[Nek5000-users] Restarting with PNPN using PNPN-2 results
Wed Jun 15 03:44:04 CDT 2016
I guess the question is whether there is a similar type of Uzawa
iteration also for Pnpn, this I don't know and I have not looked into
the theory. I can only say that for PnPn-2, with the nested iterations
you can get a perfect pressure (i.e. not proportional to Delta p) in one
time step. I guess one needs a PnPn user to answer that question.
Just as a side question; why do you want to go from PnPn-2 to PnPn? Out
of curiosity...
Best regards,
PHilipp
On 2016-06-15 00:44, nek5000-users at lists.mcs.anl.gov wrote:
> Philipp and Aleks,
> Thanks for the replies.  The Uzawa method sounds exactly like what I am
> looking for.  I would like to pay a penalty upfront to converge to a
> good pressure solution without taking too many (or really any) timesteps
> and then move forward with a resolved pressure solution.  I am hoping
> there is a way to do this since a pressure projection method is being used.
> My solution is already well resolved temporally and I don't want to
> perturbe it with a long time series of unresolved pressure
> fields/slightly divergent velocity fields. Can anyone comment on the use
> of Uzawa with PNPN?  Also, Philipp is there a specific routine you call
> to perform just one of these iterations?  I haven't used this method before.
> Kind regards,
> Phil
> On Tue, Jun 14, 2016 at 11:00 AM,
> <nek5000-users-request at lists.mcs.anl.gov
> <mailto:nek5000-users-request at lists.mcs.anl.gov>> wrote:
>     Send Nek5000-users mailing list submissions to
>     <mailto:nek5000-users at lists.mcs.anl.gov>
>     To subscribe or unsubscribe via the World Wide Web, visit
>             https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>     or, via email, send a message with subject or body 'help' to
>     You can reach the person managing the list at
>             nek5000-users-owner at lists.mcs.anl.gov
>     <mailto:nek5000-users-owner at lists.mcs.anl.gov>
>     When replying, please edit your Subject line so it is more specific
>     than "Re: Contents of Nek5000-users digest..."
>     Today's Topics:
>        1. Restarting with PNPN using PNPN-2 results
>           (nek5000-users at lists.mcs.anl.gov
>     <mailto:nek5000-users at lists.mcs.anl.gov>)
>        2. Re: Restarting with PNPN using PNPN-2 results
>        3. Re: Restarting with PNPN using PNPN-2 results
>        4. Re: lambda2 in turbChannel (nek5000-users at lists.mcs.anl.gov
>        5. g2gi() no geometry found (nek5000-users at lists.mcs.anl.gov
>        6. Re: g2gi() no geometry found (nek5000-users at lists.mcs.anl.gov
>     Message: 1
>     Date: Mon, 13 Jun 2016 13:09:05 -0600
>     From: nek5000-users at lists.mcs.anl.gov
>     To: nek5000-users at lists.mcs.anl.gov
>     Subject: [Nek5000-users] Restarting with PNPN using PNPN-2 results
>     Message-ID:
>     <mailman.23731.1465844987.24727.nek5000-users at lists.mcs.anl.gov
>     <mailto:mailman.23731.1465844987.24727.nek5000-users at lists.mcs.anl.gov>>
>     Content-Type: text/plain; charset="utf-8"
>     Hello neks,
>     I have a DNS simulation that I was running as PNPN-2 and I would like to
>     run it as PNPN without starting back at the initial conditions.
>     I am curious if anyone has experience running a PNPN case with initial
>     conditions from a PNPN-2 simulation?  I have tried this and the
>     simulation
>     runs okay, except the pressure term never seems to converge when running
>     the PNPN simulation.  This dramatically increases runtime and makes the
>     results questionable.  It seems to me that restarting with PNPN-2
>     results
>     should be doable, and that it should only take a few iterations for the
>     pressure term to start converging.  However, my simulation is still not
>     converging after 100+ iterations, but it was converging fine when I was
>     running PNPN-2.
>     Any suggestions for things I should look for that might cause the
>     problem,
>     or potential fixes?
>     Thanks
>     Phil Sakievich
>     PhD Candidate - Mechanical Engineering
>     Arizona State University - Ira A. Fulton School for Engineering of
>     Matter
>     Transport and Energy
>     Tempe, Arizona
>     -------------- next part --------------
>     An HTML attachment was scrubbed...
>     URL:
>     <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160613/790d807b/attachment-0001.html>
>     Message: 2
>     Date: Mon, 13 Jun 2016 19:15:32 +0000
>     To: "nek5000-users at lists.mcs.anl.gov
>     <mailto:nek5000-users at lists.mcs.anl.gov>"
>             <nek5000-users at lists.mcs.anl.gov
>     <mailto:nek5000-users at lists.mcs.anl.gov>>
>     Subject: Re: [Nek5000-users] Restarting with PNPN using PNPN-2 results
>     Message-ID:
>     <mailman.23735.1465845499.24727.nek5000-users at lists.mcs.anl.gov
>     <mailto:mailman.23735.1465845499.24727.nek5000-users at lists.mcs.anl.gov>>
>     Content-Type: text/plain; charset="iso-8859-1"
>     Hi Phil,
>     The regularity of the pressure field is much larger for Pn-Pn as
>     compared to Pn-Pn-2 so it should take some time to readjust to the
>     larger resolution.
>     Aleks
>     ________________________________
>     From: nek5000-users-bounces at lists.mcs.anl.gov
>     <mailto:nek5000-users-bounces at lists.mcs.anl.gov>
>     [nek5000-users-bounces at lists.mcs.anl.gov
>     <mailto:nek5000-users-bounces at lists.mcs.anl.gov>] on behalf of
>     [nek5000-users at lists.mcs.anl.gov
>     <mailto:nek5000-users at lists.mcs.anl.gov>]
>     Sent: Monday, June 13, 2016 2:09 PM
>     Hello neks,
>     like to run it as PNPN without starting back at the initial conditions.
>     initial conditions from a PNPN-2 simulation?  I have tried this and
>     the simulation runs okay, except the pressure term never seems to
>     converge when running the PNPN simulation.  This dramatically
>     increases runtime and makes the results questionable.  It seems to
>     me that restarting with PNPN-2 results should be doable, and that it
>     should only take a few iterations for the pressure term to start
>     converging.  However, my simulation is still not converging after
>     100+ iterations, but it was converging fine when I was running PNPN-2.
>     problem, or potential fixes?
>     Thanks
>     Phil Sakievich
>     Matter Transport and Energy
>     Tempe, Arizona
>     URL:
>     <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160613/09bbb78b/attachment-0001.html>
>     Message: 3
>     Date: Mon, 13 Jun 2016 21:31:08 +0200
>     Message-ID:
>     <mailman.23743.1465847039.24727.nek5000-users at lists.mcs.anl.gov
>     <mailto:mailman.23743.1465847039.24727.nek5000-users at lists.mcs.anl.gov>>
>     Content-Type: text/plain; charset=windows-1252; format=flowed
>     Hi,
>     In principle, you can do a Navier-Stokes restart without pressure field.
>     For PnPn-2 you can for instance do one step with Uzawa (nested
>     iterations) to have a good pressure. So usually, when we do a restart of
>     a solution wi
>     thout pressure (e.g. when doing Arnoldi or Newton) then one Uzawa step
>     fixes everything. I am not too familiar with PnPn, but I guess that
>     there is a flavour that is not dependent on a previous pressure
>     solution. Perhaps a PnPn-expert has some opinion on a Uzawa-like method?
>     Best regards,
>     Philipp
>     On 2016-06-13 21:15, nek5000-users at lists.mcs.anl.gov
>     <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>     > Hi Phil,
>     > larger resolution.
>     > Aleks
>     > *From:* nek5000-users-bounces at lists.mcs.anl.gov
>     > *Sent:* Monday, June 13, 2016 2:09 PM
>     > *To:* nek5000-users at lists.mcs.anl.gov
>     > *Subject:* [Nek5000-users] Restarting with PNPN using PNPN-2 results
>     > Hello neks,
>     like to
>     > simulation runs okay, except the pressure term never seems to converge
>     > when running the PNPN simulation.  This dramatically increases runtime
>     > and makes the results questionable.  It seems to me that
>     restarting with
>     > PNPN-2 results should be doable, and that it should only take a few
>     > iterations for the pressure term to start converging.  However, my
>     > simulation is still not converging after 100+ iterations, but it was
>     > Thanks
>     > Phil Sakievich
>     > Tempe, Arizona
>     > _______________________________________________
>     > Nek5000-users at lists.mcs.anl.gov
>     <mailto:Nek5000-users at lists.mcs.anl.gov>
>     Message: 4
>     Date: Mon, 13 Jun 2016 16:11:14 -0700
>     Subject: Re: [Nek5000-users] lambda2 in turbChannel
>     Message-ID:
>     <mailman.23757.1465860244.24727.nek5000-users at lists.mcs.anl.gov
>     <mailto:mailman.23757.1465860244.24727.nek5000-users at lists.mcs.anl.gov>>
>     Hi Wei,
>     I do not think so. But you can definitely, modify the lambda2()
>     routine to
>     generate the Q criterion. It is quite straightforward.
>     URL:
>     <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20160613/40eedaf9/attachment-0001.html>
>     Message: 5
>     Date: Tue, 14 Jun 2016 11:21:16 +0200
>     Subject: [Nek5000-users] g2gi() no geometry found
>     Message-ID:
>     <mailman.23773.1465903728.24727.nek5000-users at lists.mcs.anl.gov
>     <mailto:mailman.23773.1465903728.24727.nek5000-users at lists.mcs.anl.gov>>
>     Content-Type: text/plain; charset=ISO-8859-1; DelSp="Yes";
>             format="flowed"
>     Hello Neks,
>     I am trying to use the g2gi subroutine, but keep getting the error
>     massage ABORT: No geometry found in:
>       call userchk
>       grid-to-grid interpolation
>       140   8   8   8 2.0010000E+03 4002 U P                             4
>     NELT,NX,N ?a?@
>                                       NONSTD HDR, parse_hdr, abort.
>       ABORT: No geometry found in newgeom.fld
>     call exitt: dying ...
>     Anybody familiar with this error? Do I give him the wrong files? I
>     assumed Nek wants a .fld. Any help or working case as an example would
>     be highly appreciated.
>     Br
>     Michael
>     e1429308 at student.tuwien.ac.at <mailto:e1429308 at student.tuwien.ac.at>
>     Message: 6
>     Date: Tue, 14 Jun 2016 11:40:05 +0000
>     Subject: Re: [Nek5000-users] g2gi() no geometry found
>     Message-ID:
>     <mailman.23774.1465904407.24727.nek5000-users at lists.mcs.anl.gov
>     <mailto:mailman.23774.1465904407.24727.nek5000-users at lists.mcs.anl.gov>>
>     Content-Type: text/plain; charset="us-ascii"
>     Hi Michael,
>     You need to compile with the ifmpiio flag set in makenek:
>     # (set PPLIST=? to get a list of available symbols)
>     PPLIST="MPIIO"
>     All files should be .f00000 files, which is the current default.
>     (Make certain that your
>     current .usr file does not reset param(66) to 4.)   [ You can
>     convert a .fld file to a .f0000
>     file by running a 0 step, 0 FINTIME job and setting p66=6, p67=4 in
>     the .usr file, say, in
>     subroutine usrdat(). ]
>     When running g2gi, make certain that the new file has the geometry
>     in it.   The old file does not need the
>     geometry, only the data to be interpolated.
>     hth
>     Paul
>     Sent: Tuesday, June 14, 2016 4:21 AM
>     Hello Neks,
>       call userchk
>     NELT,NX,N ?a?@
>     Br
>     Michael
>     Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
>     End of Nek5000-users Digest, Vol 88, Issue 13
> Phil Sakievich
> Tempe, Arizona
