[Nek5000-users] Parallel issue: Inflow conditions from external files
Sat Sep 27 08:31:01 CDT 2014
Dear All,
You need to understand something about distributed memory parallel computing to
be able to read files.
My suggestion would be to write your file into the .fld or f0000 format and restart from that,
since Nek provides a parallel read.
Otherwise, you have to think carefully about the reading process, whether you have
enough memory per node for a since process to read the file, whether it will take so
long that you need parallel I/O, etc.   There is not a one-size-fits all solution (save for
the above suggestion) because for small files it's possible to write something in 10 minutes
whereas for large files much more sophistication is required in order to meet the
time and memory constraints.
If you want to read a small file, you would do something like:
      common /scrns/ u(lx1,ly1,lz1,lelg),work(lx1,ly1,lz1,lelg)
      if (istep.eq.0) then
         nxyz = nx1*ny1*nz1
         n = nelgv*nxyz
         call rzero(u,n)   ! zero-out u on all processors
         if (nid.eq.0) then
            read(44,*) (u(k),k=1,n)
         endif
         call gop(u,work,'+  ',n)  ! add result across all processors
         do e=1,nelv
              eg = lglel(e)
              call copy(vx(1,1,1,e),u(1,1,1,eg),nxyz)
         enddo
...The danger here is that it is slow (because it is serial) and that
you run out memory because you are allocating memory that is
the size of the entire problem (i.e., not size-of-problem divided by P,
the number of processors).
For small processor counts it might be ok.... depending on how
big the simulation etc.
If you take this approach, however, it will not scale when you start running
serious simulations.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Friday, September 26, 2014 5:52 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Parallel issue: Inflow conditions from external files
Did you manage to solve the problem? I also have the same problem... I
am able to read velocity data and to set them as initial condition in
serial, but in parallel it is not working... The velocity is mapped to
nodes that are not the proper ones...
What is wrong?
Thanks!
SL
El 10-09-2014 13:08, nek5000-users at lists.mcs.anl.gov escribió:
> Hi all,
> I have a question on how to read in information from external files as
> an inflow boundary condition when running in parallel.
> Similar problem to this:
> http://lists.mcs.anl.gov/pipermail/nek5000-users/2010-December/001151.html
> [1]
> My geometry is a simple 3D rectangle prism with the inlet on the Y-Z
> plane @ x=0.
> I have developed some code that reads in a 2D plane of velocity data
> from another simulation (in this case fluent) as the boundary
> condition in userbc(). I am happy to share the process and the code
> (Fortran input/output from NEK, and MATLAB to do interpolation)
> however here I am primarily focused on getting it working in parallel.
> The process works fine in serial - it reads in 3 files (01.dat,
> 02.dat, 03.dat) that hold the x,y,z velocity (respectively) for each
> node on the inlet.
> However it does not work correctly when running in parallel - looking
> at the results after a few iterations shows that the velocities are
> being mapped to nodes that are not all on the inlet. It does compile
> and run though.
> I'd sincerely appreciate any the help in making it work.
> Warm regards,
> Tom
> I have included my .usr file below.
> C-----------------------------
> C  nek5000 user-file template
> C
> C  user specified routines:
> C     - userbc : boundary conditions
> C     - useric : initial conditions
> C     - uservp : variable properties
> C     - userf  : local acceleration term for fluid
> C     - userq  : local source term for scalars
> C     - userchk: general purpose routine for checking errors etc.
> C
> C-----------------------------------------------------------------------
>       subroutine uservp(ix,iy,iz,eg) ! set variable properties
>       include 'SIZE'
>       include 'TOTAL'
>       include 'NEKUSE'
>       integer e,f,eg
> c     e = gllel(eg)
>       udiff  = 0.0
>       utrans = 0.0
>       return
>       end
> c-----------------------------------------------------------------------
>       subroutine userf(ix,iy,iz,eg) ! set acceleration term
> c
> c     Note: this is an acceleration term, NOT a force!
> c     Thus, ffx will subsequently be multiplied by rho(x,t).
> c
>       include 'SIZE'
>       include 'TOTAL'
>       include 'NEKUSE'
>       integer e,f,eg
>       ffx=0
>       ffy=0
>       ffz=0
>       return
>       end
>       subroutine userq(ix,iy,iz,eg) ! set source term
>       include 'SIZE'
>       include 'TOTAL'
>       include 'NEKUSE'
>       integer e,f,eg
> c     e = gllel(eg)
>       qvol   = 0.0
>       source = 0.0
>       return
>       end
>       subroutine userbc(ix,iy,iz,iside,eg) ! set up boundary
> conditions
> c     NOTE: This routine may or may not be called by every
> processor
>       include 'SIZE'
>       include 'TOTAL'
>       include 'NEKUSE'
>       integer e,eg,ix,iy,iz,NELY,NELZ,egs
>       common /myinlet/ Arrangedu(ly1,lz1,lelt),
>      >                 Arrangedv(ly1,lz1,lelt),
>      >                 Arrangedw(ly1,lz1,lelt)
>       e  = gllel(eg)
>       ux   = Arrangedu(iy,iz,eg)
>       uy   = Arrangedv(iy,iz,eg)
>       uz   = Arrangedw(iy,iz,eg)
>       temp = 0.0
>       return
>       end
>       subroutine useric(ix,iy,iz,eg) ! set up initial conditions
>       include 'SIZE'
>       include 'TOTAL'
>       include 'NEKUSE'
>       integer e,eg
>       ux   = 7.235
>       uy   = 0.0
>       uz   = 0.0
>       temp = 0.0
>       return
>       end
>       subroutine userchk()
>       include 'SIZE'
>       include 'TOTAL'
>       return
>       end
>       subroutine usrdat()   ! This routine to modify element
> vertices
>       include 'SIZE'
>       include 'TOTAL'
>       return
>       end
>       subroutine usrdat2()  ! This routine to modify mesh
> coordinates
>       include 'SIZE'
>       include 'TOTAL'
>       call read_inlet(Arrangedu,Arrangedv,Arrangedw) ! Read in
> inlet data for BCs
>       return
>       end
>       subroutine usrdat3()
>       include 'SIZE'
>       include 'TOTAL'
>       return
>       end
> C-------------------------------------------------------------------------------
>       subroutine read_inlet(Arrangedu,Arrangedv,Arrangedw) ! Read
> in the inlet data
>       include 'SIZE'
>       include 'TOTAL'
>       Integer    Max_Nodes,          Lun_Dat
>       Parameter( Max_Nodes = 200000, Lun_Dat = 3)
>       real Var_1( Max_Nodes,lx1), Var_2( Max_Nodes), Var_3(
> Max_Nodes)
>       real Var_4( Max_Nodes), Var_5( Max_Nodes), Var_6(
> Max_Nodes)
>       real Arrangedu(ly1,lz1,lelt)
>       real Arrangedv(ly1,lz1,lelt)
>       real Arrangedw(ly1,lz1,lelt)
>       integer i_row( Max_Nodes), i_eg( Max_Nodes), i_y(
> Max_Nodes)
>       real junk
>       integer i, j, k, l, m, n, imin, imax, N_Nodes,ze, iyz,
> egs,egz
>       integer fcount
>       Character Line* 72
>       Character  Directory* 57
>       Parameter( Directory=
> '/home/tom/NEK/meshControl/MultiBox/MultiBox_10/NewInlet4/')
> c
> 1234567890123456789012345678901234567890123456789012345678
>       Character  Filename* 4
>       Parameter( Filename= '.dat')
> c                           12345
>       character(2) fc
> C     +-----------+
> C     | Execution |
> C     +-----------+
> 1       format( 1x, a)
>       do fcount=1,3 !for each file 01=u;02=v;03=w.
> 37    format (I2.2)
>       write (fc,37) fcount ! converting integer to string
>       print *,'Readining file #: ',fc
>       open( unit = Lun_Dat, status = 'old', form='formatted', err
> = 2,
>      >      file = Directory//trim(fc)//Filename)
>       go to 3
> 2     write( 6, 1) 'Error Opening file - EXIT'
> 3     read( Lun_Dat, 1)  Line
>       N_Nodes = 0
>       do i = 1, Max_Nodes
>          read( Lun_Dat, 11, end=5) i_row(i),  i_eg(i),
> i_y(i),
>      >                      Var_1(i,1),
> Var_1(i,2), Var_1(i,3),
>      >                      Var_1(i,4),
> Var_1(i,5), Var_1(i,6),
>      >                      Var_1(i,7),
> Var_1(i,8), Var_1(i,9)
> 11       format( i6, 1x, i5, 1x, i4, 9( 1x, 1P E16.9))
>          N_Nodes = N_Nodes + 1
>        if( fcount .EQ. 1) THEN
>          iyz=i_y(i)
>          egz=i_eg(i)
>          do ze=1,lx1
>          Arrangedu(iyz,ze,egz)= Var_1(i,ze)
>          end do
>        else if( fcount .EQ. 2) THEN
>          iyz=i_y(i)
>          egz=i_eg(i)
>          do ze=1,lx1
>          Arrangedv(iyz,ze,egz)= Var_1(i,ze)
>          end do
>       else if( fcount .EQ. 3) THEN
>          iyz=i_y(i)
>          egz=i_eg(i)
>          do ze=1,lx1
>          Arrangedw(iyz,ze,egz)= Var_1(i,ze)
>          end do
>       end if
>       end do
>       write( 6, 1) ' '
>       write( 6, 1) ' WARNING - Max nodes exceeeded'
>       write( 6, 1) ' '
> 5     write( 6, 6) N_Nodes
> 6     format( ' Number of nodes read = ', I8)
>       end do
>       end
> Links:
> [1]
> Nek5000-users mailing list
