[Nek5000-users] How to obtain spectral coefficients and basis
Mon Dec 14 12:35:16 CST 2015
Andrew,
Thanks for the reply. And can you please confirm that the polynomials
used are Chebyshev?
On 12/8/2015 11:26 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Hello,
> If I've understood you propely, you can see all the collocation points
> and weights in the file coef.f (subroutine genwz).
> Andrew
> 2015-12-07 4:23 GMT+01:00 <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>>:
>     Hello,
>     I'm trying to represent the solution, either velocity or
>     temperature, in terms of spectral basis, i.e.
>     $u=\Sigma a_i \phi_i $ with $\phi_i$ as the basis and $a_i$ as the
>     coefficients.
>     I have two questions:
>     1) (a naive one!) Which basis is being used in Nek5000? I assume
>     it is Chebyshev polynomials. Is that true? If not, what is the basis?
>     2) How can I retrieve the coefficients $a_i$? Also, is there a way
>     to access such coefficients during the solution, say by writing
>     them to a file?
>     I really appreciate the responses. As a side note, I'd like to use
>     DNS data for model reduction.
>     Many thanks,
>     Saleh
>     _______________________________________________
>     Nek5000-users mailing list
>     Nek5000-users at lists.mcs.anl.gov
>     <mailto:Nek5000-users at lists.mcs.anl.gov>
>     https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151214/cfacb31a/attachment.html>
