[Nek5000-users] restart a case got an error: Error reading initial condition/drive force data
Fri Aug 28 03:43:10 CDT 2015
not sure it helps, but we had a similar problem recently when a rea file
went trough Windows and Linux, adding CR and LF as line breaks. As far
as I remember, using dos2unix of the file helped. Also, a tab character
(ASCII 9) somewhere on that line gave some problems.
Good luck,  Philipp
On 2015-08-28 05:22, nek5000-users at lists.mcs.anl.gov wrote:
> Hi, Nekers:
> I recently want to do some simulation with Nek, so I followed the
> tutorial for the eddy_uv case
> I have run the case without problem, but when I want to try the restart
> utility with the following modification instructed by the manual
>              1 PRESOLVE/RESTART OPTIONS  *****
> eddy_uv0.f00010
> affter changing for a new case name and recompile, I started the restart
> run, but the logfile gives the following error :
>   mapping elements to processors
>             2          86          86         256         256  NELV
>             0          85          85         256         256  NELV
>             1          85          85         256         256  NELV
>   RANK     0 IEG     133     134     135     136     149     150 151     152
>                      161     162     165     166     167     168 177     178
>                      179     181     182     183     184     193 194     195
>                      196     197     198     199     200     201 202     203
>                      204     205     206     207     208     209 210     211
>                      212     213     214     215     216     217 218     219
>                      220     221     222     223     224     225 226     227
>                      228     229     230     231     232     233 234     235
>                      236     237     238     239     240     241 242     243
>                      244     245     246     247     248     249 250     251
>                      252     253     254     255     256
>   element load imbalance:            1          85          86
>   done :: mapping elements to processors
>    aborting in routine rdicdf.
> EXIT: rdicdf error          1
> call exitt: dying ...
> backtrace(): obtained 9 stack frames.
> ./nek5000(print_stack_+0x18) [0x500ff8]
> ./nek5000(exitt_+0x1cc) [0x5be5ec]
> ./nek5000(exitti_+0x117) [0x5c1537]
> ./nek5000(rdicdf_+0x1e7) [0x442387]
> ./nek5000(readat_+0x35f) [0x44951f]
> ./nek5000(nek_init_+0x75) [0x41ae25]
> ./nek5000(main+0x24) [0x419d84]
> /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f26a5be276d]
> ./nek5000() [0x419dc9]
> I have searched the post list, but I only found very vague statement of
> this
> problem:_http://lists.mcs.anl.gov/pipermail/nek5000-users/2011-October/001560.html_
> Hope some one can give me some hint, I actually do exactly what the
> manual does, which makes me confused.
> Thanks, hope it is a minor mistake.
> from Allen
> Nek5000-users mailing list
