[Nek5000-users] Metadata files
Sat Mar 14 21:42:52 CDT 2015
Hi David,
I guess your question was in fact simpler, you just need run visnek from scripts and this would create a file *.nek5000 which is readable in visit. You could also write out files using the outpost command in case you have some special fields to visualize (thus outposting, sorry for inventing a new word).
Oana
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Saturday, March 14, 2015 9:20 PM
To: Nek Mailing List
Subject: Re: [Nek5000-users] Metadata files
Thanks for your help, but I'm not sure I understand. What do you mean by out posting the files?
On Mar 1, 2015 10:48 AM, <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
Hi David,
Which files are you referring to? Your own output files or nek outpost generated ones? The easiest would be to just make a call to outpost and overwrite the velocity fields and pressure, and use a different name than your current SESSION, instead of writing out your own data file.
In this way you can still use the script 'visnek' to create a Visit readable file (the format visit has for nek is .nek5000 which looks very simple to tweak if needed).
Hope I understood your problem correctly,
Oana
From: nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov> [nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov>] on behalf of nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> [nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>]
Sent: Sunday, March 01, 2015 9:32 AM
Subject: [Nek5000-users] Metadata files
Hi all,
Would someone be able to help me create a Metadata file, so I can upload my results into VisIt? I'm under the impression that you have to create a new file, is that correct? Thanks.
David H.
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150315/945f1b5d/attachment-0001.html>
