[Nek5000-users] Wall Clock Time
Tue Sep 2 16:19:14 CDT 2014
Hello all,
I'm interested in comparing the wall clock time for a same run with
different number of CPU's. However, the time output seems to always give
0. I have tried using the mpi_wtime and dnekclock functions in the
userchk subroutine and it has also been giving me 0 for each processor.
I have included the end of my logfile in this email. The last 2 values
of the first output line for a time step should give the total wall
clock time and step wall clock time, but are both showing 0. At the end
of the run, total elapsed time should be shown, but once again the value
output is zero.
Has anyone figured out a method permitting to obtain the total wall
clock time?
Thank you,
Jérémie
----------------------- END OF LOGFILE
Step     20, t= 4.8774474E-02, DT= 2.4387237E-03, C=  0.501 0.0000E+00
0.0000E+00
              Solving for fluid
       20  1  4.7138E-02  1.7111E-07  2.7549E+05  15 alph1x
     20 halpha  15 -1.1778E-03  1.2672E-01  6.1694E-02  1.1588E-01
5.4007E-02  5.1022E-02  3.1403E-02  2.4425E-02  1.0726E-02 6.0344E-03
          20    Hmholtz VELX:      3   2.6011E-13   1.7111E-07 1.0000E-12
       20  2  3.4534E-02  2.5050E-07  1.3786E+05  15 alph1x
     20 halpha  15  1.8538E-02  1.0186E-01  4.5783E-02  4.5495E-02
4.2007E-02  4.7957E-02  3.7328E-02  2.8192E-02  2.2477E-02 9.2507E-03
          20    Hmholtz VELY:      3   3.4751E-13   2.5050E-07 1.0000E-12
    20   15 alpha: -2.7079E-06 -1.8713E-04  3.2842E-03  3.7249E-03
2.1355E-03  1.4731E-03  1.7188E-03  3.0469E-03  1.6907E-03 1.1608E-03
     20  15  4.0387E-03  7.8105E-07  5.1708E+03 alph12
         20 U-PRES gmres:     13  8.2682E-13  1.0000E-12  1.0390E-09
0.0000E+00  0.0000E+00
           20  DNORM, DIVEX   8.2682338981824994E-013
8.2682352659334355E-013
          20   4.8774E-02  0.0000E+00 Fluid done
  call outfld: ifpsco: F
        20  4.8774E-02 Write checkpoint:
        0      20 OPEN: naca24150.f00001
        20  4.8774E-02 done :: Write checkpoint
                               file size =      4.4    MB
                               avg data-throughput =     InfMB/s
                               io-nodes =     1
end of time-step loop
runtime statistics:
  total time   9.9999999999999995E-008
  inv3 time         621   0.0000000000000000 0.0000000000000000
  invc time          80   0.0000000000000000 0.0000000000000000
  mltd time        1282   0.0000000000000000 0.0000000000000000
  cdtp time        1282   0.0000000000000000 0.0000000000000000
  eslv time          20   0.0000000000000000 0.0000000000000000
  pres time          20   0.0000000000000000 0.0000000000000000
  crsl time         565   0.0000000000000000 0.0000000000000000
  crsl min    0.0000000000000000
  crsl max    0.0000000000000000
  crsl avg    0.0000000000000000
  hmhz time           8   0.0000000000000000 0.0000000000000000
  spro time          21   0.0000000000000000 0.0000000000000000
  usbc time          21   0.0000000000000000 0.0000000000000000
  usbc min    0.0000000000000000
  usbc max    0.0000000000000000
  usb  avg    0.0000000000000000
  axhm time         458   0.0000000000000000 0.0000000000000000
  advc time          40   0.0000000000000000 0.0000000000000000
  vdss time         622   0.0000000000000000 0.0000000000000000
  vdss min    0.0000000000000000
  vdss max    0.0000000000000000
  vdss avg    0.0000000000000000
  dsum time        2139   0.0000000000000000 0.0000000000000000
  dsum min    0.0000000000000000
  dsum max    0.0000000000000000
  dsum avg    0.0000000000000000
  dadd time           0   0.0000000000000000 0.0000000000000000
  ddsl time         565   0.0000000000000000 0.0000000000000000
  solv time         565   0.0000000000000000 0.0000000000000000
  prep time          20   0.0000000000000000 0.0000000000000000
#  nid       tusbc       tdadd       tcrsl       tvdss tdsum
tgop    qqq    F
         0  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00 0.0000E+00
0.0000E+00 qqq
         1  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00 0.0000E+00
0.0000E+00 qqq
         2  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00 0.0000E+00
0.0000E+00 qqq
         3  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00 0.0000E+00
0.0000E+00 qqq
         4  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00 0.0000E+00
0.0000E+00 qqq
         5  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00 0.0000E+00
0.0000E+00 qqq
call exitt: dying ...
backtrace(): obtained 5 stack frames.
./nek5000(print_stack_+0x1a) [0x4fa15a]
./nek5000(exitt_+0x1a6) [0x5e6b56]
./nek5000(main+0x39) [0x419489]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x2b7993c6076d]
./nek5000() [0x4194b9]
total elapsed time             :   0.00000E+00 sec
total solver time incl. I/O    :   0.00000E+00 sec
time/timestep                  :   0.00000E+00 sec
CPU seconds/timestep/gridpt    :   0.00000E+00 sec
