[Nek5000-users] How to obtain spectral coefficients and basis
Mon Dec 14 15:20:37 CST 2015
Nek is based on a Gauss-Legendre-Lobatto(GLL) quadrature, so the grids are GLL points. The basis polynomials are Lagrange polynomials.
Oana
________________________________________basic
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Monday, December 14, 2015 12:35 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] How to obtain spectral coefficients and basis
Andrew,
Thanks for the reply. And can you please confirm that the polynomials used are Chebyshev?
On 12/8/2015 11:26 AM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Hello,
If I've understood you propely, you can see all the collocation points and weights in the file coef.f (subroutine genwz).
Andrew
2015-12-07 4:23 GMT+01:00 <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>:
Hello,
I'm trying to represent the solution, either velocity or temperature, in terms of spectral basis, i.e.
$u=\Sigma a_i \phi_i $ with $\phi_i$ as the basis and $a_i$ as the coefficients.
I have two questions:
1) (a naive one!) Which basis is being used in Nek5000? I assume it is Chebyshev polynomials. Is that true? If not, what is the basis?
2) How can I retrieve the coefficients $a_i$? Also, is there a way to access such coefficients during the solution, say by writing them to a file?
I really appreciate the responses. As a side note, I'd like to use DNS data for model reduction.
Many thanks,
Saleh
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
