[Nek5000-users] Metadata files
Sun Mar 15 13:25:09 CDT 2015
you need to install tcsh on your system because the visnek script is
written for tcsh.
Just do (on a Ubuntu system):
 > sudo apt-get install tcsh
and it should work.
Philipp
On 2015-03-15 19:18, nek5000-users at lists.mcs.anl.gov wrote:
> Yes, that makes sense, but I get the error "bash: ./visnek: /bin/tcsh:
> bad interpreter: No such file or directory". Does this mean I'm missing
> a file in my bin folder?
> On Mar 14, 2015 10:42 PM, <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>     Hi David,
>     I guess your question was in fact simpler, you just need run visnek
>     from scripts and this would create a file *.nek5000 which is
>     readable in visit. You could also write out files using the outpost
>     command in case you have some special fields to visualize (thus
>     outposting, sorry for inventing a new word).
>     Oana
>     *From:* nek5000-users-bounces at lists.mcs.anl.gov
>     <mailto:nek5000-users-bounces at lists.mcs.anl.gov>
>     [nek5000-users-bounces at lists.mcs.anl.gov
>     <mailto:nek5000-users-bounces at lists.mcs.anl.gov>] on behalf of
>     [nek5000-users at lists.mcs.anl.gov
>     <mailto:nek5000-users at lists.mcs.anl.gov>]
>     *Sent:* Saturday, March 14, 2015 9:20 PM
>     *To:* Nek Mailing List
>     *Subject:* Re: [Nek5000-users] Metadata files
>     Thanks for your help, but I'm not sure I understand. What do you
>     mean by out posting the files?
>     On Mar 1, 2015 10:48 AM, <nek5000-users at lists.mcs.anl.gov
>         Hi David,
>         Which files are you referring to? Your own output files or nek
>         outpost generated ones? The easiest would be to just make a call
>         to outpost and overwrite the velocity fields and pressure, and
>         use a different name than your current SESSION, instead of
>         writing out your own data file.
>         In this way you can still use the script 'visnek' to create a
>         Visit readable file (the format visit has for nek is .nek5000
>         which looks very simple to tweak if needed).
>         Hope I understood your problem correctly,
>         Oana
>         *Sent:* Sunday, March 01, 2015 9:32 AM
>         *Subject:* [Nek5000-users] Metadata files
>         Hi all,
>         Would someone be able to help me create a Metadata file, so I
>         can upload my results into VisIt? I'm under the impression that
>         you have to create a new file, is that correct? Thanks.
>         David H.
>         _______________________________________________
>         Nek5000-users mailing list
>         Nek5000-users at lists.mcs.anl.gov
>         <mailto:Nek5000-users at lists.mcs.anl.gov>
>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>     Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
