> >     <mailto:nek5000-users-owner at lists.mcs.anl.gov>
> >     Today's Topics:
> >        1. Restarting with PNPN using PNPN-2 results
> >     <mailto:nek5000-users at lists.mcs.anl.gov>)
> >        2. Re: Restarting with PNPN using PNPN-2 results
> >        3. Re: Restarting with PNPN using PNPN-2 results
> >        4. Re: lambda2 in turbChannel (nek5000-users at lists.mcs.anl.gov
> >        5. g2gi() no geometry found (nek5000-users at lists.mcs.anl.gov
> >        6. Re: g2gi() no geometry found (nek5000-users at lists.mcs.anl.gov
> >     Message: 1
> >     Date: Mon, 13 Jun 2016 13:09:05 -0600
> >     Subject: [Nek5000-users] Restarting with PNPN using PNPN-2 results
> >     Message-ID:
> >     <mailman.23731.1465844987.24727.nek5000-users at lists.mcs.anl.gov
> >     <mailto:
> mailman.23731.1465844987.24727.nek5000-users at lists.mcs.anl.gov>>
> >     Content-Type: text/plain; charset="utf-8"
> >     Hello neks,
> >     I have a DNS simulation that I was running as PNPN-2 and I would
> like to
> >     run it as PNPN without starting back at the initial conditions.
> >     I am curious if anyone has experience running a PNPN case with
> initial
> >     conditions from a PNPN-2 simulation?  I have tried this and the
> >     simulation
> >     runs okay, except the pressure term never seems to converge when
> running
> >     the PNPN simulation.  This dramatically increases runtime and makes
> the
> >     results questionable.  It seems to me that restarting with PNPN-2
> >     results
> >     should be doable, and that it should only take a few iterations for
> the
> >     pressure term to start converging.  However, my simulation is still
> not
> >     converging after 100+ iterations, but it was converging fine when I
> was
> >     running PNPN-2.
> >     Any suggestions for things I should look for that might cause the
> >     problem,
> >     or potential fixes?
> >     Thanks
> >     Phil Sakievich
> >     PhD Candidate - Mechanical Engineering
> >     Arizona State University - Ira A. Fulton School for Engineering of
> >     Matter
> >     Transport and Energy
> >     Tempe, Arizona
> >     -------------- next part --------------
> >     An HTML attachment was scrubbed...
> >     URL:
> http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160613/790d807b/attachment-0001.html
> >     Message: 2
> >     Date: Mon, 13 Jun 2016 19:15:32 +0000
> >     To: "nek5000-users at lists.mcs.anl.gov
> >     <mailto:nek5000-users at lists.mcs.anl.gov>"
> >             <nek5000-users at lists.mcs.anl.gov
> >     <mailto:nek5000-users at lists.mcs.anl.gov>>
> results
> >     Message-ID:
> >     <mailman.23735.1465845499.24727.nek5000-users at lists.mcs.anl.gov
> >     <mailto:
> mailman.23735.1465845499.24727.nek5000-users at lists.mcs.anl.gov>>
> >     Content-Type: text/plain; charset="iso-8859-1"
> >     Hi Phil,
> >     The regularity of the pressure field is much larger for Pn-Pn as
> >     compared to Pn-Pn-2 so it should take some time to readjust to the
> >     larger resolution.
> >     Aleks
> >     ________________________________
> >     From: nek5000-users-bounces at lists.mcs.anl.gov
> >     <mailto:nek5000-users-bounces at lists.mcs.anl.gov>
> >     [nek5000-users-bounces at lists.mcs.anl.gov
> >     <mailto:nek5000-users-bounces at lists.mcs.anl.gov>] on behalf of
> >     [nek5000-users at lists.mcs.anl.gov
> >     <mailto:nek5000-users at lists.mcs.anl.gov>]
> >     Sent: Monday, June 13, 2016 2:09 PM
> >     Hello neks,
> >     like to run it as PNPN without starting back at the initial
> conditions.
> >     initial conditions from a PNPN-2 simulation?  I have tried this and
> >     the simulation runs okay, except the pressure term never seems to
> >     converge when running the PNPN simulation.  This dramatically
> >     increases runtime and makes the results questionable.  It seems to
> >     me that restarting with PNPN-2 results should be doable, and that it
> >     should only take a few iterations for the pressure term to start
> >     converging.  However, my simulation is still not converging after
> >     100+ iterations, but it was converging fine when I was running
> PNPN-2.
> >     problem, or potential fixes?
> >     Thanks
> >     Phil Sakievich
> >     Matter Transport and Energy
> >     Tempe, Arizona
> >     URL:
> http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160613/09bbb78b/attachment-0001.html
> >     Message: 3
> >     Date: Mon, 13 Jun 2016 21:31:08 +0200
> results
> >     Message-ID:
> >     <mailman.23743.1465847039.24727.nek5000-users at lists.mcs.anl.gov
> >     <mailto:
> mailman.23743.1465847039.24727.nek5000-users at lists.mcs.anl.gov>>
> >     Hi,
> >     In principle, you can do a Navier-Stokes restart without pressure
> field.
> >     For PnPn-2 you can for instance do one step with Uzawa (nested
> >     iterations) to have a good pressure. So usually, when we do a
> restart of
> >     a solution wi
> >     thout pressure (e.g. when doing Arnoldi or Newton) then one Uzawa
> step
> >     fixes everything. I am not too familiar with PnPn, but I guess that
> >     there is a flavour that is not dependent on a previous pressure
> >     solution. Perhaps a PnPn-expert has some opinion on a Uzawa-like
> method?
> >     Best regards,
> >     Philipp
> >     On 2016-06-13 21:15, nek5000-users at lists.mcs.anl.gov
> >     <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
> >     > Hi Phil,
> >     > larger resolution.
> >     > Aleks
> >     > *From:* nek5000-users-bounces at lists.mcs.anl.gov
> >     > *Sent:* Monday, June 13, 2016 2:09 PM
> >     > *To:* nek5000-users at lists.mcs.anl.gov
> >     > *Subject:* [Nek5000-users] Restarting with PNPN using PNPN-2
> results
> >     > Hello neks,
> >     like to
> initial
> converge
> >     > when running the PNPN simulation.  This dramatically increases
> runtime
> >     > and makes the results questionable.  It seems to me that
> >     restarting with
> >     > PNPN-2 results should be doable, and that it should only take a few
> >     > iterations for the pressure term to start converging.  However, my
> >     > simulation is still not converging after 100+ iterations, but it
> was
> >     > converging fine when I was running PNPN-2.
> >     > Thanks
> >     > Phil Sakievich
> >     > Tempe, Arizona
> >     > _______________________________________________
> >     > Nek5000-users at lists.mcs.anl.gov
> >     <mailto:Nek5000-users at lists.mcs.anl.gov>
> >     Message: 4
> >     Date: Mon, 13 Jun 2016 16:11:14 -0700
> >     Subject: Re: [Nek5000-users] lambda2 in turbChannel
> >     Message-ID:
> >     <mailman.23757.1465860244.24727.nek5000-users at lists.mcs.anl.gov
> >     <mailto:
> mailman.23757.1465860244.24727.nek5000-users at lists.mcs.anl.gov>>
> >     Hi Wei,
> >     I do not think so. But you can definitely, modify the lambda2()
> >     routine to
> >     generate the Q criterion. It is quite straightforward.
> >     URL:
> http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160613/40eedaf9/attachment-0001.html
> >     Message: 5
> >     Date: Tue, 14 Jun 2016 11:21:16 +0200
> >     Subject: [Nek5000-users] g2gi() no geometry found
> >     Message-ID:
> >     <mailman.23773.1465903728.24727.nek5000-users at lists.mcs.anl.gov
> >     <mailto:
> mailman.23773.1465903728.24727.nek5000-users at lists.mcs.anl.gov>>
> >     Content-Type: text/plain; charset=ISO-8859-1; DelSp="Yes";
> >             format="flowed"
> >     Hello Neks,
> >     I am trying to use the g2gi subroutine, but keep getting the error
> >     massage ABORT: No geometry found in:
> >       call userchk
> >       grid-to-grid interpolation
> >       140   8   8   8 2.0010000E+03 4002 U P
>  4
> >     NELT,NX,N ?a?@
> >                                       NONSTD HDR, parse_hdr, abort.
> >       ABORT: No geometry found in newgeom.fld
> >     call exitt: dying ...
> >     Anybody familiar with this error? Do I give him the wrong files? I
> >     assumed Nek wants a .fld. Any help or working case as an example
> would
> >     be highly appreciated.
> >     Br
> >     Michael
> >     e1429308 at student.tuwien.ac.at <mailto:e1429308 at student.tuwien.ac.at>
> >     Message: 6
> >     Date: Tue, 14 Jun 2016 11:40:05 +0000
> >     Subject: Re: [Nek5000-users] g2gi() no geometry found
> >     Message-ID:
> >     <mailman.23774.1465904407.24727.nek5000-users at lists.mcs.anl.gov
> >     <mailto:
> mailman.23774.1465904407.24727.nek5000-users at lists.mcs.anl.gov>>
> >     Content-Type: text/plain; charset="us-ascii"
> >     Hi Michael,
> >     You need to compile with the ifmpiio flag set in makenek:
> >     # (set PPLIST=? to get a list of available symbols)
> >     PPLIST="MPIIO"
> >     All files should be .f00000 files, which is the current default.
> >     (Make certain that your
> >     current .usr file does not reset param(66) to 4.)   [ You can
> >     convert a .fld file to a .f0000
> >     file by running a 0 step, 0 FINTIME job and setting p66=6, p67=4 in
> >     the .usr file, say, in
> >     subroutine usrdat(). ]
> >     When running g2gi, make certain that the new file has the geometry
> >     in it.   The old file does not need the
> >     geometry, only the data to be interpolated.
> >     hth
> >     Paul
> >     Sent: Tuesday, June 14, 2016 4:21 AM
> >     Hello Neks,
> >       call userchk
>  4
> >     NELT,NX,N ?a?@
> would
> >     Br
> >     Michael
> >     Nek5000-users at lists.mcs.anl.gov <mailto:
> >     End of Nek5000-users Digest, Vol 88, Issue 13
> > Phil Sakievich
> > Tempe, Arizona
> End of Nek5000-users Digest, Vol 88, Issue 15
Phil Sakievich
Arizona State University - Ira A. Fulton School for Engineering of Matter
Tempe, Arizona
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160615/01545ef9/attachment-0001.html>
