[Nek5000-users] Parallel issue: Inflow conditions from external files
Fri Sep 26 05:52:06 CDT 2014
Did you manage to solve the problem? I also have the same problem... I
am able to read velocity data and to set them as initial condition in
serial, but in parallel it is not working... The velocity is mapped to
nodes that are not the proper ones...
What is wrong?
Thanks!
SL
El 10-09-2014 13:08, nek5000-users at lists.mcs.anl.gov escribió:
> Hi all,
> I have a question on how to read in information from external files as
> an inflow boundary condition when running in parallel.
> Similar problem to this:
> http://lists.mcs.anl.gov/pipermail/nek5000-users/2010-December/001151.html
> [1]
> My geometry is a simple 3D rectangle prism with the inlet on the Y-Z
> plane @ x=0.
> I have developed some code that reads in a 2D plane of velocity data
> from another simulation (in this case fluent) as the boundary
> condition in userbc(). I am happy to share the process and the code
> (Fortran input/output from NEK, and MATLAB to do interpolation)
> however here I am primarily focused on getting it working in parallel.
> The process works fine in serial - it reads in 3 files (01.dat,
> 02.dat, 03.dat) that hold the x,y,z velocity (respectively) for each
> node on the inlet.
> However it does not work correctly when running in parallel - looking
> at the results after a few iterations shows that the velocities are
> being mapped to nodes that are not all on the inlet. It does compile
> and run though.
> I'd sincerely appreciate any the help in making it work.
> Warm regards,
> Tom
> I have included my .usr file below.
> C-----------------------------
> C  nek5000 user-file template
> C
> C  user specified routines:
> C     - userbc : boundary conditions
> C     - useric : initial conditions
> C     - uservp : variable properties
> C     - userf  : local acceleration term for fluid
> C     - userq  : local source term for scalars
> C     - userchk: general purpose routine for checking errors etc.
> C
> C-----------------------------------------------------------------------
>       subroutine uservp(ix,iy,iz,eg) ! set variable properties
>       include 'SIZE'
>       include 'TOTAL'
>       include 'NEKUSE'
>       integer e,f,eg
> c     e = gllel(eg)
>       udiff  = 0.0
>       utrans = 0.0
>       return
>       end
> c-----------------------------------------------------------------------
>       subroutine userf(ix,iy,iz,eg) ! set acceleration term
> c
> c     Note: this is an acceleration term, NOT a force!
> c     Thus, ffx will subsequently be multiplied by rho(x,t).
> c
>       include 'SIZE'
>       include 'TOTAL'
>       include 'NEKUSE'
>       integer e,f,eg
>       ffx=0
>       ffy=0
>       ffz=0
>       return
>       end
>       subroutine userq(ix,iy,iz,eg) ! set source term
>       include 'SIZE'
>       include 'TOTAL'
>       include 'NEKUSE'
>       integer e,f,eg
> c     e = gllel(eg)
>       qvol   = 0.0
>       source = 0.0
>       return
>       end
>       subroutine userbc(ix,iy,iz,iside,eg) ! set up boundary
> conditions
> c     NOTE: This routine may or may not be called by every
> processor
>       include 'SIZE'
>       include 'TOTAL'
>       include 'NEKUSE'
>       integer e,eg,ix,iy,iz,NELY,NELZ,egs
>       common /myinlet/ Arrangedu(ly1,lz1,lelt),
>      >                 Arrangedv(ly1,lz1,lelt),
>      >                 Arrangedw(ly1,lz1,lelt)
>       e  = gllel(eg)
>       ux   = Arrangedu(iy,iz,eg)
>       uy   = Arrangedv(iy,iz,eg)
>       uz   = Arrangedw(iy,iz,eg)
>       temp = 0.0
>       return
>       end
>       subroutine useric(ix,iy,iz,eg) ! set up initial conditions
>       include 'SIZE'
>       include 'TOTAL'
>       include 'NEKUSE'
>       integer e,eg
>       ux   = 7.235
>       uy   = 0.0
>       uz   = 0.0
>       temp = 0.0
>       return
>       end
>       subroutine userchk()
>       include 'SIZE'
>       include 'TOTAL'
>       return
>       end
>       subroutine usrdat()   ! This routine to modify element
> vertices
>       include 'SIZE'
>       include 'TOTAL'
>       return
>       end
>       subroutine usrdat2()  ! This routine to modify mesh
> coordinates
>       include 'SIZE'
>       include 'TOTAL'
>       call read_inlet(Arrangedu,Arrangedv,Arrangedw) ! Read in
> inlet data for BCs
>       return
>       end
>       subroutine usrdat3()
>       include 'SIZE'
>       include 'TOTAL'
>       return
>       end
> C-------------------------------------------------------------------------------
>       subroutine read_inlet(Arrangedu,Arrangedv,Arrangedw) ! Read
> in the inlet data
>       include 'SIZE'
>       include 'TOTAL'
>       Integer    Max_Nodes,          Lun_Dat
>       Parameter( Max_Nodes = 200000, Lun_Dat = 3)
>       real Var_1( Max_Nodes,lx1), Var_2( Max_Nodes), Var_3(
> Max_Nodes)
>       real Var_4( Max_Nodes), Var_5( Max_Nodes), Var_6(
> Max_Nodes)
>       real Arrangedu(ly1,lz1,lelt)
>       real Arrangedv(ly1,lz1,lelt)
>       real Arrangedw(ly1,lz1,lelt)
>       integer i_row( Max_Nodes), i_eg( Max_Nodes), i_y(
> Max_Nodes)
>       real junk
>       integer i, j, k, l, m, n, imin, imax, N_Nodes,ze, iyz,
> egs,egz
>       integer fcount
>       Character Line* 72
>       Character  Directory* 57
>       Parameter( Directory=
> '/home/tom/NEK/meshControl/MultiBox/MultiBox_10/NewInlet4/')
> c
> 1234567890123456789012345678901234567890123456789012345678
>       Character  Filename* 4
>       Parameter( Filename= '.dat')
> c                           12345
>       character(2) fc
> C     +-----------+
> C     | Execution |
> C     +-----------+
> 1       format( 1x, a)
>       do fcount=1,3 !for each file 01=u;02=v;03=w.
> 37    format (I2.2)
>       write (fc,37) fcount ! converting integer to string
>       print *,'Readining file #: ',fc
>       open( unit = Lun_Dat, status = 'old', form='formatted', err
> = 2,
>      >      file = Directory//trim(fc)//Filename)
>       go to 3
> 2     write( 6, 1) 'Error Opening file - EXIT'
> 3     read( Lun_Dat, 1)  Line
>       N_Nodes = 0
>       do i = 1, Max_Nodes
>          read( Lun_Dat, 11, end=5) i_row(i),  i_eg(i),
> i_y(i),
>      >                      Var_1(i,1),
> Var_1(i,2), Var_1(i,3),
>      >                      Var_1(i,4),
> Var_1(i,5), Var_1(i,6),
>      >                      Var_1(i,7),
> Var_1(i,8), Var_1(i,9)
> 11       format( i6, 1x, i5, 1x, i4, 9( 1x, 1P E16.9))
>          N_Nodes = N_Nodes + 1
>        if( fcount .EQ. 1) THEN
>          iyz=i_y(i)
>          egz=i_eg(i)
>          do ze=1,lx1
>          Arrangedu(iyz,ze,egz)= Var_1(i,ze)
>          end do
>        else if( fcount .EQ. 2) THEN
>          iyz=i_y(i)
>          egz=i_eg(i)
>          do ze=1,lx1
>          Arrangedv(iyz,ze,egz)= Var_1(i,ze)
>          end do
>       else if( fcount .EQ. 3) THEN
>          iyz=i_y(i)
>          egz=i_eg(i)
>          do ze=1,lx1
>          Arrangedw(iyz,ze,egz)= Var_1(i,ze)
>          end do
>       end if
>       end do
>       write( 6, 1) ' '
>       write( 6, 1) ' WARNING - Max nodes exceeeded'
>       write( 6, 1) ' '
> 5     write( 6, 6) N_Nodes
> 6     format( ' Number of nodes read = ', I8)
>       end do
>       end
> Links:
> [1]
> Nek5000-users mailing list
