[Nek5000-users] Stress formulation
Sun Dec 13 17:55:04 CST 2015
Hi Andrew,
In my view, you are already getting the correct flow physics.
What happens at outflow, especially at moderate Reynolds number, is not
necessarily parallel flow.
The stress formulation is giving the stress-free result.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Sunday, December 13, 2015 5:19 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Stress formulation
Hi Paul,
Thank you for your reply.
Yes, if i increase Reynolds number, the outlet profile become much close to the inlet one. But in my simulations the Reynolds number is between 300 and 1200.
Can you recommend me what kind of boundary conditions i can utilise for ensure for ensure the flow physics ? I would implement these one in code.
Andrew
2015-12-05 3:37 GMT+01:00 <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>:
Hi Andrew,
I checked into this... I think what is happening is that the 'O  ' bc for the stress formulation
means stress-free, which is not guaranteed to yield  a parabolic profile at the outlet.
If you increase your Reynolds number I'm guessing that you'll recover the parabolic
profile because the viscous stresses will diminish -- this is what I observed.
>From my perspective, the outlet boundary is not a region where I would count on accurate
physics --- it is, after all, a truncated domain, so I don't generally worry too much about
the behavior there.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov> [nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov>] on behalf of nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> [nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>]
Sent: Tuesday, December 01, 2015 2:44 AM
To: nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>
Subject: [Nek5000-users] Stress formulation
Hi Neks,
    I have one question about stress formulation in NEK5000.
    I tried to make a simulation for Poiseuil flow with stress formulation. In inlet boundary condition use was made of parabolic profile. If IFSTRS=false the outlet profile is exactly the same as inlet one but in case of IFSTRS=true the outlet profile changes significantly (both the maximum value and profile shape). Could you tell me how I can get the parabolic profile at outlet, please?
     The same thing occurs with pressure values. The maximum pressure value with IFSTRS=true is three times higher then the one with IFSTRS=false.
     I found that the difference comes from subroutines where the stiffness matrix is calculated (axehlm for IFSTRS = false and axhmsf for IFSTRS = true) but I don't undestand what is happening exactly.
Thanks in advance for your help,
Best regards,
Andrew
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151213/31d8ae52/attachment.html>
