[Nek5000-users] Compiling with MOAB - no implicit type
Wed Jul 27 14:46:26 CDT 2016
Temporarily, can you try cherry-picking d0ef99a from my fork [1] ? Let
me know if that solves the compiler errors. If not, please send the
error messages so that we can fix any other pending issues.
Vijay
[1] https://github.com/vijaysm/Nek5000.git
On Wed, Jul 27, 2016 at 2:40 PM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
>> Implicit none is used extensively in the subroutines in moab.f but it seems
>> that a  lot of the variables in the include files are declared implicit so I
>> get compile error no implicit type…
> Yes, it was originally written this way to make sure the right
> variables are being set across various calls to moab.f. However, since
> the bulk of the code has been verified, we could potentially remove
> the "implicit none" statements and have it working cleanly.
> I also have a fix for adding the variable to NEKMOAB to remove the
> compiler error. However this is in a separate fork and I can submit a
> PR with the change. Ron, can you take a look at this if you have some
> time now ?
>> If implicit none is removed then it compiles… I have a feeling I am missing
>> something, is there a compiler setting that should be set? (gnu compiler on
>> ubuntu 14.04)
> The behavior is compiler independent. There is a bit of rearrangement
> going on with the move to Git and we are trying to come up with a
> clean process to push future changes to this interface seamlessly.
> With Github thankfully, this should be quite easy.
> Vijay
> On Wed, Jul 27, 2016 at 10:38 AM,  <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi
>> How is Nek compiled with MOAB? (I’m a newbie on NEK)
>> ubuntu 14.04)
>> Best regards,
>> Per
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
