[Nek5000-users] Metadata files
Sun Mar 15 14:37:42 CDT 2015
Thanks, its working fine now.
On Mar 15, 2015 2:25 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi,
> you need to install tcsh on your system because the visnek script is
> written for tcsh.
> Just do (on a Ubuntu system):
> > sudo apt-get install tcsh
> and it should work.
> Philipp
> On 2015-03-15 19:18, nek5000-users at lists.mcs.anl.gov wrote:
>> Yes, that makes sense, but I get the error "bash: ./visnek: /bin/tcsh:
>> bad interpreter: No such file or directory". Does this mean I'm missing
>> a file in my bin folder?
>> On Mar 14, 2015 10:42 PM, <nek5000-users at lists.mcs.anl.gov
>> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>>     Hi David,
>>     I guess your question was in fact simpler, you just need run visnek
>>     from scripts and this would create a file *.nek5000 which is
>>     readable in visit. You could also write out files using the outpost
>>     command in case you have some special fields to visualize (thus
>>     outposting, sorry for inventing a new word).
>>     Oana
>>     *From:* nek5000-users-bounces at lists.mcs.anl.gov
>>     <mailto:nek5000-users-bounces at lists.mcs.anl.gov>
>>     [nek5000-users-bounces at lists.mcs.anl.gov
>>     <mailto:nek5000-users-bounces at lists.mcs.anl.gov>] on behalf of
>>     [nek5000-users at lists.mcs.anl.gov
>>     <mailto:nek5000-users at lists.mcs.anl.gov>]
>>     *Sent:* Saturday, March 14, 2015 9:20 PM
>>     *To:* Nek Mailing List
>>     *Subject:* Re: [Nek5000-users] Metadata files
>>     Thanks for your help, but I'm not sure I understand. What do you
>>     mean by out posting the files?
>>     On Mar 1, 2015 10:48 AM, <nek5000-users at lists.mcs.anl.gov
>>         Hi David,
>>         Which files are you referring to? Your own output files or nek
>>         outpost generated ones? The easiest would be to just make a call
>>         to outpost and overwrite the velocity fields and pressure, and
>>         use a different name than your current SESSION, instead of
>>         writing out your own data file.
>>         In this way you can still use the script 'visnek' to create a
>>         Visit readable file (the format visit has for nek is .nek5000
>>         which looks very simple to tweak if needed).
>>         Hope I understood your problem correctly,
>>         Oana
>>         *Sent:* Sunday, March 01, 2015 9:32 AM
>>         *Subject:* [Nek5000-users] Metadata files
>>         Hi all,
>>         Would someone be able to help me create a Metadata file, so I
>>         can upload my results into VisIt? I'm under the impression that
>>         you have to create a new file, is that correct? Thanks.
>>         David H.
>>         _______________________________________________
>>         Nek5000-users mailing list
>>         Nek5000-users at lists.mcs.anl.gov
>>         <mailto:Nek5000-users at lists.mcs.anl.gov>
>>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>     Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.
>> mcs.anl.gov>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150315/f9210a39/attachment-0001.html>
