[Nek5000-users] MPI_TAG_UB too small
Fri Apr 3 11:04:16 CDT 2015
Dear all,
indeed, we have experienced the same problem with the recent Cray MPI
Library; the maximum tag size was reduced to 2**21 (the MPI standard
requires 2^16, but most libraries have 2^32). The problem in Nek is that
in the initial distribution of the mesh and velocities onto the
processors, the element number is used as a message tag, which obviously
fails if you have more than 2**21 elements. The check you mention
(nval.lt.(10000+max(lp,lelg)) is exactly checking that (mpi_dummf.f is
only used in serial runs, in parallel runs mpi_attr_get is a routine
provided by the current mpi library and returns the maximum tag number
of the implementation).
Anyway, we have recently fixed this problem by changing the way the tag
is used (local element number vs global one). Maybe the easiest would be
to merge these changes in the repo? Otherwise, I can also send the
changed files, but then of course one has to be careful to have matching
revisions.
Best regards,
Philipp
On 2015-04-03 14:04, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Neks,
> I'm having a problem running my simulation with thousands of processors.
> In my case, I have 6090000 elements and I ran the simulation with 8520
> procs. However, the simulation aborted with the error message
> 'MPI_TAG_UB too small'.
> I checked the code and found that if "nval.lt.(10000+max(lp,lelg))", the
> simulation would abort. But in the subroutine 'mpi_attr_get', ival is
> set to be 9999999. In this case, nval should be larger than
> 10000+max(lp,lelg). So, why did the simulation not run?
> Hope anyone can help me on this. Thank you very much.
> Best regards,
> Tony
> Nek5000-users mailing list
