[Nek5000-users] Metadata files
Sat Mar 14 22:54:31 CDT 2015
I normally use the visnek or nekvis script
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Saturday, March 14, 2015 9:42 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Metadata files
Hi David,
I have attached a metafile required for opening output of nek5000 in VisIt. You just need to change the name and number of outputs appropriately upon your results.
Ami
On Sat, Mar 14, 2015 at 10:20 PM, <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
Thanks for your help, but I'm not sure I understand. What do you mean by out posting the files?
On Mar 1, 2015 10:48 AM, <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
Hi David,
Which files are you referring to? Your own output files or nek outpost generated ones? The easiest would be to just make a call to outpost and overwrite the velocity fields and pressure, and use a different name than your current SESSION, instead of writing out your own data file.
In this way you can still use the script 'visnek' to create a Visit readable file (the format visit has for nek is .nek5000 which looks very simple to tweak if needed).
Hope I understood your problem correctly,
Oana
From: nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov> [nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov>] on behalf of nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> [nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>]
Sent: Sunday, March 01, 2015 9:32 AM
To: Nek Mailing List
Subject: [Nek5000-users] Metadata files
Hi all,
Would someone be able to help me create a Metadata file, so I can upload my results into VisIt? I'm under the impression that you have to create a new file, is that correct? Thanks.
David H.
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
