[Nek5000-users] Nek5000-users Digest, Vol 78, Issue 9
Sat Aug 29 02:51:22 CDT 2015
Hi, Phillip
Thanks for your reply, but the dos2unix actually does not help. And I
tried a lot to fix it up, including copy existing command from other
examples .rea files to eliminate the error that might have something to
do with the "CR and LF" stuff (I know little about these line breaks).
I am in Ubuntu, should this this be due to the  failue of reading
restart parameters?he
I have attached the .rea file. It would  be greatly that you can have a
look and give some advice.
Thanks in advance.
and have a nice weekend!
from Allen
On 08/29/2015 01:00 AM, nek5000-users-request at lists.mcs.anl.gov wrote:
> Send Nek5000-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> 	https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	nek5000-users-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Nek5000-users digest..."
> Today's Topics:
>     1. restart a case got an error: Error reading initial
>        condition/drive force data (nek5000-users at lists.mcs.anl.gov)
>     2. Re: restart a case got an error: Error reading initial
> Message: 1
> Date: Fri, 28 Aug 2015 11:22:34 +0800
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Subject: [Nek5000-users] restart a case got an error: Error reading
> 	initial condition/drive force data
> Message-ID:
> 	<mailman.6382.1440732161.24727.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset="utf-8"; Format="flowed"
> Hi, Nekers:
> I recently want to do some simulation with Nek, so I followed the
> tutorial for the eddy_uv case
> I have run the case without problem, but when I want to try the restart
> utility with the following modification instructed by the manual
>               1 PRESOLVE/RESTART OPTIONS  *****
> eddy_uv0.f00010
> affter changing for a new case name and recompile, I started the restart
> run, but the logfile gives the following error :
>    mapping elements to processors
>              2          86          86         256         256  NELV
>              0          85          85         256         256  NELV
>              1          85          85         256         256  NELV
>    RANK     0 IEG     133     134     135     136     149     150 151     152
>                       161     162     165     166     167     168 177     178
>                       179     181     182     183     184     193 194     195
>                       196     197     198     199     200     201 202     203
>                       204     205     206     207     208     209 210     211
>                       212     213     214     215     216     217 218     219
>                       220     221     222     223     224     225 226     227
>                       228     229     230     231     232     233 234     235
>                       236     237     238     239     240     241 242     243
>                       244     245     246     247     248     249 250     251
>                       252     253     254     255     256
>    element load imbalance:            1          85          86
>    done :: mapping elements to processors
>     Error reading initial condition/drive force data
>     aborting in routine rdicdf.
> EXIT: rdicdf error          1
> call exitt: dying ...
> backtrace(): obtained 9 stack frames.
> ./nek5000(print_stack_+0x18) [0x500ff8]
> ./nek5000(exitt_+0x1cc) [0x5be5ec]
> ./nek5000(exitti_+0x117) [0x5c1537]
> ./nek5000(rdicdf_+0x1e7) [0x442387]
> ./nek5000(readat_+0x35f) [0x44951f]
> ./nek5000(nek_init_+0x75) [0x41ae25]
> ./nek5000(main+0x24) [0x419d84]
> /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f26a5be276d]
> ./nek5000() [0x419dc9]
> I have searched the post list, but I only found very vague statement of
> this
> problem:_http://lists.mcs.anl.gov/pipermail/nek5000-users/2011-October/001560.html_
> Hope some one can give me some hint, I actually do exactly what the
> manual does, which makes me confused.
> Thanks, hope it is a minor mistake.
> from Allen
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150828/06850988/attachment-0001.html>
> Message: 2
> Date: Fri, 28 Aug 2015 10:43:10 +0200
> Subject: Re: [Nek5000-users] restart a case got an error: Error
> Message-ID:
> 	<mailman.6397.1440751408.24727.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset=windows-1252; format=flowed
> not sure it helps, but we had a similar problem recently when a rea file
> went trough Windows and Linux, adding CR and LF as line breaks. As far
> as I remember, using dos2unix of the file helped. Also, a tab character
> (ASCII 9) somewhere on that line gave some problems.
> Good luck,  Philipp
> On 2015-08-28 05:22, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi, Nekers:
>> eddy_uv0.f00010
>>                       252     253     254     255     256
>> this
>> from Allen
>> Nek5000-users at lists.mcs.anl.gov
> End of Nek5000-users Digest, Vol 78, Issue 9
 ****** PARAMETERS *****
    2.610000     NEKTON VERSION
            2 DIMENSIONAL RUN
          103 PARAMETERS FOLLOW
       1.000000         p01 DENSITY
      -20.00000         p02 VISCOS
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p07 RHOCP
       1.000000         p08 CONDUCT
      0.0000000E+00
      0.0000000E+00     p10 FINTIME
       2000.000         p11 NSTEPS
     -1.0000000E-04     p12 DT
      0.0000000E+00     p13 IOCOMM
      0.0000000E+00     p14 IOTIME
       100.0000         p15 IOSTEP
      0.0000000E+00     p16 PSSOLVER
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      1.0000000E-11     p21 DIVERGENCE
      1.0000000E-12     p22 HELMHOLTZ
      0.0000000E+00     p23 NPSCAL
      1.0000000E-10     p24 TOLREL
      1.0000000E-10     p25 TOLABS
       1.000000         p26 COURANT/NTAU
       3.000000         p27 TORDER
      0.0000000E+00     p28 TORDER: mesh velocity (0: p28=p27)
      0.0000000E+00     p29 magnetic visc if > 0, = -1/Rm if < 0
      0.0000000E+00     p30 > 0 ==> properties set in uservp()
      0.0000000E+00     p31 NPERT: #perturbation modes
      0.0000000E+00     p32 #BCs in re2 file, if > 0
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p42 0=gmres/1=pcg
       1.000000         p43 0=semg/1=schwarz
      0.0000000E+00     p44 0=E-based/1=A-based prec.
      0.0000000E+00     p45 Relaxation factor for DTFS
      0.0000000E+00      p46 if >0, dont call SETICS
      0.0000000E+00     p47 vnu: mesh matieral prop
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p52 IOHIS
      0.0000000E+00
      0.0000000E+00     p54 1,2,3-->fixed flow rate dir=x,y,z
      0.0000000E+00     p55 vol.flow rate(p54>0) or Ubar(p54<0)
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p59 !=0 --> use std axhelm for all elem
      0.0000000E+00     p60 !=0--> init velocity to small nonzero
      0.0000000E+00
      0.0000000E+00     p62 >0 --> force byte_swap for output
      0.0000000E+00     p63 =8 --> force 8-byte output
      0.0000000E+00     p64 =1 --> perturbation restart
      0.0000000E+00     p65 #iofile(eg,0 or 64); <0 --> sep. dirs
       6.000000         p66 write fmt:ONLY postx uses rea value
       6.000000         p67 read fmt: same modes as p66
      0.0000000E+00     p68 iastep: freq for avg_all
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p74 verbose Helmholtz
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p84 !=0 -->sets initial timestep if p12>0
      0.0000000E+00     p85 dt ratio if p84 !=0, for timesteps>0
      0.0000000E+00     p86 reserved
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p89 reserved
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
       20.00000         p93 Numbr of prev pressure solns saved
       5.000000         p94 start projecting vel. after p94 step
       5.000000         p95 start projecting pr after p95 step
       1.00000          p96 u0 translational velocity (in .usr)
        0.30000          p97 v0 translational velocity (in .usr)
      0.0000000E+00
       3.000000         p99    dealiasing:if <0 disable
      0.0000000E+00     p100 reserved
      0.0000000E+00     p101   No. of additional filter modes
      0.0000000E+00
      0.0000000E+00     p103   weight of stabilizing filter (.01)
      4  Lines of passive scalar data follows2 CONDUCT; 2RHOCP
   1.00000       1.00000       1.00000       1.00000       1.00000
           13  LOGICAL SWITCHES FOLLOW
  T     IFFLOW
  F     IFHEAT
  T     IFTRAN
  T F F F F F F F F F F IFNAV & IFADVC (convection in P.S. fields)
  F F T T T T T T T T T T IFTMSH (IF mesh for this field is T mesh)
  F     IFAXIS
  F     IFSTRS
  F     IFSPLIT
  F     IFMGRID
  F     IFMODEL
  F     IFKEPS
  F     IFMVBD
  F     IFCHAR
   8.00000       8.00000     -0.500000      -4.00000     XFAC,YFAC,XZERO,YZERO
 **MESH DATA** 1st line is X of corner 1,2,3,4. 2nd line is Y.
   256     2   256           NEL,NDIM,NELV
            ELEMENT    1 [    1a]    GROUP     0
  0.0000000E+00  6.2500000E-02  6.2500000E-02  0.0000000E+00
  0.0000000E+00  0.0000000E+00  6.2500000E-02  6.2500000E-02
            ELEMENT    2 [    1b]    GROUP     0
  6.2500000E-02  1.2500000E-01  1.2500000E-01  6.2500000E-02
            ELEMENT    3 [    1c]    GROUP     0
  1.2500000E-01  1.8750000E-01  1.8750000E-01  1.2500000E-01
            ELEMENT    4 [    1d]    GROUP     0
  1.8750000E-01  2.5000000E-01  2.5000000E-01  1.8750000E-01
            ELEMENT    5 [    1e]    GROUP     0
  2.5000000E-01  3.1250000E-01  3.1250000E-01  2.5000000E-01
            ELEMENT    6 [    1f]    GROUP     0
  3.1250000E-01  3.7500000E-01  3.7500000E-01  3.1250000E-01
            ELEMENT    7 [    1g]    GROUP     0
  3.7500000E-01  4.3750000E-01  4.3750000E-01  3.7500000E-01
            ELEMENT    8 [    1h]    GROUP     0
  4.3750000E-01  5.0000000E-01  5.0000000E-01  4.3750000E-01
            ELEMENT    9 [    1i]    GROUP     0
  5.0000000E-01  5.6250000E-01  5.6250000E-01  5.0000000E-01
            ELEMENT   10 [    1j]    GROUP     0
  5.6250000E-01  6.2500000E-01  6.2500000E-01  5.6250000E-01
            ELEMENT   11 [    1k]    GROUP     0
  6.2500000E-01  6.8750000E-01  6.8750000E-01  6.2500000E-01
            ELEMENT   12 [    1l]    GROUP     0
  6.8750000E-01  7.5000000E-01  7.5000000E-01  6.8750000E-01
            ELEMENT   13 [    1m]    GROUP     0
  7.5000000E-01  8.1250000E-01  8.1250000E-01  7.5000000E-01
            ELEMENT   14 [    1n]    GROUP     0
  8.1250000E-01  8.7500000E-01  8.7500000E-01  8.1250000E-01
            ELEMENT   15 [    1o]    GROUP     0
  8.7500000E-01  9.3750000E-01  9.3750000E-01  8.7500000E-01
            ELEMENT   16 [    1p]    GROUP     0
  9.3750000E-01  1.0000000E+00  1.0000000E+00  9.3750000E-01
            ELEMENT   17 [    1q]    GROUP     0
  6.2500000E-02  6.2500000E-02  1.2500000E-01  1.2500000E-01
            ELEMENT   18 [    1r]    GROUP     0
            ELEMENT   19 [    1s]    GROUP     0
            ELEMENT   20 [    1t]    GROUP     0
            ELEMENT   21 [    1u]    GROUP     0
            ELEMENT   22 [    1v]    GROUP     0
            ELEMENT   23 [    1w]    GROUP     0
            ELEMENT   24 [    1x]    GROUP     0
            ELEMENT   25 [    1y]    GROUP     0
            ELEMENT   26 [    1z]    GROUP     0
            ELEMENT   27 [    1A]    GROUP     0
            ELEMENT   28 [    1B]    GROUP     0
            ELEMENT   29 [    1C]    GROUP     0
            ELEMENT   30 [    1D]    GROUP     0
            ELEMENT   31 [    1E]    GROUP     0
            ELEMENT   32 [    1F]    GROUP     0
            ELEMENT   33 [    1G]    GROUP     0
  1.2500000E-01  1.2500000E-01  1.8750000E-01  1.8750000E-01
            ELEMENT   34 [    1H]    GROUP     0
            ELEMENT   35 [    1I]    GROUP     0
            ELEMENT   36 [    1J]    GROUP     0
            ELEMENT   37 [    1K]    GROUP     0
            ELEMENT   38 [    1L]    GROUP     0
            ELEMENT   39 [    1M]    GROUP     0
            ELEMENT   40 [    1N]    GROUP     0
            ELEMENT   41 [    1O]    GROUP     0
            ELEMENT   42 [    1P]    GROUP     0
            ELEMENT   43 [    1Q]    GROUP     0
            ELEMENT   44 [    1R]    GROUP     0
            ELEMENT   45 [    1S]    GROUP     0
            ELEMENT   46 [    1T]    GROUP     0
            ELEMENT   47 [    1U]    GROUP     0
            ELEMENT   48 [    1V]    GROUP     0
            ELEMENT   49 [    1W]    GROUP     0
  1.8750000E-01  1.8750000E-01  2.5000000E-01  2.5000000E-01
            ELEMENT   50 [    1X]    GROUP     0
            ELEMENT   51 [    1Y]    GROUP     0
            ELEMENT   52 [    1Z]    GROUP     0
            ELEMENT   53 [    1a]    GROUP     0
            ELEMENT   54 [    1b]    GROUP     0
            ELEMENT   55 [    1c]    GROUP     0
            ELEMENT   56 [    1d]    GROUP     0
            ELEMENT   57 [    1e]    GROUP     0
            ELEMENT   58 [    1f]    GROUP     0
            ELEMENT   59 [    1g]    GROUP     0
            ELEMENT   60 [    1h]    GROUP     0
            ELEMENT   61 [    1i]    GROUP     0
            ELEMENT   62 [    1j]    GROUP     0
            ELEMENT   63 [    1k]    GROUP     0
            ELEMENT   64 [    1l]    GROUP     0
            ELEMENT   65 [    1m]    GROUP     0
  2.5000000E-01  2.5000000E-01  3.1250000E-01  3.1250000E-01
            ELEMENT   66 [    1n]    GROUP     0
            ELEMENT   67 [    1o]    GROUP     0
            ELEMENT   68 [    1p]    GROUP     0
            ELEMENT   69 [    1q]    GROUP     0
            ELEMENT   70 [    1r]    GROUP     0
            ELEMENT   71 [    1s]    GROUP     0
            ELEMENT   72 [    1t]    GROUP     0
            ELEMENT   73 [    1u]    GROUP     0
            ELEMENT   74 [    1v]    GROUP     0
            ELEMENT   75 [    1w]    GROUP     0
            ELEMENT   76 [    1x]    GROUP     0
            ELEMENT   77 [    1y]    GROUP     0
            ELEMENT   78 [    1z]    GROUP     0
            ELEMENT   79 [    1A]    GROUP     0
            ELEMENT   80 [    1B]    GROUP     0
            ELEMENT   81 [    1C]    GROUP     0
  3.1250000E-01  3.1250000E-01  3.7500000E-01  3.7500000E-01
            ELEMENT   82 [    1D]    GROUP     0
            ELEMENT   83 [    1E]    GROUP     0
            ELEMENT   84 [    1F]    GROUP     0
            ELEMENT   85 [    1G]    GROUP     0
            ELEMENT   86 [    1H]    GROUP     0
            ELEMENT   87 [    1I]    GROUP     0
            ELEMENT   88 [    1J]    GROUP     0
            ELEMENT   89 [    1K]    GROUP     0
            ELEMENT   90 [    1L]    GROUP     0
            ELEMENT   91 [    1M]    GROUP     0
            ELEMENT   92 [    1N]    GROUP     0
            ELEMENT   93 [    1O]    GROUP     0
            ELEMENT   94 [    1P]    GROUP     0
            ELEMENT   95 [    1Q]    GROUP     0
            ELEMENT   96 [    1R]    GROUP     0
            ELEMENT   97 [    1S]    GROUP     0
  3.7500000E-01  3.7500000E-01  4.3750000E-01  4.3750000E-01
            ELEMENT   98 [    1T]    GROUP     0
            ELEMENT   99 [    1U]    GROUP     0
            ELEMENT  100 [    1V]    GROUP     0
            ELEMENT  101 [    1W]    GROUP     0
            ELEMENT  102 [    1X]    GROUP     0
            ELEMENT  103 [    1Y]    GROUP     0
            ELEMENT  104 [    1Z]    GROUP     0
            ELEMENT  105 [    1a]    GROUP     0
            ELEMENT  106 [    1b]    GROUP     0
            ELEMENT  107 [    1c]    GROUP     0
            ELEMENT  108 [    1d]    GROUP     0
            ELEMENT  109 [    1e]    GROUP     0
            ELEMENT  110 [    1f]    GROUP     0
            ELEMENT  111 [    1g]    GROUP     0
            ELEMENT  112 [    1h]    GROUP     0
            ELEMENT  113 [    1i]    GROUP     0
  4.3750000E-01  4.3750000E-01  5.0000000E-01  5.0000000E-01
            ELEMENT  114 [    1j]    GROUP     0
            ELEMENT  115 [    1k]    GROUP     0
            ELEMENT  116 [    1l]    GROUP     0
            ELEMENT  117 [    1m]    GROUP     0
            ELEMENT  118 [    1n]    GROUP     0
            ELEMENT  119 [    1o]    GROUP     0
            ELEMENT  120 [    1p]    GROUP     0
            ELEMENT  121 [    1q]    GROUP     0
            ELEMENT  122 [    1r]    GROUP     0
            ELEMENT  123 [    1s]    GROUP     0
            ELEMENT  124 [    1t]    GROUP     0
            ELEMENT  125 [    1u]    GROUP     0
            ELEMENT  126 [    1v]    GROUP     0
            ELEMENT  127 [    1w]    GROUP     0
            ELEMENT  128 [    1x]    GROUP     0
            ELEMENT  129 [    1y]    GROUP     0
  5.0000000E-01  5.0000000E-01  5.6250000E-01  5.6250000E-01
            ELEMENT  130 [    1z]    GROUP     0
            ELEMENT  131 [    1A]    GROUP     0
            ELEMENT  132 [    1B]    GROUP     0
            ELEMENT  133 [    1C]    GROUP     0
            ELEMENT  134 [    1D]    GROUP     0
            ELEMENT  135 [    1E]    GROUP     0
            ELEMENT  136 [    1F]    GROUP     0
            ELEMENT  137 [    1G]    GROUP     0
            ELEMENT  138 [    1H]    GROUP     0
            ELEMENT  139 [    1I]    GROUP     0
            ELEMENT  140 [    1J]    GROUP     0
            ELEMENT  141 [    1K]    GROUP     0
            ELEMENT  142 [    1L]    GROUP     0
            ELEMENT  143 [    1M]    GROUP     0
            ELEMENT  144 [    1N]    GROUP     0
            ELEMENT  145 [    1O]    GROUP     0
  5.6250000E-01  5.6250000E-01  6.2500000E-01  6.2500000E-01
            ELEMENT  146 [    1P]    GROUP     0
            ELEMENT  147 [    1Q]    GROUP     0
            ELEMENT  148 [    1R]    GROUP     0
            ELEMENT  149 [    1S]    GROUP     0
            ELEMENT  150 [    1T]    GROUP     0
            ELEMENT  151 [    1U]    GROUP     0
            ELEMENT  152 [    1V]    GROUP     0
            ELEMENT  153 [    1W]    GROUP     0
            ELEMENT  154 [    1X]    GROUP     0
            ELEMENT  155 [    1Y]    GROUP     0
            ELEMENT  156 [    1Z]    GROUP     0
            ELEMENT  157 [    1a]    GROUP     0
            ELEMENT  158 [    1b]    GROUP     0
            ELEMENT  159 [    1c]    GROUP     0
            ELEMENT  160 [    1d]    GROUP     0
            ELEMENT  161 [    1e]    GROUP     0
  6.2500000E-01  6.2500000E-01  6.8750000E-01  6.8750000E-01
            ELEMENT  162 [    1f]    GROUP     0
            ELEMENT  163 [    1g]    GROUP     0
            ELEMENT  164 [    1h]    GROUP     0
            ELEMENT  165 [    1i]    GROUP     0
            ELEMENT  166 [    1j]    GROUP     0
            ELEMENT  167 [    1k]    GROUP     0
            ELEMENT  168 [    1l]    GROUP     0
            ELEMENT  169 [    1m]    GROUP     0
            ELEMENT  170 [    1n]    GROUP     0
            ELEMENT  171 [    1o]    GROUP     0
            ELEMENT  172 [    1p]    GROUP     0
            ELEMENT  173 [    1q]    GROUP     0
            ELEMENT  174 [    1r]    GROUP     0
            ELEMENT  175 [    1s]    GROUP     0
            ELEMENT  176 [    1t]    GROUP     0
            ELEMENT  177 [    1u]    GROUP     0
  6.8750000E-01  6.8750000E-01  7.5000000E-01  7.5000000E-01
            ELEMENT  178 [    1v]    GROUP     0
            ELEMENT  179 [    1w]    GROUP     0
            ELEMENT  180 [    1x]    GROUP     0
            ELEMENT  181 [    1y]    GROUP     0
            ELEMENT  182 [    1z]    GROUP     0
            ELEMENT  183 [    1A]    GROUP     0
            ELEMENT  184 [    1B]    GROUP     0
            ELEMENT  185 [    1C]    GROUP     0
            ELEMENT  186 [    1D]    GROUP     0
            ELEMENT  187 [    1E]    GROUP     0
            ELEMENT  188 [    1F]    GROUP     0
            ELEMENT  189 [    1G]    GROUP     0
            ELEMENT  190 [    1H]    GROUP     0
            ELEMENT  191 [    1I]    GROUP     0
            ELEMENT  192 [    1J]    GROUP     0
            ELEMENT  193 [    1K]    GROUP     0
  7.5000000E-01  7.5000000E-01  8.1250000E-01  8.1250000E-01
            ELEMENT  194 [    1L]    GROUP     0
            ELEMENT  195 [    1M]    GROUP     0
            ELEMENT  196 [    1N]    GROUP     0
            ELEMENT  197 [    1O]    GROUP     0
            ELEMENT  198 [    1P]    GROUP     0
            ELEMENT  199 [    1Q]    GROUP     0
            ELEMENT  200 [    1R]    GROUP     0
            ELEMENT  201 [    1S]    GROUP     0
            ELEMENT  202 [    1T]    GROUP     0
            ELEMENT  203 [    1U]    GROUP     0
            ELEMENT  204 [    1V]    GROUP     0
            ELEMENT  205 [    1W]    GROUP     0
            ELEMENT  206 [    1X]    GROUP     0
            ELEMENT  207 [    1Y]    GROUP     0
            ELEMENT  208 [    1Z]    GROUP     0
            ELEMENT  209 [    1a]    GROUP     0
  8.1250000E-01  8.1250000E-01  8.7500000E-01  8.7500000E-01
            ELEMENT  210 [    1b]    GROUP     0
            ELEMENT  211 [    1c]    GROUP     0
            ELEMENT  212 [    1d]    GROUP     0
            ELEMENT  213 [    1e]    GROUP     0
            ELEMENT  214 [    1f]    GROUP     0
            ELEMENT  215 [    1g]    GROUP     0
            ELEMENT  216 [    1h]    GROUP     0
            ELEMENT  217 [    1i]    GROUP     0
            ELEMENT  218 [    1j]    GROUP     0
            ELEMENT  219 [    1k]    GROUP     0
            ELEMENT  220 [    1l]    GROUP     0
            ELEMENT  221 [    1m]    GROUP     0
            ELEMENT  222 [    1n]    GROUP     0
            ELEMENT  223 [    1o]    GROUP     0
            ELEMENT  224 [    1p]    GROUP     0
            ELEMENT  225 [    1q]    GROUP     0
  8.7500000E-01  8.7500000E-01  9.3750000E-01  9.3750000E-01
            ELEMENT  226 [    1r]    GROUP     0
            ELEMENT  227 [    1s]    GROUP     0
            ELEMENT  228 [    1t]    GROUP     0
            ELEMENT  229 [    1u]    GROUP     0
            ELEMENT  230 [    1v]    GROUP     0
            ELEMENT  231 [    1w]    GROUP     0
            ELEMENT  232 [    1x]    GROUP     0
            ELEMENT  233 [    1y]    GROUP     0
            ELEMENT  234 [    1z]    GROUP     0
            ELEMENT  235 [    1A]    GROUP     0
            ELEMENT  236 [    1B]    GROUP     0
            ELEMENT  237 [    1C]    GROUP     0
            ELEMENT  238 [    1D]    GROUP     0
            ELEMENT  239 [    1E]    GROUP     0
            ELEMENT  240 [    1F]    GROUP     0
            ELEMENT  241 [    1G]    GROUP     0
  9.3750000E-01  9.3750000E-01  1.0000000E+00  1.0000000E+00
            ELEMENT  242 [    1H]    GROUP     0
            ELEMENT  243 [    1I]    GROUP     0
            ELEMENT  244 [    1J]    GROUP     0
            ELEMENT  245 [    1K]    GROUP     0
            ELEMENT  246 [    1L]    GROUP     0
            ELEMENT  247 [    1M]    GROUP     0
            ELEMENT  248 [    1N]    GROUP     0
            ELEMENT  249 [    1O]    GROUP     0
            ELEMENT  250 [    1P]    GROUP     0
            ELEMENT  251 [    1Q]    GROUP     0
            ELEMENT  252 [    1R]    GROUP     0
            ELEMENT  253 [    1S]    GROUP     0
            ELEMENT  254 [    1T]    GROUP     0
            ELEMENT  255 [    1U]    GROUP     0
            ELEMENT  256 [    1V]    GROUP     0
  ***** CURVED SIDE DATA *****
     0 Curved sides follow IEDGE,IEL,CURVE(I),I=1,5, CCURVE
  ***** BOUNDARY CONDITIONS *****
  ***** FLUID   BOUNDARY CONDITIONS *****
 P    1  1  241.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    1  2  2.000000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    1  3  17.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P    1  4  16.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P    2  1  242.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    2  2  3.000000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    2  3  18.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    2  4  1.000000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P    3  1  243.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    3  2  4.000000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    3  3  19.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    3  4  2.000000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P    4  1  244.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    4  2  5.000000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    4  3  20.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    4  4  3.000000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P    5  1  245.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    5  2  6.000000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    5  3  21.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    5  4  4.000000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P    6  1  246.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    6  2  7.000000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    6  3  22.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    6  4  5.000000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P    7  1  247.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    7  2  8.000000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    7  3  23.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    7  4  6.000000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P    8  1  248.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    8  2  9.000000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    8  3  24.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    8  4  7.000000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P    9  1  249.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    9  2  10.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    9  3  25.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E    9  4  8.000000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   10  1  250.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   10  2  11.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   10  3  26.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   10  4  9.000000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   11  1  251.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   11  2  12.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   11  3  27.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   11  4  10.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   12  1  252.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   12  2  13.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   12  3  28.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   12  4  11.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   13  1  253.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   13  2  14.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   13  3  29.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   13  4  12.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   14  1  254.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   14  2  15.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   14  3  30.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   14  4  13.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   15  1  255.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   15  2  16.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   15  3  31.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   15  4  14.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   16  1  256.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   16  2  1.000000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   16  3  32.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   16  4  15.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   17  1  1.000000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   17  2  18.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   17  3  33.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   17  4  32.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   18  1  2.000000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   18  2  19.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   18  3  34.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   18  4  17.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   19  1  3.000000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   19  2  20.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   19  3  35.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   19  4  18.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   20  1  4.000000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   20  2  21.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   20  3  36.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   20  4  19.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   21  1  5.000000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   21  2  22.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   21  3  37.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   21  4  20.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   22  1  6.000000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   22  2  23.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   22  3  38.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   22  4  21.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   23  1  7.000000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   23  2  24.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   23  3  39.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   23  4  22.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   24  1  8.000000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   24  2  25.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   24  3  40.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   24  4  23.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   25  1  9.000000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   25  2  26.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   25  3  41.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   25  4  24.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   26  1  10.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   26  2  27.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   26  3  42.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   26  4  25.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   27  1  11.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   27  2  28.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   27  3  43.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   27  4  26.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   28  1  12.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   28  2  29.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   28  3  44.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   28  4  27.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   29  1  13.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   29  2  30.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   29  3  45.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   29  4  28.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   30  1  14.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   30  2  31.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   30  3  46.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   30  4  29.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   31  1  15.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   31  2  32.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   31  3  47.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   31  4  30.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   32  1  16.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   32  2  17.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   32  3  48.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   32  4  31.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   33  1  17.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   33  2  34.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   33  3  49.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   33  4  48.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   34  1  18.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   34  2  35.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   34  3  50.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   34  4  33.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   35  1  19.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   35  2  36.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   35  3  51.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   35  4  34.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   36  1  20.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   36  2  37.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   36  3  52.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   36  4  35.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   37  1  21.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   37  2  38.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   37  3  53.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   37  4  36.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   38  1  22.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   38  2  39.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   38  3  54.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   38  4  37.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   39  1  23.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   39  2  40.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   39  3  55.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   39  4  38.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   40  1  24.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   40  2  41.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   40  3  56.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   40  4  39.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   41  1  25.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   41  2  42.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   41  3  57.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   41  4  40.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   42  1  26.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   42  2  43.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   42  3  58.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   42  4  41.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   43  1  27.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   43  2  44.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   43  3  59.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   43  4  42.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   44  1  28.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   44  2  45.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   44  3  60.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   44  4  43.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   45  1  29.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   45  2  46.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   45  3  61.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   45  4  44.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   46  1  30.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   46  2  47.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   46  3  62.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   46  4  45.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   47  1  31.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   47  2  48.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   47  3  63.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   47  4  46.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   48  1  32.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   48  2  33.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   48  3  64.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   48  4  47.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   49  1  33.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   49  2  50.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   49  3  65.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   49  4  64.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   50  1  34.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   50  2  51.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   50  3  66.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   50  4  49.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   51  1  35.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   51  2  52.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   51  3  67.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   51  4  50.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   52  1  36.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   52  2  53.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   52  3  68.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   52  4  51.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   53  1  37.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   53  2  54.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   53  3  69.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   53  4  52.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   54  1  38.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   54  2  55.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   54  3  70.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   54  4  53.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   55  1  39.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   55  2  56.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   55  3  71.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   55  4  54.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   56  1  40.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   56  2  57.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   56  3  72.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   56  4  55.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   57  1  41.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   57  2  58.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   57  3  73.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   57  4  56.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   58  1  42.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   58  2  59.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   58  3  74.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   58  4  57.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   59  1  43.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   59  2  60.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   59  3  75.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   59  4  58.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   60  1  44.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   60  2  61.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   60  3  76.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   60  4  59.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   61  1  45.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   61  2  62.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   61  3  77.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   61  4  60.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   62  1  46.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   62  2  63.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   62  3  78.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   62  4  61.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   63  1  47.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   63  2  64.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   63  3  79.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   63  4  62.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   64  1  48.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   64  2  49.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   64  3  80.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   64  4  63.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   65  1  49.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   65  2  66.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   65  3  81.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   65  4  80.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   66  1  50.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   66  2  67.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   66  3  82.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   66  4  65.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   67  1  51.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   67  2  68.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   67  3  83.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   67  4  66.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   68  1  52.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   68  2  69.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   68  3  84.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   68  4  67.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   69  1  53.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   69  2  70.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   69  3  85.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   69  4  68.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   70  1  54.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   70  2  71.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   70  3  86.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   70  4  69.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   71  1  55.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   71  2  72.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   71  3  87.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   71  4  70.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   72  1  56.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   72  2  73.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   72  3  88.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   72  4  71.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   73  1  57.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   73  2  74.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   73  3  89.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   73  4  72.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   74  1  58.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   74  2  75.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   74  3  90.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   74  4  73.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   75  1  59.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   75  2  76.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   75  3  91.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   75  4  74.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   76  1  60.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   76  2  77.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   76  3  92.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   76  4  75.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   77  1  61.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   77  2  78.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   77  3  93.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   77  4  76.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   78  1  62.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   78  2  79.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   78  3  94.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   78  4  77.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   79  1  63.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   79  2  80.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   79  3  95.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   79  4  78.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   80  1  64.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   80  2  65.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   80  3  96.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   80  4  79.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   81  1  65.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   81  2  82.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   81  3  97.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   81  4  96.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   82  1  66.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   82  2  83.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   82  3  98.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   82  4  81.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   83  1  67.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   83  2  84.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   83  3  99.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   83  4  82.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   84  1  68.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   84  2  85.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   84  3  100.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   84  4  83.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   85  1  69.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   85  2  86.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   85  3  101.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   85  4  84.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   86  1  70.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   86  2  87.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   86  3  102.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   86  4  85.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   87  1  71.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   87  2  88.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   87  3  103.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   87  4  86.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   88  1  72.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   88  2  89.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   88  3  104.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   88  4  87.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   89  1  73.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   89  2  90.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   89  3  105.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   89  4  88.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   90  1  74.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   90  2  91.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   90  3  106.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   90  4  89.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   91  1  75.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   91  2  92.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   91  3  107.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   91  4  90.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   92  1  76.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   92  2  93.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   92  3  108.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   92  4  91.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   93  1  77.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   93  2  94.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   93  3  109.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   93  4  92.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   94  1  78.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   94  2  95.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   94  3  110.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   94  4  93.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   95  1  79.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   95  2  96.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   95  3  111.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   95  4  94.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   96  1  80.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   96  2  81.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   96  3  112.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   96  4  95.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   97  1  81.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   97  2  98.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   97  3  113.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P   97  4  112.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   98  1  82.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   98  2  99.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   98  3  114.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   98  4  97.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   99  1  83.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   99  2  100.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   99  3  115.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E   99  4  98.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  100  1  84.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  100  2  101.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  100  3  116.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  100  4  99.00000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  101  1  85.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  101  2  102.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  101  3  117.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  101  4  100.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  102  1  86.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  102  2  103.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  102  3  118.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  102  4  101.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  103  1  87.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  103  2  104.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  103  3  119.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  103  4  102.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  104  1  88.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  104  2  105.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  104  3  120.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  104  4  103.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  105  1  89.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  105  2  106.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  105  3  121.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  105  4  104.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  106  1  90.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  106  2  107.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  106  3  122.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  106  4  105.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  107  1  91.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  107  2  108.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  107  3  123.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  107  4  106.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  108  1  92.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  108  2  109.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  108  3  124.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  108  4  107.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  109  1  93.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  109  2  110.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  109  3  125.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  109  4  108.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  110  1  94.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  110  2  111.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  110  3  126.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  110  4  109.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  111  1  95.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  111  2  112.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  111  3  127.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  111  4  110.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  112  1  96.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  112  2  97.00000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  112  3  128.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  112  4  111.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  113  1  97.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  113  2  114.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  113  3  129.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  113  4  128.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  114  1  98.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  114  2  115.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  114  3  130.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  114  4  113.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  115  1  99.00000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  115  2  116.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  115  3  131.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  115  4  114.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  116  1  100.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  116  2  117.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  116  3  132.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  116  4  115.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  117  1  101.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  117  2  118.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  117  3  133.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  117  4  116.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  118  1  102.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  118  2  119.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  118  3  134.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  118  4  117.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  119  1  103.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  119  2  120.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  119  3  135.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  119  4  118.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  120  1  104.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  120  2  121.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  120  3  136.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  120  4  119.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  121  1  105.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  121  2  122.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  121  3  137.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  121  4  120.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  122  1  106.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  122  2  123.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  122  3  138.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  122  4  121.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  123  1  107.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  123  2  124.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  123  3  139.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  123  4  122.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  124  1  108.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  124  2  125.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  124  3  140.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  124  4  123.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  125  1  109.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  125  2  126.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  125  3  141.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  125  4  124.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  126  1  110.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  126  2  127.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  126  3  142.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  126  4  125.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  127  1  111.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  127  2  128.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  127  3  143.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  127  4  126.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  128  1  112.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  128  2  113.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  128  3  144.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  128  4  127.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  129  1  113.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  129  2  130.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  129  3  145.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  129  4  144.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  130  1  114.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  130  2  131.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  130  3  146.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  130  4  129.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  131  1  115.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  131  2  132.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  131  3  147.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  131  4  130.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  132  1  116.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  132  2  133.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  132  3  148.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  132  4  131.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  133  1  117.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  133  2  134.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  133  3  149.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  133  4  132.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  134  1  118.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  134  2  135.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  134  3  150.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  134  4  133.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  135  1  119.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  135  2  136.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  135  3  151.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  135  4  134.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  136  1  120.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  136  2  137.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  136  3  152.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  136  4  135.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  137  1  121.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  137  2  138.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  137  3  153.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  137  4  136.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  138  1  122.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  138  2  139.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  138  3  154.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  138  4  137.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  139  1  123.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  139  2  140.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  139  3  155.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  139  4  138.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  140  1  124.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  140  2  141.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  140  3  156.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  140  4  139.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  141  1  125.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  141  2  142.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  141  3  157.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  141  4  140.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  142  1  126.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  142  2  143.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  142  3  158.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  142  4  141.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  143  1  127.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  143  2  144.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  143  3  159.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  143  4  142.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  144  1  128.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  144  2  129.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  144  3  160.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  144  4  143.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  145  1  129.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  145  2  146.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  145  3  161.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  145  4  160.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  146  1  130.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  146  2  147.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  146  3  162.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  146  4  145.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  147  1  131.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  147  2  148.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  147  3  163.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  147  4  146.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  148  1  132.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  148  2  149.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  148  3  164.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  148  4  147.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  149  1  133.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  149  2  150.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  149  3  165.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  149  4  148.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  150  1  134.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  150  2  151.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  150  3  166.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  150  4  149.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  151  1  135.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  151  2  152.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  151  3  167.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  151  4  150.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  152  1  136.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  152  2  153.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  152  3  168.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  152  4  151.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  153  1  137.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  153  2  154.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  153  3  169.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  153  4  152.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  154  1  138.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  154  2  155.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  154  3  170.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  154  4  153.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  155  1  139.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  155  2  156.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  155  3  171.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  155  4  154.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  156  1  140.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  156  2  157.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  156  3  172.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  156  4  155.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  157  1  141.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  157  2  158.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  157  3  173.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  157  4  156.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  158  1  142.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  158  2  159.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  158  3  174.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  158  4  157.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  159  1  143.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  159  2  160.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  159  3  175.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  159  4  158.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  160  1  144.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  160  2  145.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  160  3  176.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  160  4  159.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  161  1  145.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  161  2  162.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  161  3  177.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  161  4  176.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  162  1  146.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  162  2  163.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  162  3  178.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  162  4  161.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  163  1  147.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  163  2  164.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  163  3  179.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  163  4  162.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  164  1  148.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  164  2  165.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  164  3  180.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  164  4  163.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  165  1  149.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  165  2  166.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  165  3  181.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  165  4  164.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  166  1  150.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  166  2  167.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  166  3  182.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  166  4  165.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  167  1  151.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  167  2  168.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  167  3  183.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  167  4  166.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  168  1  152.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  168  2  169.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  168  3  184.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  168  4  167.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  169  1  153.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  169  2  170.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  169  3  185.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  169  4  168.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  170  1  154.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  170  2  171.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  170  3  186.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  170  4  169.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  171  1  155.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  171  2  172.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  171  3  187.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  171  4  170.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  172  1  156.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  172  2  173.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  172  3  188.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  172  4  171.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  173  1  157.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  173  2  174.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  173  3  189.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  173  4  172.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  174  1  158.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  174  2  175.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  174  3  190.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  174  4  173.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  175  1  159.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  175  2  176.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  175  3  191.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  175  4  174.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  176  1  160.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  176  2  161.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  176  3  192.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  176  4  175.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  177  1  161.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  177  2  178.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  177  3  193.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  177  4  192.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  178  1  162.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  178  2  179.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  178  3  194.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  178  4  177.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  179  1  163.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  179  2  180.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  179  3  195.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  179  4  178.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  180  1  164.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  180  2  181.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  180  3  196.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  180  4  179.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  181  1  165.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  181  2  182.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  181  3  197.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  181  4  180.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  182  1  166.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  182  2  183.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  182  3  198.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  182  4  181.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  183  1  167.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  183  2  184.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  183  3  199.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  183  4  182.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  184  1  168.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  184  2  185.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  184  3  200.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  184  4  183.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  185  1  169.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  185  2  186.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  185  3  201.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  185  4  184.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  186  1  170.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  186  2  187.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  186  3  202.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  186  4  185.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  187  1  171.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  187  2  188.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  187  3  203.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  187  4  186.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  188  1  172.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  188  2  189.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  188  3  204.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  188  4  187.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  189  1  173.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  189  2  190.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  189  3  205.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  189  4  188.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  190  1  174.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  190  2  191.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  190  3  206.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  190  4  189.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  191  1  175.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  191  2  192.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  191  3  207.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  191  4  190.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  192  1  176.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  192  2  177.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  192  3  208.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  192  4  191.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  193  1  177.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  193  2  194.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  193  3  209.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  193  4  208.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  194  1  178.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  194  2  195.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  194  3  210.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  194  4  193.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  195  1  179.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  195  2  196.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  195  3  211.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  195  4  194.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  196  1  180.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  196  2  197.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  196  3  212.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  196  4  195.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  197  1  181.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  197  2  198.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  197  3  213.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  197  4  196.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  198  1  182.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  198  2  199.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  198  3  214.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  198  4  197.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  199  1  183.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  199  2  200.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  199  3  215.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  199  4  198.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  200  1  184.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  200  2  201.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  200  3  216.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  200  4  199.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  201  1  185.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  201  2  202.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  201  3  217.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  201  4  200.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  202  1  186.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  202  2  203.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  202  3  218.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  202  4  201.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  203  1  187.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  203  2  204.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  203  3  219.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  203  4  202.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  204  1  188.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  204  2  205.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  204  3  220.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  204  4  203.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  205  1  189.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  205  2  206.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  205  3  221.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  205  4  204.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  206  1  190.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  206  2  207.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  206  3  222.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  206  4  205.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  207  1  191.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  207  2  208.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  207  3  223.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  207  4  206.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  208  1  192.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  208  2  193.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  208  3  224.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  208  4  207.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  209  1  193.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  209  2  210.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  209  3  225.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  209  4  224.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  210  1  194.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  210  2  211.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  210  3  226.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  210  4  209.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  211  1  195.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  211  2  212.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  211  3  227.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  211  4  210.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  212  1  196.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  212  2  213.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  212  3  228.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  212  4  211.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  213  1  197.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  213  2  214.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  213  3  229.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  213  4  212.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  214  1  198.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  214  2  215.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  214  3  230.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  214  4  213.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  215  1  199.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  215  2  216.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  215  3  231.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  215  4  214.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  216  1  200.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  216  2  217.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  216  3  232.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  216  4  215.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  217  1  201.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  217  2  218.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  217  3  233.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  217  4  216.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  218  1  202.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  218  2  219.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  218  3  234.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  218  4  217.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  219  1  203.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  219  2  220.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  219  3  235.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  219  4  218.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  220  1  204.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  220  2  221.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  220  3  236.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  220  4  219.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  221  1  205.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  221  2  222.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  221  3  237.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  221  4  220.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  222  1  206.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  222  2  223.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  222  3  238.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  222  4  221.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  223  1  207.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  223  2  224.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  223  3  239.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  223  4  222.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  224  1  208.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  224  2  209.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  224  3  240.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  224  4  223.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  225  1  209.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  225  2  226.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  225  3  241.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  225  4  240.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  226  1  210.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  226  2  227.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  226  3  242.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  226  4  225.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  227  1  211.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  227  2  228.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  227  3  243.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  227  4  226.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  228  1  212.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  228  2  229.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  228  3  244.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  228  4  227.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  229  1  213.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  229  2  230.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  229  3  245.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  229  4  228.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  230  1  214.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  230  2  231.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  230  3  246.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  230  4  229.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  231  1  215.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  231  2  232.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  231  3  247.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  231  4  230.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  232  1  216.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  232  2  233.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  232  3  248.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  232  4  231.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  233  1  217.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  233  2  234.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  233  3  249.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  233  4  232.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  234  1  218.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  234  2  235.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  234  3  250.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  234  4  233.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  235  1  219.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  235  2  236.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  235  3  251.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  235  4  234.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  236  1  220.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  236  2  237.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  236  3  252.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  236  4  235.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  237  1  221.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  237  2  238.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  237  3  253.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  237  4  236.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  238  1  222.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  238  2  239.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  238  3  254.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  238  4  237.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  239  1  223.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  239  2  240.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  239  3  255.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  239  4  238.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  240  1  224.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  240  2  225.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  240  3  256.0000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  240  4  239.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  241  1  225.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  241  2  242.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  241  3  1.000000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  241  4  256.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  242  1  226.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  242  2  243.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  242  3  2.000000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  242  4  241.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  243  1  227.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  243  2  244.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  243  3  3.000000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  243  4  242.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  244  1  228.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  244  2  245.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  244  3  4.000000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  244  4  243.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  245  1  229.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  245  2  246.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  245  3  5.000000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  245  4  244.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  246  1  230.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  246  2  247.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  246  3  6.000000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  246  4  245.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  247  1  231.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  247  2  248.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  247  3  7.000000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  247  4  246.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  248  1  232.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  248  2  249.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  248  3  8.000000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  248  4  247.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  249  1  233.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  249  2  250.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  249  3  9.000000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  249  4  248.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  250  1  234.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  250  2  251.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  250  3  10.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  250  4  249.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  251  1  235.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  251  2  252.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  251  3  11.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  251  4  250.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  252  1  236.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  252  2  253.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  252  3  12.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  252  4  251.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  253  1  237.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  253  2  254.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  253  3  13.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  253  4  252.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  254  1  238.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  254  2  255.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  254  3  14.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  254  4  253.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  255  1  239.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  255  2  256.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  255  3  15.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  255  4  254.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  256  1  240.0000      3.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  256  2  241.0000      4.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 P  256  3  16.00000      1.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
 E  256  4  255.0000      2.000000     0.0000000E+00 0.0000000E+00 0.0000000E+00
  ***** NO THERMAL BOUNDARY CONDITIONS *****
            1 PRESOLVE/RESTART OPTIONS  *****
eddy_uv0.f00010 U p
            7         INITIAL CONDITIONS *****
C Default
C Default
C Default
C Default
C Default
C Default
C Default
  ***** DRIVE FORCE DATA ***** BODY FORCE, FLOW, Q
            4                 Lines of Drive force data follow
C
C
C
C
  ***** Variable Property Data ***** Overrrides Parameter data.
            1 Lines follow.
            0 PACKETS OF DATA FOLLOW
  ***** HISTORY AND INTEGRAL DATA *****
            0   POINTS.  Hcode, I,J,H,IEL
  ***** OUTPUT FIELD SPECIFICATION *****
            6 SPECIFICATIONS FOLLOW
  T      COORDINATES
  T      VELOCITY
  T      PRESSURE
  F      TEMPERATURE
  F      TEMPERATURE GRADIENT
            0      PASSIVE SCALARS
  ***** OBJECT SPECIFICATION *****
       0 Surface Objects
       0 Volume  Objects
       0 Edge    Objects
       0 Point   Objects
