[Nek5000-users] Compiling with MOAB - no implicit type
Thu Jul 28 03:09:51 CDT 2016
Hi Vijay
Thanks, adding UPARAM  takes care of the implicit variables :)
In the moab example the SIZE file gives too large partiions - setting
lelt=1374, lpp=4 and lelg=5496 takes care of that and makes it runnable
Per
Quoting nek5000-users at lists.mcs.anl.gov:
> Temporarily, can you try cherry-picking d0ef99a from my fork [1] ? Let
> me know if that solves the compiler errors. If not, please send the
> error messages so that we can fix any other pending issues.
> Vijay
> [1] https://github.com/vijaysm/Nek5000.git
> On Wed, Jul 27, 2016 at 2:40 PM, Vijay S. Mahadevan
> <vijay.m at gmail.com> wrote:
>>> Implicit none is used extensively in the subroutines in moab.f but it seems
>>> that a  lot of the variables in the include files are declared
>>> implicit so I
>>> get compile error no implicit type…
>> Yes, it was originally written this way to make sure the right
>> variables are being set across various calls to moab.f. However, since
>> the bulk of the code has been verified, we could potentially remove
>> the "implicit none" statements and have it working cleanly.
>> I also have a fix for adding the variable to NEKMOAB to remove the
>> compiler error. However this is in a separate fork and I can submit a
>> PR with the change. Ron, can you take a look at this if you have some
>> time now ?
>>> If implicit none is removed then it compiles… I have a feeling I am missing
>>> something, is there a compiler setting that should be set? (gnu compiler on
>>> ubuntu 14.04)
>> The behavior is compiler independent. There is a bit of rearrangement
>> going on with the move to Git and we are trying to come up with a
>> clean process to push future changes to this interface seamlessly.
>> With Github thankfully, this should be quite easy.
>> Vijay
>> On Wed, Jul 27, 2016 at 10:38 AM,  <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi
>>> How is Nek compiled with MOAB? (I’m a newbie on NEK)
>>> implicit so I
>>> ubuntu 14.04)
>>> Best regards,
>>> Per
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
