[Nek5000-users] question about efficient running nek5000
Wed Feb 4 13:30:25 CST 2015
Hi Ami,
Could you try your 12 core-per-node case running with only 11 cores per
node (and increasing the total number of nodes to keep the number of CPU
fixed)?
Aleks
On Wed, 4 Feb 2015, nek5000-users at lists.mcs.anl.gov wrote:
> Mike,
> Thanks for your answer!, Total grid points is 32499936, which I believe it
> is greater than 20k for both cases!
> Ami
> On Wed, Feb 4, 2015 at 2:17 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Ami,
>> How many nodes were in your simulation? Nek scales well if your number of
>> gridpoints per core is large enough, e.g., greater than 20K or so in my
>> experience.
>> It's not clear to me if the power-of-two issue would be the cause here;
>> perhaps Paul could comment.
>> Mike
>> On Feb 4, 2015, at 12:09 PM, <nek5000-users at lists.mcs.anl.gov>
>>  wrote:
>>> Hi,
>>> I ran nek5000 on 1024 CPUs which is divided to 128 nodes and 8 cores per
>> node, and the same problem on 1200 CPUs with 100 nodes and 12 cores per
>> node, however in second case I got lower efficiency, simulation goes slower
>> about 5~8 percent!! I ran both cases on the same cluster!! Does anyone have
>> any idea why I do not get higher efficiency with the higher number of CPUs
>> but less nodes involved!? Could memory be a limitation here or since
>> numbers in first case are power of 2, it is more efficient!?
>>> Thanks,
>>> Ami
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
