[Nek5000-users] Nek5000-users Digest, Vol 78, Issue 9
Sat Aug 29 02:58:40 CDT 2015
Hi, all
sorry I have attached the wrong .rea file, the .rea file is renewed in
this mail.
To save
Sorry!!
On 08/29/2015 03:51 PM, Allen wrote:
> Hi, Phillip
> Thanks for your reply, but the dos2unix actually does not help. And I
> tried a lot to fix it up, including copy existing command from other
> examples .rea files to eliminate the error that might have something
> to do with the "CR and LF" stuff (I know little about these line breaks).
> I am in Ubuntu, should this this be due to the  failue of reading
> restart parameters?he
> I have attached the .rea file. It would  be greatly that you can have
> a look and give some advice.
> Thanks in advance.
> and have a nice weekend!
> from Allen
> On 08/29/2015 01:00 AM, nek5000-users-request at lists.mcs.anl.gov wrote:
>> Send Nek5000-users mailing list submissions to
>> To subscribe or unsubscribe via the World Wide Web, visit
>>     https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>>     nek5000-users-owner at lists.mcs.anl.gov
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of Nek5000-users digest..."
>> Today's Topics:
>>     1. restart a case got an error: Error reading initial
>>        condition/drive force data (nek5000-users at lists.mcs.anl.gov)
>>     2. Re: restart a case got an error: Error reading initial
>> Message: 1
>> Date: Fri, 28 Aug 2015 11:22:34 +0800
>> From: nek5000-users at lists.mcs.anl.gov
>> To: nek5000-users at lists.mcs.anl.gov
>> Subject: [Nek5000-users] restart a case got an error: Error reading
>>     initial condition/drive force data
>> Message-ID:
>>     <mailman.6382.1440732161.24727.nek5000-users at lists.mcs.anl.gov>
>> Content-Type: text/plain; charset="utf-8"; Format="flowed"
>> Hi, Nekers:
>> I recently want to do some simulation with Nek, so I followed the
>> tutorial for the eddy_uv case
>> I have run the case without problem, but when I want to try the restart
>> utility with the following modification instructed by the manual
>>               1 PRESOLVE/RESTART OPTIONS  *****
>> eddy_uv0.f00010
>> affter changing for a new case name and recompile, I started the restart
>> run, but the logfile gives the following error :
>>    mapping elements to processors
>>              2          86          86         256         256 NELV
>>              0          85          85         256         256 NELV
>>              1          85          85         256         256 NELV
>>    RANK     0 IEG     133     134     135     136     149 150 151
>> 152
>>                       161     162     165     166     167 168 177
>> 178
>>                       179     181     182     183     184 193 194
>> 195
>>                       196     197     198     199     200 201 202
>> 203
>>                       204     205     206     207     208 209 210
>> 211
>>                       212     213     214     215     216 217 218
>> 219
>>                       220     221     222     223     224 225 226
>> 227
>>                       228     229     230     231     232 233 234
>> 235
>>                       236     237     238     239     240 241 242
>> 243
>>                       244     245     246     247     248 249 250
>> 251
>>                       252     253     254     255     256
>>    element load imbalance:            1          85          86
>>    done :: mapping elements to processors
>>     Error reading initial condition/drive force data
>>     aborting in routine rdicdf.
>> EXIT: rdicdf error          1
>> call exitt: dying ...
>> backtrace(): obtained 9 stack frames.
>> ./nek5000(print_stack_+0x18) [0x500ff8]
>> ./nek5000(exitt_+0x1cc) [0x5be5ec]
>> ./nek5000(exitti_+0x117) [0x5c1537]
>> ./nek5000(rdicdf_+0x1e7) [0x442387]
>> ./nek5000(readat_+0x35f) [0x44951f]
>> ./nek5000(nek_init_+0x75) [0x41ae25]
>> ./nek5000(main+0x24) [0x419d84]
>> /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f26a5be276d]
>> ./nek5000() [0x419dc9]
>> I have searched the post list, but I only found very vague statement of
>> this
>> problem:_http://lists.mcs.anl.gov/pipermail/nek5000-users/2011-October/001560.html_
>> Hope some one can give me some hint, I actually do exactly what the
>> manual does, which makes me confused.
>> Thanks, hope it is a minor mistake.
>> from Allen
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL:
>> <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150828/06850988/attachment-0001.html>
>> Message: 2
>> Date: Fri, 28 Aug 2015 10:43:10 +0200
>> Subject: Re: [Nek5000-users] restart a case got an error: Error
>> Message-ID:
>>     <mailman.6397.1440751408.24727.nek5000-users at lists.mcs.anl.gov>
>> Content-Type: text/plain; charset=windows-1252; format=flowed
>> not sure it helps, but we had a similar problem recently when a rea file
>> went trough Windows and Linux, adding CR and LF as line breaks. As far
>> as I remember, using dos2unix of the file helped. Also, a tab character
>> (ASCII 9) somewhere on that line gave some problems.
>> Good luck,  Philipp
>> On 2015-08-28 05:22, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi, Nekers:
>>> eddy_uv0.f00010
>>> restart
>>> 151     152
>>> 177     178
>>> 194     195
>>> 202     203
>>> 210     211
>>> 218     219
>>> 226     227
>>> 234     235
>>> 242     243
>>> 250     251
>>>                       252     253     254     255     256
>>> [0x7f26a5be276d]
>>> this
>>> from Allen
>>> _______________________________________________
>>> Nek5000-users at lists.mcs.anl.gov
>> End of Nek5000-users Digest, Vol 78, Issue 9
 ****** PARAMETERS *****
    2.610000     NEKTON VERSION
            2 DIMENSIONAL RUN
          103 PARAMETERS FOLLOW
       1.000000         p01 DENSITY
      -20.00000         p02 VISCOS
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p07 RHOCP
       1.000000         p08 CONDUCT
      0.0000000E+00
      0.0000000E+00     p10 FINTIME
       2000.000         p11 NSTEPS
     -1.0000000E-04     p12 DT
      0.0000000E+00     p13 IOCOMM
      0.0000000E+00     p14 IOTIME
       100.0000         p15 IOSTEP
      0.0000000E+00     p16 PSSOLVER
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      1.0000000E-11     p21 DIVERGENCE
      1.0000000E-12     p22 HELMHOLTZ
      0.0000000E+00     p23 NPSCAL
      1.0000000E-10     p24 TOLREL
      1.0000000E-10     p25 TOLABS
       1.000000         p26 COURANT/NTAU
       3.000000         p27 TORDER
      0.0000000E+00     p28 TORDER: mesh velocity (0: p28=p27)
      0.0000000E+00     p29 magnetic visc if > 0, = -1/Rm if < 0
      0.0000000E+00     p30 > 0 ==> properties set in uservp()
      0.0000000E+00     p31 NPERT: #perturbation modes
      0.0000000E+00     p32 #BCs in re2 file, if > 0
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p42 0=gmres/1=pcg
       1.000000         p43 0=semg/1=schwarz
      0.0000000E+00     p44 0=E-based/1=A-based prec.
      0.0000000E+00     p45 Relaxation factor for DTFS
      0.0000000E+00      p46 if >0, dont call SETICS
      0.0000000E+00     p47 vnu: mesh matieral prop
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p52 IOHIS
      0.0000000E+00
      0.0000000E+00     p54 1,2,3-->fixed flow rate dir=x,y,z
      0.0000000E+00     p55 vol.flow rate(p54>0) or Ubar(p54<0)
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p59 !=0 --> use std axhelm for all elem
      0.0000000E+00     p60 !=0--> init velocity to small nonzero
      0.0000000E+00
      0.0000000E+00     p62 >0 --> force byte_swap for output
      0.0000000E+00     p63 =8 --> force 8-byte output
      0.0000000E+00     p64 =1 --> perturbation restart
      0.0000000E+00     p65 #iofile(eg,0 or 64); <0 --> sep. dirs
       6.000000         p66 write fmt:ONLY postx uses rea value
       6.000000         p67 read fmt: same modes as p66
      0.0000000E+00     p68 iastep: freq for avg_all
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p74 verbose Helmholtz
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p84 !=0 -->sets initial timestep if p12>0
      0.0000000E+00     p85 dt ratio if p84 !=0, for timesteps>0
      0.0000000E+00     p86 reserved
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p89 reserved
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
       20.00000         p93 Numbr of prev pressure solns saved
       5.000000         p94 start projecting vel. after p94 step
       5.000000         p95 start projecting pr after p95 step
       1.00000          p96 u0 translational velocity (in .usr)
        0.30000          p97 v0 translational velocity (in .usr)
      0.0000000E+00
       3.000000         p99    dealiasing:if <0 disable
      0.0000000E+00     p100 reserved
      0.0000000E+00     p101   No. of additional filter modes
      0.0000000E+00
      0.0000000E+00     p103   weight of stabilizing filter (.01)
      4  Lines of passive scalar data follows2 CONDUCT; 2RHOCP
   1.00000       1.00000       1.00000       1.00000       1.00000
           13  LOGICAL SWITCHES FOLLOW
  T     IFFLOW
  F     IFHEAT
  T     IFTRAN
  T F F F F F F F F F F IFNAV & IFADVC (convection in P.S. fields)
  F F T T T T T T T T T T IFTMSH (IF mesh for this field is T mesh)
  F     IFAXIS
  F     IFSTRS
  F     IFSPLIT
  F     IFMGRID
  F     IFMODEL
  F     IFKEPS
  F     IFMVBD
  F     IFCHAR
   8.00000       8.00000     -0.500000      -4.00000     XFAC,YFAC,XZERO,YZERO
 **MESH DATA** 1st line is X of corner 1,2,3,4. 2nd line is Y.
   256     2   256           NEL,NDIM,NELV
            ELEMENT    1 [    1a]    GROUP     0
  0.0000000E+00  6.2500000E-02  6.2500000E-02  0.0000000E+00
  0.0000000E+00  0.0000000E+00  6.2500000E-02  6.2500000E-02
            ELEMENT    2 [    1b]    GROUP     0
  6.2500000E-02  1.2500000E-01  1.2500000E-01  6.2500000E-02
            ELEMENT    3 [    1c]    GROUP     0
  1.2500000E-01  1.8750000E-01  1.8750000E-01  1.2500000E-01
            ELEMENT    4 [    1d]    GROUP     0
  1.8750000E-01  2.5000000E-01  2.5000000E-01  1.8750000E-01
            ELEMENT    5 [    1e]    GROUP     0
  2.5000000E-01  3.1250000E-01  3.1250000E-01  2.5000000E-01
            ELEMENT    6 [    1f]    GROUP     0
  3.1250000E-01  3.7500000E-01  3.7500000E-01  3.1250000E-01
            ELEMENT    7 [    1g]    GROUP     0
  3.7500000E-01  4.3750000E-01  4.3750000E-01  3.7500000E-01
            ELEMENT    8 [    1h]    GROUP     0
  4.3750000E-01  5.0000000E-01  5.0000000E-01  4.3750000E-01
            ELEMENT    9 [    1i]    GROUP     0
  5.0000000E-01  5.6250000E-01  5.6250000E-01  5.0000000E-01
            ELEMENT   10 [    1j]    GROUP     0
  5.6250000E-01  6.2500000E-01  6.2500000E-01  5.6250000E-01
            ELEMENT   11 [    1k]    GROUP     0
  6.2500000E-01  6.8750000E-01  6.8750000E-01  6.2500000E-01
            ELEMENT   12 [    1l]    GROUP     0
  6.8750000E-01  7.5000000E-01  7.5000000E-01  6.8750000E-01
            ELEMENT   13 [    1m]    GROUP     0
  7.5000000E-01  8.1250000E-01  8.1250000E-01  7.5000000E-01
            ELEMENT   14 [    1n]    GROUP     0
  8.1250000E-01  8.7500000E-01  8.7500000E-01  8.1250000E-01
            ELEMENT   15 [    1o]    GROUP     0
  8.7500000E-01  9.3750000E-01  9.3750000E-01  8.7500000E-01
            ELEMENT   16 [    1p]    GROUP     0
  9.3750000E-01  1.0000000E+00  1.0000000E+00  9.3750000E-01
            ELEMENT   17 [    1q]    GROUP     0
  6.2500000E-02  6.2500000E-02  1.2500000E-01  1.2500000E-01
            ELEMENT   18 [    1r]    GROUP     0
            ELEMENT   19 [    1s]    GROUP     0
            ELEMENT   20 [    1t]    GROUP     0
            ELEMENT   21 [    1u]    GROUP     0
            ELEMENT   22 [    1v]    GROUP     0
            ELEMENT   23 [    1w]    GROUP     0
            ELEMENT   24 [    1x]    GROUP     0
            ELEMENT   25 [    1y]    GROUP     0
            ELEMENT   26 [    1z]    GROUP     0
            ELEMENT   27 [    1A]    GROUP     0
            ELEMENT   28 [    1B]    GROUP     0
            ELEMENT   29 [    1C]    GROUP     0
            ELEMENT   30 [    1D]    GROUP     0
            ELEMENT   31 [    1E]    GROUP     0
            ELEMENT   32 [    1F]    GROUP     0
            ELEMENT   33 [    1G]    GROUP     0
  1.2500000E-01  1.2500000E-01  1.8750000E-01  1.8750000E-01
            ELEMENT   34 [    1H]    GROUP     0
            ELEMENT   35 [    1I]    GROUP     0
            ELEMENT   36 [    1J]    GROUP     0
            ELEMENT   37 [    1K]    GROUP     0
            ELEMENT   38 [    1L]    GROUP     0
            ELEMENT   39 [    1M]    GROUP     0
            ELEMENT   40 [    1N]    GROUP     0
            ELEMENT   41 [    1O]    GROUP     0
            ELEMENT   42 [    1P]    GROUP     0
            ELEMENT   43 [    1Q]    GROUP     0
            ELEMENT   44 [    1R]    GROUP     0
            ELEMENT   45 [    1S]    GROUP     0
            ELEMENT   46 [    1T]    GROUP     0
            ELEMENT   47 [    1U]    GROUP     0
            ELEMENT   48 [    1V]    GROUP     0
            ELEMENT   49 [    1W]    GROUP     0
  1.8750000E-01  1.8750000E-01  2.5000000E-01  2.5000000E-01
            ELEMENT   50 [    1X]    GROUP     0
            ELEMENT   51 [    1Y]    GROUP     0
            ELEMENT   52 [    1Z]    GROUP     0
            ELEMENT   53 [    1a]    GROUP     0
            ELEMENT   54 [    1b]    GROUP     0
            ELEMENT   55 [    1c]    GROUP     0
            ELEMENT   56 [    1d]    GROUP     0
            ELEMENT   57 [    1e]    GROUP     0
            ELEMENT   58 [    1f]    GROUP     0
            ELEMENT   59 [    1g]    GROUP     0
            ELEMENT   60 [    1h]    GROUP     0
            ELEMENT   61 [    1i]    GROUP     0
            ELEMENT   62 [    1j]    GROUP     0
            ELEMENT   63 [    1k]    GROUP     0
            ELEMENT   64 [    1l]    GROUP     0
            ELEMENT   65 [    1m]    GROUP     0
  2.5000000E-01  2.5000000E-01  3.1250000E-01  3.1250000E-01
            ELEMENT   66 [    1n]    GROUP     0
            ELEMENT   67 [    1o]    GROUP     0
            ELEMENT   68 [    1p]    GROUP     0
            ELEMENT   69 [    1q]    GROUP     0
            ELEMENT   70 [    1r]    GROUP     0
            ELEMENT   71 [    1s]    GROUP     0
            ELEMENT   72 [    1t]    GROUP     0
            ELEMENT   73 [    1u]    GROUP     0
            ELEMENT   74 [    1v]    GROUP     0
            ELEMENT   75 [    1w]    GROUP     0
            ELEMENT   76 [    1x]    GROUP     0
            ELEMENT   77 [    1y]    GROUP     0
            ELEMENT   78 [    1z]    GROUP     0
            ELEMENT   79 [    1A]    GROUP     0
            ELEMENT   80 [    1B]    GROUP     0
            ELEMENT   81 [    1C]    GROUP     0
  3.1250000E-01  3.1250000E-01  3.7500000E-01  3.7500000E-01
            ELEMENT   82 [    1D]    GROUP     0
            ELEMENT   83 [    1E]    GROUP     0
            ELEMENT   84 [    1F]    GROUP     0
            ELEMENT   85 [    1G]    GROUP     0
            ELEMENT   86 [    1H]    GROUP     0
            ELEMENT   87 [    1I]    GROUP     0
            ELEMENT   88 [    1J]    GROUP     0
            ELEMENT   89 [    1K]    GROUP     0
            ELEMENT   90 [    1L]    GROUP     0
            ELEMENT   91 [    1M]    GROUP     0
            ELEMENT   92 [    1N]    GROUP     0
            ELEMENT   93 [    1O]    GROUP     0
            ELEMENT   94 [    1P]    GROUP     0
            ELEMENT   95 [    1Q]    GROUP     0
            ELEMENT   96 [    1R]    GROUP     0
            ELEMENT   97 [    1S]    GROUP     0
  3.7500000E-01  3.7500000E-01  4.3750000E-01  4.3750000E-01
            ELEMENT   98 [    1T]    GROUP     0
            ELEMENT   99 [    1U]    GROUP     0
            ELEMENT  100 [    1V]    GROUP     0
            ELEMENT  101 [    1W]    GROUP     0
            ELEMENT  102 [    1X]    GROUP     0
            ELEMENT  103 [    1Y]    GROUP     0
            ELEMENT  104 [    1Z]    GROUP     0
            ELEMENT  105 [    1a]    GROUP     0
            ELEMENT  106 [    1b]    GROUP     0
            ELEMENT  107 [    1c]    GROUP     0
            ELEMENT  108 [    1d]    GROUP     0
            ELEMENT  109 [    1e]    GROUP     0
            ELEMENT  110 [    1f]    GROUP     0
            ELEMENT  111 [    1g]    GROUP     0
            ELEMENT  112 [    1h]    GROUP     0
            ELEMENT  113 [    1i]    GROUP     0
  4.3750000E-01  4.3750000E-01  5.0000000E-01  5.0000000E-01
            ELEMENT  114 [    1j]    GROUP     0
            ELEMENT  115 [    1k]    GROUP     0
            ELEMENT  116 [    1l]    GROUP     0
            ELEMENT  117 [    1m]    GROUP     0
            ELEMENT  118 [    1n]    GROUP     0
            ELEMENT  119 [    1o]    GROUP     0
            ELEMENT  120 [    1p]    GROUP     0
            ELEMENT  121 [    1q]    GROUP     0
            ELEMENT  122 [    1r]    GROUP     0
            ELEMENT  123 [    1s]    GROUP     0
            ELEMENT  124 [    1t]    GROUP     0
            ELEMENT  125 [    1u]    GROUP     0
            ELEMENT  126 [    1v]    GROUP     0
            ELEMENT  127 [    1w]    GROUP     0
            ELEMENT  128 [    1x]    GROUP     0
            ELEMENT  129 [    1y]    GROUP     0
  5.0000000E-01  5.0000000E-01  5.6250000E-01  5.6250000E-01
            ELEMENT  130 [    1z]    GROUP     0
            ELEMENT  131 [    1A]    GROUP     0
            ELEMENT  132 [    1B]    GROUP     0
            ELEMENT  133 [    1C]    GROUP     0
            ELEMENT  134 [    1D]    GROUP     0
            ELEMENT  135 [    1E]    GROUP     0
            ELEMENT  136 [    1F]    GROUP     0
            ELEMENT  137 [    1G]    GROUP     0
            ELEMENT  138 [    1H]    GROUP     0
            ELEMENT  139 [    1I]    GROUP     0
            ELEMENT  140 [    1J]    GROUP     0
            ELEMENT  141 [    1K]    GROUP     0
            ELEMENT  142 [    1L]    GROUP     0
            ELEMENT  143 [    1M]    GROUP     0
            ELEMENT  144 [    1N]    GROUP     0
            ELEMENT  145 [    1O]    GROUP     0
  5.6250000E-01  5.6250000E-01  6.2500000E-01  6.2500000E-01
            ELEMENT  146 [    1P]    GROUP     0
            ELEMENT  147 [    1Q]    GROUP     0
            ELEMENT  148 [    1R]    GROUP     0
            ELEMENT  149 [    1S]    GROUP     0
            ELEMENT  150 [    1T]    GROUP     0
            ELEMENT  151 [    1U]    GROUP     0
            ELEMENT  152 [    1V]    GROUP     0
            ELEMENT  153 [    1W]    GROUP     0
            ELEMENT  154 [    1X]    GROUP     0
            ELEMENT  155 [    1Y]    GROUP     0
            ELEMENT  156 [    1Z]    GROUP     0
            ELEMENT  157 [    1a]    GROUP     0
            ELEMENT  158 [    1b]    GROUP     0
            ELEMENT  159 [    1c]    GROUP     0
            ELEMENT  160 [    1d]    GROUP     0
            ELEMENT  161 [    1e]    GROUP     0
  6.2500000E-01  6.2500000E-01  6.8750000E-01  6.8750000E-01
            ELEMENT  162 [    1f]    GROUP     0
            ELEMENT  163 [    1g]    GROUP     0
            ELEMENT  164 [    1h]    GROUP     0
            ELEMENT  165 [    1i]    GROUP     0
            ELEMENT  166 [    1j]    GROUP     0
            ELEMENT  167 [    1k]    GROUP     0
            ELEMENT  168 [    1l]    GROUP     0
            ELEMENT  169 [    1m]    GROUP     0
            ELEMENT  170 [    1n]    GROUP     0
            ELEMENT  171 [    1o]    GROUP     0
            ELEMENT  172 [    1p]    GROUP     0
            ELEMENT  173 [    1q]    GROUP     0
            ELEMENT  174 [    1r]    GROUP     0
            ELEMENT  175 [    1s]    GROUP     0
            ELEMENT  176 [    1t]    GROUP     0
            ELEMENT  177 [    1u]    GROUP     0
  6.8750000E-01  6.8750000E-01  7.5000000E-01  7.5000000E-01
            ELEMENT  178 [    1v]    GROUP     0
            ELEMENT  179 [    1w]    GROUP     0
            ELEMENT  180 [    1x]    GROUP     0
            ELEMENT  181 [    1y]    GROUP     0
            ELEMENT  182 [    1z]    GROUP     0
            ELEMENT  183 [    1A]    GROUP     0
            ELEMENT  184 [    1B]    GROUP     0
            ELEMENT  185 [    1C]    GROUP     0
            ELEMENT  186 [    1D]    GROUP     0
            ELEMENT  187 [    1E]    GROUP     0
            ELEMENT  188 [    1F]    GROUP     0
            ELEMENT  189 [    1G]    GROUP     0
            ELEMENT  190 [    1H]    GROUP     0
            ELEMENT  191 [    1I]    GROUP     0
            ELEMENT  192 [    1J]    GROUP     0
            ELEMENT  193 [    1K]    GROUP     0
  7.5000000E-01  7.5000000E-01  8.1250000E-01  8.1250000E-01
            ELEMENT  194 [    1L]    GROUP     0
            ELEMENT  195 [    1M]    GROUP     0
            ELEMENT  196 [    1N]    GROUP     0
            ELEMENT  197 [    1O]    GROUP     0
            ELEMENT  198 [    1P]    GROUP     0
            ELEMENT  199 [    1Q]    GROUP     0
            ELEMENT  200 [    1R]    GROUP     0
            ELEMENT  201 [    1S]    GROUP     0
            ELEMENT  202 [    1T]    GROUP     0
            ELEMENT  203 [    1U]    GROUP     0
            ELEMENT  204 [    1V]    GROUP     0
            ELEMENT  205 [    1W]    GROUP     0
            ELEMENT  206 [    1X]    GROUP     0
            ELEMENT  207 [    1Y]    GROUP     0
            ELEMENT  208 [    1Z]    GROUP     0
            ELEMENT  209 [    1a]    GROUP     0
  8.1250000E-01  8.1250000E-01  8.7500000E-01  8.7500000E-01
            ELEMENT  210 [    1b]    GROUP     0
            ELEMENT  211 [    1c]    GROUP     0
            ELEMENT  212 [    1d]    GROUP     0
            ELEMENT  213 [    1e]    GROUP     0
            ELEMENT  214 [    1f]    GROUP     0
            ELEMENT  215 [    1g]    GROUP     0
            ELEMENT  216 [    1h]    GROUP     0
            ELEMENT  217 [    1i]    GROUP     0
            ELEMENT  218 [    1j]    GROUP     0
            ELEMENT  219 [    1k]    GROUP     0
            ELEMENT  220 [    1l]    GROUP     0
            ELEMENT  221 [    1m]    GROUP     0
            ELEMENT  222 [    1n]    GROUP     0
            ELEMENT  223 [    1o]    GROUP     0
            ELEMENT  224 [    1p]    GROUP     0
            ELEMENT  225 [    1q]    GROUP     0
  8.7500000E-01  8.7500000E-01  9.3750000E-01  9.3750000E-01
            ELEMENT  226 [    1r]    GROUP     0
            ELEMENT  227 [    1s]    GROUP     0
            ELEMENT  228 [    1t]    GROUP     0
            ELEMENT  229 [    1u]    GROUP     0
            ELEMENT  230 [    1v]    GROUP     0
            ELEMENT  231 [    1w]    GROUP     0
            ELEMENT  232 [    1x]    GROUP     0
            ELEMENT  233 [    1y]    GROUP     0
            ELEMENT  234 [    1z]    GROUP     0
            ELEMENT  235 [    1A]    GROUP     0
            ELEMENT  236 [    1B]    GROUP     0
            ELEMENT  237 [    1C]    GROUP     0
            ELEMENT  238 [    1D]    GROUP     0
            ELEMENT  239 [    1E]    GROUP     0
            ELEMENT  240 [    1F]    GROUP     0
            ELEMENT  241 [    1G]    GROUP     0
  9.3750000E-01  9.3750000E-01  1.0000000E+00  1.0000000E+00
            ELEMENT  242 [    1H]    GROUP     0
            ELEMENT  243 [    1I]    GROUP     0
            ELEMENT  244 [    1J]    GROUP     0
            ELEMENT  245 [    1K]    GROUP     0
            ELEMENT  246 [    1L]    GROUP     0
            ELEMENT  247 [    1M]    GROUP     0
            ELEMENT  248 [    1N]    GROUP     0
            ELEMENT  249 [    1O]    GROUP     0
            ELEMENT  250 [    1P]    GROUP     0
            ELEMENT  251 [    1Q]    GROUP     0
            ELEMENT  252 [    1R]    GROUP     0
            ELEMENT  253 [    1S]    GROUP     0
            ELEMENT  254 [    1T]    GROUP     0
            ELEMENT  255 [    1U]    GROUP     0
            ELEMENT  256 [    1V]    GROUP     0
  ***** CURVED SIDE DATA *****
     0 Curved sides follow IEDGE,IEL,CURVE(I),I=1,5, CCURVE
  ***** BOUNDARY CONDITIONS *****
  ***** FLUID   BOUNDARY CONDITIONS *****
  ***** NO THERMAL BOUNDARY CONDITIONS *****
eddy_uv0.f00010 U p
            7         INITIAL CONDITIONS *****
C Default
C Default
C Default
C Default
C Default
C Default
C Default
  ***** DRIVE FORCE DATA ***** BODY FORCE, FLOW, Q
            4                 Lines of Drive force data follow
C
C
C
C
  ***** Variable Property Data ***** Overrrides Parameter data.
            1 Lines follow.
            0 PACKETS OF DATA FOLLOW
  ***** HISTORY AND INTEGRAL DATA *****
            0   POINTS.  Hcode, I,J,H,IEL
  ***** OUTPUT FIELD SPECIFICATION *****
            6 SPECIFICATIONS FOLLOW
  T      COORDINATES
  T      VELOCITY
  T      PRESSURE
  F      TEMPERATURE
  F      TEMPERATURE GRADIENT
            0      PASSIVE SCALARS
  ***** OBJECT SPECIFICATION *****
       0 Surface Objects
       0 Volume  Objects
       0 Edge    Objects
       0 Point   Objects
