[Nek5000-users] How to obtain spectral coefficients and basis
Tue Dec 8 10:26:43 CST 2015
Hello,
If I've understood you propely, you can see all the collocation points and
weights in the file coef.f (subroutine genwz).
Andrew
2015-12-07 4:23 GMT+01:00 <nek5000-users at lists.mcs.anl.gov>:
> Hello,
> I'm trying to represent the solution, either velocity or temperature, in
> terms of spectral basis, i.e.
> $u=\Sigma a_i \phi_i $ with $\phi_i$ as the basis and $a_i$ as the
> coefficients.
> I have two questions:
> 1) (a naive one!) Which basis is being used in Nek5000? I assume it is
> Chebyshev polynomials. Is that true? If not, what is the basis?
> 2) How can I retrieve the coefficients $a_i$? Also, is there a way to
> access such coefficients during the solution, say by writing them to a file?
> I really appreciate the responses. As a side note, I'd like to use DNS
> data for model reduction.
> Many thanks,
> Saleh
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151208/a0925547/attachment.html>
