[Nek5000-users] question about efficient running nek5000
Wed Feb 4 13:35:26 CST 2015
Hi Aleks,
Approximately I can do that!
Ami
On Wed, Feb 4, 2015 at 2:30 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Ami,
> Could you try your 12 core-per-node case running with only 11 cores per
> node (and increasing the total number of nodes to keep the number of CPU
> fixed)?
> Aleks
> On Wed, 4 Feb 2015, nek5000-users at lists.mcs.anl.gov wrote:
>  Mike,
>> Thanks for your answer!, Total grid points is 32499936, which I believe it
>> is greater than 20k for both cases!
>> Ami
>> On Wed, Feb 4, 2015 at 2:17 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>  Hi Ami,
>>> How many nodes were in your simulation? Nek scales well if your number of
>>> gridpoints per core is large enough, e.g., greater than 20K or so in my
>>> experience.
>>> It's not clear to me if the power-of-two issue would be the cause here;
>>> perhaps Paul could comment.
>>> Mike
>>> On Feb 4, 2015, at 12:09 PM, <nek5000-users at lists.mcs.anl.gov>
>>>  wrote:
>>>  Hi,
>>>> I ran nek5000 on 1024 CPUs which is divided to 128 nodes and 8 cores per
>>> node, and the same problem on 1200 CPUs with 100 nodes and 12 cores per
>>> node, however in second case I got lower efficiency, simulation goes
>>> slower
>>> about 5~8 percent!! I ran both cases on the same cluster!! Does anyone
>>> have
>>> any idea why I do not get higher efficiency with the higher number of
>>> CPUs
>>> but less nodes involved!? Could memory be a limitation here or since
>>> numbers in first case are power of 2, it is more efficient!?
>>>> Thanks,
>>>> Ami
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150204/ed88ff9b/attachment.html>
