[Nek5000-users] Nek5000-users Digest, Vol 81, Issue 24
Sat Nov 28 03:13:00 CST 2015
Hi Philipp,
Thanks for the input. Is there a way to make the whole computational domain
rotate?
Rif
On Fri, Nov 27, 2015 at 2:00 AM, <nek5000-users-request at lists.mcs.anl.gov>
wrote:
> Send Nek5000-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         nek5000-users-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Nek5000-users digest..."
> Today's Topics:
>    1. Rotational velocity (nek5000-users at lists.mcs.anl.gov)
>    2. Re: Rotational velocity (nek5000-users at lists.mcs.anl.gov)
> Message: 1
> Date: Thu, 26 Nov 2015 10:53:53 +0800
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Subject: [Nek5000-users] Rotational velocity
> Message-ID:
>         <mailman.11183.1448506454.24727.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset="utf-8"
> Hi neks,
> Is there a way to specify rotation on a body without mesh deformation? A
> follow up question to that is..suppose I specify an Omega a value. Omega is
> rotational velocity. How does nek know that this is rotational and not
> translational?
> Rif
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151126/90f0dfbd/attachment-0001.html
> Message: 2
> Date: Thu, 26 Nov 2015 14:19:23 +0100
> Subject: Re: [Nek5000-users] Rotational velocity
> Message-ID:
>         <mailman.11191.1448543996.24727.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset=windows-1252; format=flowed
> Hi,
> if you would like to add Coriolis (and centrifugal) acceleration terms
> then these can easily be put into userf as body forces. If you use a
> param-value from the rea file, then the amount of rotation can be set at
> runtime.
> If on the other hand you would like to specify a rotating body, then I
> guess you could use the boundary conditions (userbc) on the body to
> impose this rotation.
> Best regards,
> Philipp
> On 2015-11-26 03:53, nek5000-users at lists.mcs.anl.gov wrote:
> > Hi neks,
> > is rotational velocity. How does nek know that this is rotational and
> > not translational?
> > Rif
> > _______________________________________________
> > Nek5000-users at lists.mcs.anl.gov
> End of Nek5000-users Digest, Vol 81, Issue 24
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151128/d3f73b39/attachment.html>
