[Nek5000-users] Stress formulation
Tue Dec 1 02:44:07 CST 2015
Hi Neks,
    I have one question about stress formulation in NEK5000.
    I tried to make a simulation for Poiseuil flow with stress formulation.
In inlet boundary condition use was made of parabolic profile. If
IFSTRS=false the outlet profile is exactly the same as inlet one but in
case of IFSTRS=true the outlet profile changes significantly (both the
maximum value and profile shape). Could you tell me how I can get the
parabolic profile at outlet, please?
     The same thing occurs with pressure values. The maximum pressure value
with IFSTRS=true is three times higher then the one with IFSTRS=false.
     I found that the difference comes from subroutines where the stiffness
matrix is calculated (axehlm for IFSTRS = false and axhmsf for IFSTRS =
true) but I don't undestand what is happening exactly.
Thanks in advance for your help,
Best regards,
Andrew
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20151201/b30d2ac4/attachment.html>
