[Nek5000-users] Stress formulation
Sun Dec 13 17:19:30 CST 2015
Hi Paul,
Thank you for your reply.
Yes, if i increase Reynolds number, the outlet profile become much close to
the inlet one. But in my simulations the Reynolds number is between 300 and
1200.
Can you recommend me what kind of boundary conditions i can utilise for
ensure for ensure the flow physics ? I would implement these one in code.
Andrew
2015-12-05 3:37 GMT+01:00 <nek5000-users at lists.mcs.anl.gov>:
> Hi Andrew,
> I checked into this... I think what is happening is that the 'O  ' bc for
> the stress formulation
> means stress-free, which is not guaranteed to yield  a parabolic profile
> at the outlet.
> If you increase your Reynolds number I'm guessing that you'll recover the
> parabolic
> profile because the viscous stresses will diminish -- this is what I
> observed.
> From my perspective, the outlet boundary is not a region where I would
> count on accurate
> physics --- it is, after all, a truncated domain, so I don't generally
> worry too much about
> the behavior there.
> Paul
> *From:* nek5000-users-bounces at lists.mcs.anl.gov [
> nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> *Sent:* Tuesday, December 01, 2015 2:44 AM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* [Nek5000-users] Stress formulation
> Hi Neks,
>     I have one question about stress formulation in NEK5000.
>     I tried to make a simulation for Poiseuil flow with stress
> formulation. In inlet boundary condition use was made of parabolic profile.
> If IFSTRS=false the outlet profile is exactly the same as inlet one but in
> case of IFSTRS=true the outlet profile changes significantly (both the
> maximum value and profile shape). Could you tell me how I can get the
> parabolic profile at outlet, please?
>      The same thing occurs with pressure values. The maximum pressure
> value with IFSTRS=true is three times higher then the one with IFSTRS=false.
>      I found that the difference comes from subroutines where the
> stiffness matrix is calculated (axehlm for IFSTRS = false and axhmsf for
> IFSTRS = true) but I don't undestand what is happening exactly.
> Thanks in advance for your help,
> Best regards,
> Andrew
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151214/abcab862/attachment.html>
