[Nek5000-users] Constant mass flow rate in simulation
Wed Sep 3 13:06:40 CDT 2014
Hi Paul,
I see. Thank you very much for your help. I appreciate it a lot.
By the way, for the fluctuation term you mentioned, is it time derivative of total wall shear?
Best regards,
Tony
From: nek5000-users-bounces at lists.mcs.anl.gov <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users-request at lists.mcs.anl.gov <nek5000-users-request at lists.mcs.anl.gov>
Sent: 03 September 2014 2:04
To: nek5000-users at lists.mcs.anl.gov
Subject: Nek5000-users Digest, Vol 67, Issue 4
Send Nek5000-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
        https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        nek5000-users-owner at lists.mcs.anl.gov
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Nek5000-users digest..."
Today's Topics:
   1. Re: Constant mass flow rate in simulation
      (nek5000-users at lists.mcs.anl.gov)
Message: 1
Date: Wed, 3 Sep 2014 01:04:11 +0000
To: "nek5000-users at lists.mcs.anl.gov"
        <nek5000-users at lists.mcs.anl.gov>
Subject: Re: [Nek5000-users] Constant mass flow rate in simulation
Message-ID:
        <mailman.4974.1409706253.3424.nek5000-users at lists.mcs.anl.gov>
Content-Type: text/plain; charset="us-ascii"
Hi Tony,
The main reason that fixing the body force to match the wall shear is that there is a significant
fluctuation term in
   d/dt    \int_Omega u(X,t) dV
so, you have to balance that term as well.
Because homogeneous BCs are used on U0 (no bcs on p, p', or p0), you can use whatever
would be the correct boundary conditions for U when updating U'.   The net result (solution at
the next time step) is:
    U = U' + a*U0
Does this clarify?
Best, Paul
PS -- note that the vol_flow rate routines also tell you what ffx(t) is that is required
to keep the flow rate fixed, i.e., it tells you what is the requisite body force.
A peek at the source reveals in subroutine vol_flow:
      delta_flow = flow_rate-current_flow
c
c     Note, this scale factor corresponds to FFX, provided FFX has
c     not also been specified in userf.   If ffx is also specified
c     in userf then the true FFX is given by ffx_userf + scale.
c
      scale = delta_flow/base_flow
      scale_vf(icvflow) = scale
      if (nio.eq.0) write(6,1) istep
     $   ,time,scale,delta_flow,current_flow,flow_rate,chv(icvflow)
    1    format(i8,e14.7,1p4e13.5,' volflow',1x,a1)
c
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Tuesday, September 02, 2014 5:42 PM
Dear Paul,
Thank you so much for the very detailed and patient explanation.
Just a few things want to make clear since my understanding is not good. In the procedure you explained, does the linear combination of (2) and (3) form the flow field at next time step? If so, what's the boundary condition for U' and p'? In the process, actually we are not providing the body force, by working out the alpha value based on current flow field and resolved (U',p') we achieve the target mass flow rate, is that right?
By calculating the mean wall shear stress and update the mean pressure gradient (actually the body force) every time step we should be able to fix the rate, I'm just wondering why it doesn't work here?
I'm just trying to understand this and I apologise if those questions are actually stupid. I really appreciate your help. Thank you very much.
Best regards,
Tony
Sent: 01 September 2014 23:50
Subject: Nek5000-users Digest, Vol 67, Issue 2
Today's Topics:
   2. Re: Constant mass flow rate in simulation
   3. Re: Constant mass flow rate in simulation
Message: 1
Date: Mon, 1 Sep 2014 19:02:19 +0000
Message-ID:
        <mailman.4865.1409598165.3424.nek5000-users at lists.mcs.anl.gov>
Content-Type: text/plain; charset="iso-8859-1"
Dear Paul,
Thank you very much for the tips. I've tested my simulation case based on your instruction and it worked perfectly for keeping constant mass flow rate. However, I noticed that in the end of subroutine 'vol_flow', the velocity and pressure filed are forced to achieve constant flow rate. By doing this, would it be like changing the resolved flow field to get fixed flow rate, in which case the flow field is scaled on purpose rather than being solved directly from N-S equations. I don't know whether my understanding of this procedure is right or not. Please point out if I was wrong.
Another thing is, in turbulent channel flow, in theory the constant mass flow rate can be achieved by balancing the force (mean pressure gradient) with mean wall shear stress, however this didn't work in my case. Is it because this method is not compatible with spectral method or is there any systematic issue?
It would be great if you can give me some clues for my confusions. I really appreciate it. Thank you very much in advance.
Best regards,
Tony
Sent: 01 September 2014 18:00
Subject: Nek5000-users Digest, Vol 67, Issue 1
Today's Topics:
   1. Re: Outpost question (nek5000-users at lists.mcs.anl.gov)
   2. Constant mass flow rate in simulation
Message: 1
Date: Sun, 31 Aug 2014 20:17:18 +0200
To: Nek 5000 <nek5000-users at lists.mcs.anl.gov>
Subject: Re: [Nek5000-users] Outpost question
Message-ID:
        <mailman.4827.1409509062.3424.nek5000-users at lists.mcs.anl.gov>
Content-Type: text/plain; charset="utf-8"
Hi Katherine,
I was wondering if you had time to check on the parameter to be reset so
that I can overwrite previous files?
Bonne soir?e,
JC
2014-08-15 16:57 GMT+02:00 <nek5000-users at lists.mcs.anl.gov>:
> Hi Katherine,
> Thanks for the answer. I knew about the parameter 15 and was not sure
> about the 64 bits precision. This is now more clear.
> Regarding the overwriting, I had guessed that prepost has a parameter that
> needs to be reset, but I haven't been able to figure out which one so far.
> That would be very helpful if you can take a quick look at it.
> Thanks a lot and enjoy the end of the summer
> JC
> 2014-08-15 16:53 GMT+02:00 <nek5000-users at lists.mcs.anl.gov>:
>> Hi JC,
>> You should be able to control the outpost frequency and precision using
>> the parameters parameter 15 (IOSTEP) and parameter 63, respectively.
>> So, if you wanted the first 100 steps to output every step, you would set
>> something like:
>> if(istep.le.100)  param(15)=1
>>  To set the precision to 64bit, set param(63)=8, as well.  Setting
>> param(63) to anything else should default it to 8 byte precision.
>> As far as overwriting previous fld files, you should be able to reset a
>> parameter used in prepost.f that increments the file counter.  I haven't
>> had a chance to test this, but I can take a look at it last this weekend.
>> hth.
>> Katherine
>> On Fri, Aug 15, 2014 at 3:34 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Howdy Nek's,
>>> I have a couple questions regarding the ouput of files:
>>>    1. How can force, within the code (say in usrchk), some files to be
>>>    output in 64 bits for high-accuracy checkpointing and other in regular 8
>>>    bits for simple visualisation?
>>>    2. Say, during the first 1000 iterations, the code outpost a file
>>>    every single iteration so that I have blah0.f00001 to blah0.f01000. How can
>>>    I then force the code to outpost my new files (from istep = 1001 to 2000
>>>    say) rewriting on blah0.f00001 to blah0.f01000?
>>> Thanks a lot.
>>> Regards,
>>> JC
>>> Jean-Christophe Loiseau
>>> Homepage <https://sites.google.com/site/loiseaujc/>
>>> _______________________________________________
>>> Nek5000-users at lists.mcs.anl.gov
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140831/13dce213/attachment-0001.html>
Message: 2
Date: Sun, 31 Aug 2014 22:57:27 +0000
Subject: [Nek5000-users] Constant mass flow rate in simulation
Message-ID:
        <mailman.4832.1409525852.3424.nek5000-users at lists.mcs.anl.gov>
Dear Neks,
Recently I've been struggling with constant mass flow rate in my turbulent channel flow simulation. Based on the userchk subroutine in 'turbChannel' tutorial case, I also used torque_calc(1.0,x0,.false.,.false.) to calculate the wall shear and then got the mean wall shear. After that I set mean pressure gradient 'ffx' equal to the mean wall shear in order to keep constant mass flow rate. In this case, the flow rate started from 1 (nondimensionalised case, bulk mean equal to 1) and kept increasing. Although the increment was very small at each time step, it never stopped and the bulk mean velocity has increased to 1.002.
Is it appropriate to set constant mass flow rate by updating mean pressure gradient based on mean wall shear in Nek5000 or am I using the wrong calculation? Since the bulk mean is still increasing, the simulation is like acceleration channel flow.
Does anyone has any clue about how to set constant mass flow rate for turbulent channel flow in Nek5000? Any idea is appreciated and many thanks in advance.
Thanks and regards,
Tony
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140831/65501e25/attachment-0001.html>
Message: 3
Date: Sun, 31 Aug 2014 23:58:32 +0000
Message-ID:
        <mailman.4833.1409529514.3424.nek5000-users at lists.mcs.anl.gov>
Hi Tony,
I would just set p55=1.0; p54=-1.0
This will fix < u_x > == 1.0
If you are using variable viscosity, this might be problematic, but for the
constant viscosity case this is the best way.
Be certain to also set ffx=ffy=ffz=0 in the .usr file, the the p54/p55 combination
sets the x-body force as needed to ensure the prescribed mass flux is realized.
Paul
Sent: Sunday, August 31, 2014 5:57 PM
Dear Neks,
Thanks and regards,
Tony
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140831/0fc955b0/attachment-0001.html>
End of Nek5000-users Digest, Vol 67, Issue 1
Message: 2
Date: Mon, 1 Sep 2014 16:14:40 -0500 (CDT)
Message-ID:
        <mailman.4866.1409606082.3424.nek5000-users at lists.mcs.anl.gov>
Content-Type: TEXT/PLAIN; charset=US-ASCII; format=flowed
Hi Tony,
Nek uses a semi-implicit formulation in which the nonlinear term
is treated explicitly in time.
The update is of the form:
(1)   L(U,p) = NL(u) + BC + F(t)
where, L is the linear unsteady Stokes operator, NL() accounts for
nonlinear terms and BC accounts for boundary data and F(t) accounts
for body force.   A fixed flow rate implies that F(t) adjusts to
ensure the constant flow rate.
Because L is linear, we can split the time advancement into two
parts using superposition:
(2)   L(U',p') = NL(u) + BC
(3)   L(U0,p0) = F0 + BC(0),   where BC(0) := homogeneous boundary
conditions
(4)   U = U' + a*U0,
(5)   p = p' + a*p
where a is a constant
For fixed flow rate, you need
(6)   \int U.x_hat dV = constant
which implies
(7)   a = [ constant - \int U'.x_hat dV ] / [ \int U0.x_hat dV ]
Note that (2) is independent of U and time and therefore can
be solved in a preprocessing step (assuming dt is fixed and viscosity
is time-invariant).
That is what the vol_flow routines do.
The scheme inherits the full temporal and spatial accuracy of the
constant pressure-drop case.
hth,
Paul
On Mon, 1 Sep 2014, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Paul,
> issue?
> Best regards, Tony
> ________________________________________ From:
> <nek5000-users-request at lists.mcs.anl.gov> Sent: 01 September 2014 18:00 To:
> nek5000-users at lists.mcs.anl.gov Subject: Nek5000-users Digest, Vol 67, Issue
> 1
> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users or, via email, send
> When replying, please edit your Subject line so it is more specific than "Re:
> Today's Topics:
>   1. Re: Outpost question (nek5000-users at lists.mcs.anl.gov) 2. Constant mass
>   flow rate in simulation (nek5000-users at lists.mcs.anl.gov) 3. Re: Constant
>   mass flow rate in simulation (nek5000-users at lists.mcs.anl.gov)
> Message: 1 Date: Sun, 31 Aug 2014 20:17:18 +0200 From:
> nek5000-users at lists.mcs.anl.gov To: Nek 5000
> <nek5000-users at lists.mcs.anl.gov> Subject: Re: [Nek5000-users] Outpost
> question Message-ID:
> <mailman.4827.1409509062.3424.nek5000-users at lists.mcs.anl.gov> Content-Type:
> Hi Katherine,
> I was wondering if you had time to check on the parameter to be reset so that
> Bonne soir?e, JC
>> Hi Katherine,
>> Thanks for the answer. I knew about the parameter 15 and was not sure about
>> the 64 bits precision. This is now more clear.  Regarding the overwriting, I
>> had guessed that prepost has a parameter that needs to be reset, but I
>> haven't been able to figure out which one so far.  That would be very
>> Thanks a lot and enjoy the end of the summer ++
>> JC
>>> Hi JC,
>>> You should be able to control the outpost frequency and precision using the
>>> something like:
>>> hth.  Katherine
>>>> Howdy Nek's,
>>>>    8 bits for simple visualisation?  2. Say, during the first 1000
>>>>    iterations, the code outpost a file every single iteration so that I
>>>>    have blah0.f00001 to blah0.f01000. How can I then force the code to
>>>>    outpost my new files (from istep = 1001 to 2000 say) rewriting on
>>>> Thanks a lot.  Regards,
>>>> JC
>>>> -- Jean-Christophe Loiseau Homepage
>>>> _______________________________________________ Nek5000-users mailing list
> <https://sites.google.com/site/loiseaujc/> -------------- next part
> -------------- An HTML attachment was scrubbed...  URL:
> Message: 2 Date: Sun, 31 Aug 2014 22:57:27 +0000 From:
> nek5000-users at lists.mcs.anl.gov To: "nek5000-users at lists.mcs.anl.gov"
> <nek5000-users at lists.mcs.anl.gov> Subject: [Nek5000-users] Constant mass flow
> rate in simulation Message-ID:
> <mailman.4832.1409525852.3424.nek5000-users at lists.mcs.anl.gov> Content-Type:
> Dear Neks,
> advance.
> Thanks and regards, Tony
> -------------- next part -------------- An HTML attachment was scrubbed...
> URL:
> Message: 3 Date: Sun, 31 Aug 2014 23:58:32 +0000 From:
> <nek5000-users at lists.mcs.anl.gov> Subject: Re: [Nek5000-users] Constant mass
> flow rate in simulation Message-ID:
> <mailman.4833.1409529514.3424.nek5000-users at lists.mcs.anl.gov> Content-Type:
> Hi Tony,
> combination sets the x-body force as needed to ensure the prescribed mass
> flux is realized.
> Paul
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov] Sent:
> Sunday, August 31, 2014 5:57 PM To: nek5000-users at lists.mcs.anl.gov Subject:
> Dear Neks,
> advance.
> URL:
Message: 3
Date: Mon, 1 Sep 2014 17:50:52 -0500 (CDT)
Message-ID:
        <mailman.4871.1409611853.3424.nek5000-users at lists.mcs.anl.gov>
Hi Tony,
[ A slightly revised response to address a couple of typos..]
(3.5)   F = alpha*F0
(4)   U = U' + alpha*U0,
(5)   p = p' + alpha*p
where BC(0) := homogeneous boundary conditions and
alpha is a free paramter.  For fixed flow rate, you need
                       = \int ( U' + alpha U0 ) . x_hat dV
which implies
(7)   alpha = [ constant - \int U'.x_hat dV ] / [ \int U0.x_hat dV ]
is time-invariant).
The vol_flow routines implement this two-part scheme, which
retains the full temporal and spatial accuracy of the constant
pressure-drop case.
hth,
Paul
>> Dear Paul,
>> rate.
>> and
>> would
>> which
>> flow
>> systematic
>> issue?
>> Best regards, Tony
>> Issue
>> 1
>> send
>> "Re:
>> Today's Topics:
>> mass
>> Content-Type:
>> Hi Katherine,
>> that
>> Bonne soir?e, JC
>>> Hi Katherine,
>>> about
>>> I
>>> JC
>>>> Hi JC,
>>>> the
>>>> something like:
>>>> hth.  Katherine
>>>>> Howdy Nek's,
>>>>> regular
>>>>> JC
>>>>> list
>>>> list
>> flow
>> Content-Type:
>> Dear Neks,
>> Although
>> bulk
>> like
>> in
>> advance.
>> URL:
>> mass
>> Content-Type:
>> Hi Tony,
>> flux is realized.
>> Paul
>> Subject:
>> Dear Neks,
>> Although
>> bulk
>> like
>> in
>> advance.
>> URL:
End of Nek5000-users Digest, Vol 67, Issue 2
End of Nek5000-users Digest, Vol 67, Issue 4
