[Nek5000-users] Nek5000-users Digest, Vol 78, Issue 9
Sun Aug 30 10:34:15 CDT 2015
hi,
I looked at the rea file, and I see that the whole part about boundary
conditions is missing:
   ***** FLUID   BOUNDARY CONDITIONS *****
  P    1  1  241.0000      3.000000     0.0000000E+00 0.0000000E+00
0.0000000E+00
  E    1  2  2.000000      4.000000     0.0000000E+00 0.0000000E+00
0.0000000E+00
  E    1  3  17.00000      1.000000     0.0000000E+00 0.0000000E+00
0.0000000E+00
  P    1  4  16.00000      2.000000     0.0000000E+00 0.0000000E+00
0.0000000E+00
This is what causes the error that you cite below. Then, the line to
load the restart file should be similar to the following:
             1 PRESOLVE/RESTART OPTIONS  *****
eddy_uv0.f00001
Then it should work.
Best regards,
Philipp
Quoting nek5000-users at lists.mcs.anl.gov:
> Hi, all
> sorry I have attached the wrong .rea file, the .rea file is renewed
> in this mail.
> To save
> Sorry!!
> On 08/29/2015 03:51 PM, Allen wrote:
>> Hi, Phillip
>> Thanks for your reply, but the dos2unix actually does not help. And
>> I tried a lot to fix it up, including copy existing command from
>> other examples .rea files to eliminate the error that might have
>> something to do with the "CR and LF" stuff (I know little about
>> these line breaks).
>> I am in Ubuntu, should this this be due to the  failue of reading
>> restart parameters?he
>> I have attached the .rea file. It would  be greatly that you can
>> have a look and give some advice.
>> Thanks in advance.
>> and have a nice weekend!
>> from Allen
>> On 08/29/2015 01:00 AM, nek5000-users-request at lists.mcs.anl.gov wrote:
>>> Send Nek5000-users mailing list submissions to
>>> To subscribe or unsubscribe via the World Wide Web, visit
>>>    https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>> or, via email, send a message with subject or body 'help' to
>>> You can reach the person managing the list at
>>>    nek5000-users-owner at lists.mcs.anl.gov
>>> When replying, please edit your Subject line so it is more specific
>>> than "Re: Contents of Nek5000-users digest..."
>>> Today's Topics:
>>>    1. restart a case got an error: Error reading initial
>>>       condition/drive force data (nek5000-users at lists.mcs.anl.gov)
>>>    2. Re: restart a case got an error: Error reading initial
>>> Message: 1
>>> Date: Fri, 28 Aug 2015 11:22:34 +0800
>>> From: nek5000-users at lists.mcs.anl.gov
>>> To: nek5000-users at lists.mcs.anl.gov
>>> Subject: [Nek5000-users] restart a case got an error: Error reading
>>>    initial condition/drive force data
>>> Message-ID:
>>>    <mailman.6382.1440732161.24727.nek5000-users at lists.mcs.anl.gov>
>>> Content-Type: text/plain; charset="utf-8"; Format="flowed"
>>> Hi, Nekers:
>>> I recently want to do some simulation with Nek, so I followed the
>>> tutorial for the eddy_uv case
>>> I have run the case without problem, but when I want to try the restart
>>> utility with the following modification instructed by the manual
>>> -----------------------------------------------------------------------------               1 PRESOLVE/RESTART OPTIONS
>>> eddy_uv0.f00010
>>> ----------------------------------------------------------------------------- affter changing for a new case name and recompile, I started the
>>> restart
>>> run, but the logfile gives the following error :
>>> -----------------------------------------------------------------------------    mapping elements to
>>> processors
>>>             2          86          86         256         256 NELV
>>>             0          85          85         256         256 NELV
>>>             1          85          85         256         256 NELV
>>>   RANK     0 IEG     133     134     135     136     149 150 151     152
>>>                      161     162     165     166     167 168 177     178
>>>                      179     181     182     183     184 193 194     195
>>>                      196     197     198     199     200 201 202     203
>>>                      204     205     206     207     208 209 210     211
>>>                      212     213     214     215     216 217 218     219
>>>                      220     221     222     223     224 225 226     227
>>>                      228     229     230     231     232 233 234     235
>>>                      236     237     238     239     240 241 242     243
>>>                      244     245     246     247     248 249 250     251
>>>                      252     253     254     255     256
>>>   element load imbalance:            1          85          86
>>>   done :: mapping elements to processors
>>>    Error reading initial condition/drive force data
>>>    aborting in routine rdicdf.
>>> EXIT: rdicdf error          1
>>> call exitt: dying ...
>>> backtrace(): obtained 9 stack frames.
>>> ./nek5000(print_stack_+0x18) [0x500ff8]
>>> ./nek5000(exitt_+0x1cc) [0x5be5ec]
>>> ./nek5000(exitti_+0x117) [0x5c1537]
>>> ./nek5000(rdicdf_+0x1e7) [0x442387]
>>> ./nek5000(readat_+0x35f) [0x44951f]
>>> ./nek5000(nek_init_+0x75) [0x41ae25]
>>> ./nek5000(main+0x24) [0x419d84]
>>> /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f26a5be276d]
>>> ./nek5000() [0x419dc9]
>>> -------------------------------------------------------------------------------------------------------------------- I have searched the post list, but I only found very vague statement
>>> of
>>> this
>>> problem:_http://lists.mcs.anl.gov/pipermail/nek5000-users/2011-October/001560.html_ Hope some one can give me some hint, I actually do exactly what
>>> the
>>> manual does, which makes me confused.
>>> Thanks, hope it is a minor mistake.
>>> from Allen
>>> -------------- next part --------------
>>> An HTML attachment was scrubbed...
>>> URL:
>>> <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20150828/06850988/attachment-0001.html>
>>> Message: 2
>>> Date: Fri, 28 Aug 2015 10:43:10 +0200
>>> Subject: Re: [Nek5000-users] restart a case got an error: Error
>>> Message-ID:
>>>    <mailman.6397.1440751408.24727.nek5000-users at lists.mcs.anl.gov>
>>> Content-Type: text/plain; charset=windows-1252; format=flowed
>>> not sure it helps, but we had a similar problem recently when a rea file
>>> went trough Windows and Linux, adding CR and LF as line breaks. As far
>>> as I remember, using dos2unix of the file helped. Also, a tab character
>>> (ASCII 9) somewhere on that line gave some problems.
>>> Good luck,  Philipp
>>> On 2015-08-28 05:22, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi, Nekers:
>>>> eddy_uv0.f00010
>>>> restart
>>>> processors
>>>>                      252     253     254     255     256
>>>> of
>>>> this
>>>> the
>>>> from Allen
>>>> _______________________________________________
>>>> Nek5000-users at lists.mcs.anl.gov
>>> End of Nek5000-users Digest, Vol 78, Issue 9
