[Nek5000-users] mesh problem
Fri Nov 27 18:40:22 CST 2015
Dear Neks,
I'm trying to simulate the flow on a curved wall with leading edge. My mesh is 130,000 elements and was generated using gambit, then converted using the matlab code Gambittonek. I successfully generated the mesh with genmap (no error or warning), and the calculation is running, however I have discontinuities in my mesh (see attached file). It seems quite independant of reynolds number and element order (checked). Do you have any idea ? I feel like it can come from the partitionning and/or element connectivity, but I can't solve my problem yet. I use around 1300 elements per cpu.
Thanks !
Antoine
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151128/58a7989d/attachment-0001.png>
