[Nek5000-users] Compiling with MOAB - no implicit type
Fri Jul 29 12:12:03 CDT 2016
Hi Vijay
When modifying the turbChannel example with with the the parameters
defined in SIZE gives no implicit type error
After commenting the implicit none and adding userq2 then it compiles
But the following error comes when I try to run it
|      _   __ ______ __ __  ______  ____    ____    ____   |
|     / | / // ____// //_/ / ____/ / __ \\ / __ \\ / __ \\ |
|    /  |/ // __/  / ,<   /___ \\  / / / // / / // / / /   |
|   / /|  // /___ / /| | ____/ / / /_/ // /_/ // /_/ /     |
|  /_/ |_//_____//_/ |_|/_____/  \\____/ \\____/ \\____/   |
| NEK5000:  Open Source Spectral Element Solver            |
| COPYRIGHT (c) 2008-2010 UCHICAGO ARGONNE, LLC            |
| Version:  1.0rc1 / SVN  r1115                            |
| Web:      http://nek5000.mcs.anl.gov                     |
  Number of processors:           8
  REAL    wdsize      :           8
  INTEGER wdsize      :           4
  Timer accuracy      : 9.54E-08
  Reading /home/per/nekwork/turbChannelCube/turbChannel.rea
At line 86 of file /home/per/nek5000/core/connect2.f (unit = 9, file =
'/home/per/nekwork/turbChannelCube/turbChannel.rea')
Fortran runtime error: Bad integer for item 1 in list input
Best regards,
Per
Quoting nek5000-users at lists.mcs.anl.gov:
> Temporarily, can you try cherry-picking d0ef99a from my fork [1] ? Let
> me know if that solves the compiler errors. If not, please send the
> error messages so that we can fix any other pending issues.
> Vijay
> [1] https://github.com/vijaysm/Nek5000.git
> On Wed, Jul 27, 2016 at 2:40 PM, Vijay S. Mahadevan
> <vijay.m at gmail.com> wrote:
>>> Implicit none is used extensively in the subroutines in moab.f but it seems
>>> that a  lot of the variables in the include files are declared
>>> implicit so I
>>> get compile error no implicit type…
>> Yes, it was originally written this way to make sure the right
>> variables are being set across various calls to moab.f. However, since
>> the bulk of the code has been verified, we could potentially remove
>> the "implicit none" statements and have it working cleanly.
>> I also have a fix for adding the variable to NEKMOAB to remove the
>> compiler error. However this is in a separate fork and I can submit a
>> PR with the change. Ron, can you take a look at this if you have some
>> time now ?
>>> If implicit none is removed then it compiles… I have a feeling I am missing
>>> something, is there a compiler setting that should be set? (gnu compiler on
>>> ubuntu 14.04)
>> The behavior is compiler independent. There is a bit of rearrangement
>> going on with the move to Git and we are trying to come up with a
>> clean process to push future changes to this interface seamlessly.
>> With Github thankfully, this should be quite easy.
>> Vijay
>> On Wed, Jul 27, 2016 at 10:38 AM,  <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi
>>> How is Nek compiled with MOAB? (I’m a newbie on NEK)
>>> implicit so I
>>> ubuntu 14.04)
>>> Best regards,
>>> Per
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Venlig hilsen
Per Jørgen Jørgensen
Tlf: +45 26 22 31 06
Vind-vind ApS
Langelandsvej 43, st.
DK-2000 Frederiksberg
