[Nek5000-users] Metadata files
Sun Mar 15 13:18:28 CDT 2015
Yes, that makes sense, but I get the error "bash: ./visnek: /bin/tcsh: bad
interpreter: No such file or directory". Does this mean I'm missing a file
in my bin folder?
On Mar 14, 2015 10:42 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>  Hi David,
> I guess your question was in fact simpler, you just need run visnek from
> scripts and this would create a file *.nek5000 which is readable in visit.
> You could also write out files using the outpost command in case you have
> some special fields to visualize (thus outposting, sorry for inventing a
> new word).
> Oana
> *From:* nek5000-users-bounces at lists.mcs.anl.gov [
> nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> *Sent:* Saturday, March 14, 2015 9:20 PM
> *To:* Nek Mailing List
> *Subject:* Re: [Nek5000-users] Metadata files
>   Thanks for your help, but I'm not sure I understand. What do you mean
> by out posting the files?
> On Mar 1, 2015 10:48 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>  Hi David,
>>  Which files are you referring to? Your own output files or nek outpost
>> generated ones? The easiest would be to just make a call to outpost and
>> overwrite the velocity fields and pressure, and use a different name than
>> your current SESSION, instead of writing out your own data file.
>>  In this way you can still use the script 'visnek' to create a Visit
>> readable file (the format visit has for nek is .nek5000 which looks very
>> simple to tweak if needed).
>>  Hope I understood your problem correctly,
>> Oana
>> *Sent:* Sunday, March 01, 2015 9:32 AM
>> *Subject:* [Nek5000-users] Metadata files
>>   Hi all,
>> Would someone be able to help me create a Metadata file, so I can upload
>> my results into VisIt? I'm under the impression that you have to create a
>> new file, is that correct? Thanks.
>> David H.
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150315/54daa9aa/attachment.html>
