[Nek5000-users] question about efficient running nek5000
Wed Feb 4 13:26:14 CST 2015
Mike,
Thanks for your answer!, Total grid points is 32499936, which I believe it
is greater than 20k for both cases!
Ami
On Wed, Feb 4, 2015 at 2:17 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Ami,
> How many nodes were in your simulation? Nek scales well if your number of
> gridpoints per core is large enough, e.g., greater than 20K or so in my
> experience.
> It's not clear to me if the power-of-two issue would be the cause here;
> perhaps Paul could comment.
> Mike
> On Feb 4, 2015, at 12:09 PM, <nek5000-users at lists.mcs.anl.gov>
>  wrote:
> > Hi,
> > I ran nek5000 on 1024 CPUs which is divided to 128 nodes and 8 cores per
> node, and the same problem on 1200 CPUs with 100 nodes and 12 cores per
> node, however in second case I got lower efficiency, simulation goes slower
> about 5~8 percent!! I ran both cases on the same cluster!! Does anyone have
> any idea why I do not get higher efficiency with the higher number of CPUs
> but less nodes involved!? Could memory be a limitation here or since
> numbers in first case are power of 2, it is more efficient!?
> > Thanks,
> > Ami
> > _______________________________________________
> > Nek5000-users mailing list
> > Nek5000-users at lists.mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150204/c8fd4999/attachment.html>
